RainMan's 2021 Lunar Rock TRD Pro Build
Discussion in '2.5 Gen Builds (2014-2021)' started by RainMan_PNW, Oct 30, 2020.
  1. Feb 8, 2024 at 6:48 AM
    #991
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    Thought you may have been a zombie after sending it too hard on your jib stick. Lol
    Thanks chief…
  2. Feb 8, 2024 at 7:04 AM
    #992
    memario1214
    Colton
    Missoula, MT
    '21 Limited MGM CrewMax
    Same. And here’s to the top of the side plate at the rear should you need that as well.
  3. Feb 8, 2024 at 7:56 AM
    #993
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    look at how fancy you are. Lol
    thanks for the measurements…
    scheming recommencing
  4. Feb 8, 2024 at 7:59 AM
    #994
    memario1214
    Colton
    Missoula, MT
    I picked that up to make sure that I am consistent on testing equipment. It does come in handy pretty often though!
  5. Feb 8, 2024 at 10:49 AM
    #995
    RainMan_PNW
    RainMan_PNW [OP] "Oz" SSEM #82 RGBA #4 Unofficial Forum Treasurer Vendor?
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    But did you use a straight edge and make sure your measurement was perfectly square to the plane of the rack and the back of the truck? :D
    TaquitoBandito and BiggHertz like this.
  6. Feb 8, 2024 at 11:05 AM
    #996
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    Did you?
    TaquitoBandito likes this.
  7. Feb 8, 2024 at 11:26 AM
    #997
    RainMan_PNW
    Casey
    Clark County, WA
    Yes, I did.
    I used a 4-foot level across the cross bars and then measured up from the bed "lip" behind the cab directly to the underside of the level.
  8. Feb 8, 2024 at 11:32 AM
    #998
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    it’s like you’re an engineer or something like that….
  9. Feb 8, 2024 at 11:34 AM
    #999
    Mater
    Mater New Member
    Nick
    SD
    2016 MGM Platinum
    You have a method written up? Might need to run it by the jasonspec QA dept.
  10. Feb 8, 2024 at 11:40 AM
    #1000
    memario1214
    Colton
    Missoula, MT
    Are you insinuating that my method used may lead to unreliable results? :monocle:
  11. Feb 8, 2024 at 11:40 AM
    #1001
    RobertD
    Robert
    DFW, Texas
    :ohsnap:
    :popcorn:
    TaquitoBandito, GODZILLA and Mater like this.
  12. Feb 8, 2024 at 12:00 PM
    #1002
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    Depends, does this alter the “love” you show for the forum in the form of a discount?
    :rofl::rofl::rofl:
  13. Feb 8, 2024 at 12:07 PM
    #1003
    memario1214
    Colton
    Missoula, MT
    I can't believe you'd DARE to question my allegiances. :infantry::infantry::infantry:
    I'm never giving a flat discount sitewide though. Margins be too dumb. You just gotta ask, and I'll do you right.
  14. Feb 8, 2024 at 12:37 PM
    #1004
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
  15. Feb 8, 2024 at 12:40 PM
    #1005
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Someone say discounts?
  16. Feb 8, 2024 at 12:42 PM
    #1006
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    lol
  17. Feb 8, 2024 at 2:48 PM
    #1007
    RainMan_PNW
    Casey
    Clark County, WA
    Do I need to draw up a formal procedure, or can I just sketch it out in crayons?
    No such inferences have been rendered.
  18. Feb 8, 2024 at 2:51 PM
    #1008
    Mater
    Mater New Member
    Nick
    SD
    2016 MGM Platinum
    Formal procedure might be best..
    good book btw
  19. Feb 9, 2024 at 5:37 AM
    #1009
    SnrDisregardo
    SnrDisregardo New Member
    Wade
    IL
    2018 Platinum CrewMax 4x4
    TRD Sport Suspension, TRD Front & Rear Sway bar, TRD Pro Shift knob, Charcoal Filter Delete, aFe Pro Dry S w/SABM, LineX bed, Remote Start, OEM tonneau cover, DIY pop'n lock, DIY TRD cold air intake, TRD skid plate, DD SS3 amber fogs, HotShot Offroad Hot Tails, 2020 OE radio with tech12v amp and sub.
    IDK why, but I feel this title.
  20. Feb 13, 2024 at 11:08 PM
    #1010
    KevinK
    KevinK SGU - High Speed Overlander
    Back in Arizona. Again.
    SGU - Speed Glampers Uberfahrt
    Tundras to Sedona
    What happens in Sedona (Parker?) stays in Sedona (Parker?).
    Unless it was filmed. Then you ain't ever livin' that shit down.
  21. Feb 17, 2024 at 8:25 PM
    #1011
    RainMan_PNW
    Casey
    Clark County, WA
    Finally got around to finishing up my "poor man's CAI" using some of the TRD CAI parts.
    Specifically, these are the parts that I used:
    Install was pretty easy. Remove the existing intake assembly with big ass goiter on the side of it. Install the TRD elbow coupling onto the TRD intake tube, then install that onto the throttle body. Measure and mark the straight tube to length so it just fits to the shoulders on the air box and the intake tube, then cut to length and install it. The small vacuum line can easily be routed to the matching point on the air intake tube, but the existing vent/vacuum hose needs to be removed from the T fitting and replaced with a longer one cut out of the new universal one.
    Other write-ups use a 4” ID straight coupler section, but the 3.75” is a snug fit that is closer to how the factory parts fit.
    I need to get some miles on the truck now to see what, if any, changes I notice from it.
    Other parts in this "system"
    TRD Air Intake Accelerator
    aFe Magnum Flow DRY air filter
  22. Feb 17, 2024 at 8:27 PM
    #1012
    RobertD
    Robert
    DFW, Texas
    :benchpress:
  23. Feb 17, 2024 at 8:46 PM
    #1013
    RainMan_PNW
    Casey
    Clark County, WA
    Also finally got my Baja Designs Squadron SAE Fog Lights installed today.
    Since I've got the TRD Pro with the square bezels, I also had to pick up the round bezels for my truck:
    Installation is reasonably well documented in their installation instructions. What wasn't super clear was that the stainless bolt with rubber cap on it should be left loose until you have the fog light assembly in the bumper, and then you tighten it up and it will press against the inside of the bumper and stiffen things up.
    I did decide to cut off the connectors that BD installs on the lamps and install H11 male terminals/connectors directly onto the lights to avoid another "adapter harness." I found these on ebay and they worked just fine.
    I didn't get a picture of them lit up, so I'll need to update this post in the next day or so with a lit-up picture and one of the road with them on.
  24. Feb 17, 2024 at 8:46 PM
    #1014
    SAGE63
    San Diego County
    looks good.... what filter is in the filter box?
    bulldog93 likes this.
  25. Feb 17, 2024 at 8:52 PM
    #1015
    RainMan_PNW
    Casey
    Clark County, WA
    I'm running the aFe DRY filter. I had one in my 2008 and it worked great and was easy to take care of compared to the oiled ones.
  26. Feb 18, 2024 at 6:02 AM
    #1016
    Fotnot
    Fotnot SSEM #69; LRCS#1
    Andy
    SW Louisiana
    Swimmers gonna swim
    Hopefully my next thing to do on the Sequoia!
    Good work bud!
  27. Mar 5, 2024 at 3:56 PM
    #1017
    RainMan_PNW
    Casey
    Clark County, WA
    Just swapped my USB-C charging port out for "OPTION 2" including the correct OEM connector.
    I'm OK with the media/CarPlay port still being USB-A since I use wireless CarPlay anyway.IMG_1143.jpg
  28. Mar 5, 2024 at 4:02 PM
    #1018
    RainMan_PNW
    Casey
    Clark County, WA
    In working on my 3-Switch mount for the Platinum Trim, I decided to swap out my console parts with new ones and to switch over to the MESO chrome delete kit. I also hit the shifter trim area with some satin clearcoat while I had it removed.
  29. Mar 5, 2024 at 4:09 PM
    #1019
    RainMan_PNW
    Casey
    Clark County, WA
    And another quick interior upgrade - the Revesol Leather Steering Wheel.
    MAKE SURE TO DISCONNECT THE BATTERY FOR 5 MINUTES BEFORE TOUCHING THE AIRBAG CONNECTORS.
    Also be sure to mark the spline shaft with which way the wheel is oriented before you remove the old one (mine was "locked" slightly to the left from straight when I pulled the wheel). And make sure not to spin the clock spring around at all when removing the old wheel - there's only one way it will fit in the opening in the wheel, but if you end up turning it a rotation you can mess things up.
  30. Mar 5, 2024 at 4:11 PM
    #1020
    RobertD
    Robert
    DFW, Texas
    Sweet!!!
