RainMan's 2021 Lunar Rock TRD Pro Build
Discussion in '2.5 Gen Builds (2014-2021)' started by RainMan_PNW, Oct 30, 2020.
  1. Mar 23, 2024 at 8:04 AM
    #1051
    Mater
    Mater New Member
    Nick
    SD
    2016 MGM Platinum
    Just a thought I had this morning. You ever consider those sumi connectors aren’t up to snuff for that job. As I was making my connector last night I was thinking “these pins are pretty thin”. I haven’t looked up their specs but know they’re rated for 14awg. And that’s what the the SP wiring is, but looking at them I’m not sure I’d put 15A through them. Anyway. Just a thought
  2. Mar 23, 2024 at 8:40 AM
    #1052
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    Sqaure peg…round hole…
    Poor/undersized conductor/terminal mating = high resistance…high resistance = voltage drop…voltage drop = higher current…
    Ohm’s LAW
    and a 50 onx gets pretty dang close to hitting that 35 amp ceiling of the high current circuits in ideal conditions, let alone all of the other loads on concurrently.
    other than the usual house keeping items, resistance to ground, properly seated connections etc…
    I’d :
    1. ditch those connectors in favor of deutsch DTP at a minimum (if you split load between 4 circuit connector) better would be a set of DTHDs as they’re rated to carry the nearly 30 amp that bar draws…
    2. Look at offloading the 50” bar duties to a external relay. I really like using either one of these as aux relay
    note that this us a double…
    Or
  3. Mar 23, 2024 at 8:48 AM
    #1053
    Mater
    Mater New Member
    Nick
    SD
    2016 MGM Platinum
    Where the hell do you find this stuff??
    and if you want to make your life simpler, Casey, I’d just throw on an Anderson connector and call it good. Cheap and effective. SP should be able to carry the rest
    bulldog93 and TRDFerguson like this.
  4. Mar 23, 2024 at 8:53 AM
    #1054
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    previous life…lol
    TRDFerguson and Mater[QUOTED] like this.
  5. Mar 23, 2024 at 9:02 AM
    #1055
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    I was literally typing the same thing when you posted this.
    :homer:
  6. Mar 23, 2024 at 9:04 AM
    #1056
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    Shocked the troll in you didn’t say, f the connectors…just use wire nuts
  7. Mar 23, 2024 at 9:06 AM
    #1057
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    I think in this situation you’d just want to twist them together and wrap with a little duct tape to keep the resistance down. Maybe double up on the sprinkler wire between the SP and the Onx though.
  8. Mar 23, 2024 at 9:10 AM
    #1058
    RainMan_PNW
    RainMan_PNW [OP] "Oz" SSEM #82 RGBA #4 Unofficial Forum Treasurer Vendor?
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    The circuit splits to two terminals to mate up to the switch pro. The OnX is spec’d at 28A - yes, it’s high but leaves a 20% margin on a 35A breaker/fuse.
    I prefer the Sumi connectors over Deutsch. I may switch to 187’s on the higher amp circuits, but need to go some more testing first.
    End all will be to offload the 50” to a dedicated switch and relay, but I’m not ready to give up on the SP yet.
    coTony and TRDFerguson like this.
  9. Mar 23, 2024 at 9:11 AM
    #1059
    Mater
    Mater New Member
    Nick
    SD
    2016 MGM Platinum
  10. Mar 23, 2024 at 9:11 AM
    #1060
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    You could always just relay the circuit on the SP and not have to run all the wiring for a dedicated switch. Though I know you have switch blanks for days now…
  11. Mar 23, 2024 at 9:13 AM
    #1061
    RainMan_PNW
    Casey
    Clark County, WA
    Moar switches!
    Mater and TRDFerguson[QUOTED] like this.
  12. Mar 23, 2024 at 9:31 AM
    #1062
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    one thing that bothers me is they don’t say at what voltage the that is spec’d at…is that ~29 amps at 14.4 volts? At 13.8vdc current goes up to 30.5A..at 12 volts 35a…
  13. Mar 23, 2024 at 9:34 AM
    #1063
    RobertD
    Robert
    DFW, Texas
    Such a good movie!
    Mater[QUOTED] likes this.
  14. Mar 23, 2024 at 9:35 AM
    #1064
    coTony
    Tony
    Montrose, CO
    The SwitchPro will handle it, I had my 50" Onx and my 40" S8 on the switchpro as well as rock lights with no problems. I do not do the BD connectors and always use Deutsch connectors depending on the required current for the series for each connector. Not sure if the 9100 has changed since I used it (in the cabinet in the garage waiting to go on the wifes FunRunner) but mine had a 30A circuit that was required to short pins 9&10 coming from the 20 pin connector and it had 4 dedicated 35A circuits all on the 4 pin connector with one wire. Just make sure the numbers match the current and length requirements and you should be good
  15. Mar 23, 2024 at 9:38 AM
    #1065
    Mater
    Mater New Member
    Nick
    SD
    2016 MGM Platinum
    I recently got sad when I found out their wiring harnesses are CCA. Major kick to the nuts of my stripping side hustle
  16. Mar 23, 2024 at 9:49 AM
    #1066
    RainMan_PNW
    Casey
    Clark County, WA
    Pretty common for them to default that to 12V.
    maybe @Baja Designs can chime in
    :boink:
  17. Mar 23, 2024 at 10:08 AM
    #1067
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    my guess, it is at 13.8VDC
    coTony likes this.
  18. Apr 3, 2024 at 10:13 AM
    #1068
    WBW
    WBW Resident lurker
    Bruce
    Surface of the Sun - AZ
    2015 CM Tundra SR5 2WD
    What movie is this?
  19. Apr 3, 2024 at 12:10 PM
    #1069
    RobertD
    Robert
    DFW, Texas
    Down Periscope with Kelsey Grammar.
    Mater and Tripleconpanna like this.
  20. Apr 23, 2024 at 8:15 PM
    #1070
    RainMan_PNW
    Casey
    Clark County, WA
    If there is one thing I am absolutely incapable of, it is leaving well enough alone.
    Decided to go back to the "Poor Man's CAI" and will be listing the TRD version up for sale. I had 90% of the parts already for the "poor man" version, so I just went ahead and ordered the accordion piece (part PTR03-00140-AB) to finish it off and go back to the original air box lid. The stock air box lid outlet OD is about 1/4" smaller DIA than the TRD one, but it just meant a couple more turns on the worm clamp to snug it down. Everything else buttoned up just fine. At this point, the only things that aren't "official TRD CAI" parts are the PCV hose, the air box lid, and the air filter (since I'm running the aFe Dry filter).
    Other steps in this journey:
    Intake Flow Accelerator and Carbon Filter Delete
    aFe Magnum Flow Dry Air Filter
    Straight Intake Tube (and elbow fitting)
    Yes, I know my engine is dirty as f^(<. So is the whole damn truck. Get over it - I did...
  21. Apr 23, 2024 at 8:19 PM
    #1071
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    I find your lack of vehicular care offensive.
  22. Apr 23, 2024 at 8:19 PM
    #1072
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    That said, I’m not showing what mine looks like.
  23. Apr 23, 2024 at 8:20 PM
    #1073
    RainMan_PNW
    Casey
    Clark County, WA
    I feel like we are perhaps brothers from another mother...
  24. Apr 23, 2024 at 8:21 PM
    #1074
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    :fistbump:
    TaquitoBandito likes this.
  25. Apr 23, 2024 at 9:39 PM
    #1075
    Mater
    Mater New Member
    Nick
    SD
    2016 MGM Platinum
    Why the change of heart?
    TaquitoBandito and TRDFerguson like this.
  26. Apr 23, 2024 at 9:46 PM
    #1076
    RainMan_PNW
    Casey
    Clark County, WA
    Figure it's going to be easier to sell the TRD CAI kit with the air box lid eye candy.
    I might get around to doing up a stencil and painting mine or something some day (who am I kidding...probably not).
    The part I wanted was the smooth straight intake section with the matching TRD parts. The air box lid is just a lid...
  27. Apr 24, 2024 at 5:26 AM
    #1077
    1794TX
    Steven
    N.TX
    '20 1794
    3D print a relief of a snowboarder or yeti with Shasta in the background and weld it on.
  28. Apr 24, 2024 at 8:10 AM
    #1078
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    Quit pulling a @TRDFerguson , quit refactoring and drive the thing
    TaquitoBandito and Mater like this.
  29. Apr 24, 2024 at 8:25 AM
    #1079
    Mater
    Mater New Member
    Nick
    SD
    2016 MGM Platinum
    Nice gerund!
  30. Apr 24, 2024 at 9:57 AM
    #1080
    RainMan_PNW
    Casey
    Clark County, WA
    58 miles every day to work and back.
    #mallcrawler
