Rear bumper and blind spot detection system?
Discussion in '2.5 Gen Tundras (2014-2021)' started by FA141794, Oct 26, 2018.
  1. May 5, 2021 at 6:37 AM
    Saltyhero13
    Saltyhero13 Throbbing Member
    BSM and RCTA use the same sensors in the bumper. They aren't two separate systems but more like a system with two modes where RCTA is activated when in reverse.
    AggiePhil and OhEmmBee[QUOTED] like this.
  2. May 5, 2021 at 9:59 AM
    ICI
    ICI New Member
    It shouldn't cause any issues as long as you properly secure them. You should also be able to turn off the BSM through your dashboard settings: http://www.ttundra.com/63/bsm_blind_spot_monitor_.html
    Yes, sir! Works like a charm.
  3. May 5, 2021 at 1:51 PM
    Saltyhero13
    Thanks for the update. I prefer asynchronous written communications. I don't have an issue if it were the Aluminite (TM) Resin product but good to know it is 5052.
    Do you have any videos of the product running with functional BSM/RCTA? Also the orientation of the sensors seems to be compatible with the earlier pre2018 sensors; the newer sensors 2018+ are smaller and would require the mounting points to be rotated 90 degrees. Aside from that, solid design.
    Also when do you expect this to be in back in stock? (screen shot from a few minutes ago)
    Thanks
    AggiePhil likes this.
  4. May 5, 2021 at 2:49 PM
    ICI
    ICI New Member
    I don't think we have any videos showcasing that particular function, but we'll be sure to add it to our next video shoot. Thanks for the tip!
    As far as the 2018+ sensors go, our mounting brackets account for both orientations without any modification. Our engineers are quite crafty like that.
    Bringing us to availability. In theory, you should be able to get your hands on one around July. Also, if you shoot over an email to info@icionline.com and let them know you're from the forums, they MAY even give you a clutch discount... WHO KNOWS!? :cheers:
  5. May 6, 2021 at 12:32 AM
    OhEmmBee
    OhEmmBee Rick
    Richard
    Denver
    18' Toyota Tundra MGM Crewmax (Saibot)
    Toyota Tundra Pro Grill Lace On Steering Wheel Cover Garmin Tandem and Mini Dash Cam. Center Console Safe Compustar Remote Start with DM ESP Rear under storage VLED Front & Rear foot well LED Lights Sound Deadened Cab Toytec Boss Alumna lift at 2 inches C4 Hybrid Front Bumper with four sets of Baja Designs. AlphaRex Novas Valhalla's Skid Plates Switch Pro-9100 SPC Upper Control Arms 35" tires on RRW Agressive BMC/CMC to fit larger tires. Minor bumper and fender liner trimming.
    Any chances we might also get a install video as well? I'm pretty certain anything needing installation has a install guide but I figured with securing and relocating the BSM/RCTA sensors, we got to measure twice and cut once hopefully!
    Saltyhero13 likes this.
  6. May 11, 2021 at 12:04 PM
    ICI
    ICI New Member
    Yessir! We're currently working on doing install videos on all of our products.
    Saltyhero13 and OhEmmBee[QUOTED] like this.
  7. Nov 24, 2021 at 12:45 PM
    wexttxco
    wexttxco New Member
    21 SR5 DC 4x4
    Fox 2.5 RR, 35x12.5r18 x3 on method 701, armor, front bumper
    Any new bumpers available with full sensor compatibility? And tested by someone other than the company. The westin one is piquing my interest.
  8. Nov 24, 2021 at 1:52 PM
    Saltyhero13
    Someone on another thread recently purchased the ICI rear but wont be able to install it until after the holidays.
    IMO you are almost better off sticking with OEM, most of these bumpers don't offer any clearance advantages and add weight to your overall vehicle. With that said ICI and RCI look like decent choices but you will likely have to mod to fix at least one of the issues below.
    Not familiar with the Westin offering but these bumpers seem to have common issues:
    • Check to make sure they support your model year sensor. Some of the models don't support the newer smaller sensors or the older larger sensors. mid 2017 appears to be when the sensors were switched.
    • Check to see the sensors are protected properly. Looking at some of the other forums regarding aftermarket bumpers, improper protection from vibration and environmental factors (dust, dirt, water etc) seem to cause these sensors to fail over time.
    • Check to see you can calibrate the sensors per Toyota instructions. In case of a failure during installation or after installation you'll want the ability to calibrate the sensors; most Toyota places won't touch it if its aftermarket.
    OhEmmBee and AggiePhil like this.
  9. Dec 4, 2021 at 5:45 PM
    AggiePhil
    AggiePhil Texas Chapter President
    College Station, TX
    2020 Smoked Mesquite Platinum 4x4
    Still no updates from CBI, apparently. :mad:
