RainMan's 2021 Lunar Rock TRD Pro Build
Discussion in '2.5 Gen Builds (2014-2021)' started by RainMan_PNW, Oct 30, 2020.
  1. May 2, 2023 at 9:21 PM
    #781
    RainMan_PNW
    RainMan_PNW [OP] "Oz" SSEM #82 RGBA #4 Unofficial Forum Treasurer Vendor?
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    The Rock Climbing Chalk Bag Water Bottle Holder Mod! Probably one of the easiest/fastest mods yet.
    While I was in PHX before T2S, I stopped at REI for some stuff and happened to walk past the rock climbing chalk bags.
    I remember seeing the mod on here on the forum at some point, and also knew I was gonna need a place for my ToyoMafia Nalgene, so I grabbed one. Of course, I didn’t pull out my tools the whole week at T2S, so I didn’t get to the mod itself till I got home.
    First step was to cut a short piece of dowel that I had laying around. It’s about 3.5” long, but I just eyeballed it based on holding the two tabs flat and eyeballing it. Then, I just wiggled two small zip ties through the weave of the eyelets and tightened them down.
    Give them a quick trim with a flush cutter and test fit with a nalgene.
    In the truck, open the console lid and pry up the shifter/cupholder bezel tray. Slip the dowel up into the crack and make sure it is up into the hollow cavity. I placed mine just forward of the yellow trim clip, and made sure the little tab that goes down into the side panel was lined up with the gap between the two loops.
    Press everything back down into place and revel in your new water bottle mount!
    (Seriously, including pictures, this whole mod took less time than it will take you to read it).
    ToyoMafia, SAGE63, WVI and 11 others like this.
  2. May 2, 2023 at 9:45 PM
    #782
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    Chalk bag mod rules.
    ToyoMafia, SAGE63, Fotnot and 4 others like this.
  3. May 2, 2023 at 9:54 PM
    #783
    RainMan_PNW
    Casey
    Clark County, WA
    So stupid simple and so functional.
    ToyoMafia, SAGE63, Fotnot and 2 others like this.
  4. May 2, 2023 at 10:01 PM
    #784
    alb1k
    Left Coast
    It's good
    Ya I couldn’t find my pics, it was a while ago. But yew!
  5. May 3, 2023 at 3:47 PM
    #785
    RainMan_PNW
    Casey
    Clark County, WA
    Installed an organizer tray thing to the right of the cup holders.
    I had to make a few trims to make it work with the Scosche charger unit, but overall I’m thinking this will be much more functional in that space.
    I didn’t anchor it down because to be able to remove that console piece you need to remove these first. The front one fits pretty snug and everything stays in place pretty well (so far).
  6. May 3, 2023 at 3:51 PM
    #786
    RainMan_PNW
    Casey
    Clark County, WA
    I also pulled my relocated bed rails out today and installed some of these “V” rings at two of the mounting points on each side. I hate the big goofy factory tie-down mounts, and the rails themselves were of compromised strength due to the TC-USA relocate kit, so I never really used them anyway.
    https://www.amazon.com/KAPMOZ-Anchors-Trailers-Pickups-Accessories/dp/B07Q2H38F6
    Also added a little bling to my sliders.
  7. Jun 3, 2023 at 11:09 AM
    #787
    RainMan_PNW
    Casey
    Clark County, WA
    When I put the Agency6 winch shackle on, the SSO fairlead license plate mount didn't extend far enough out to let the plate pivot down quite right. Then, after getting a bit throttle happy on one of the obstacles at Broken Arrow at T2S, I managed to bend the shit out of the license plate mount and form-fit my plate to the winch shackle (it looked way worse in person - it was pretty bent up)
    The powder coat on that mount was also pretty beat up and there was some rust showing up already, so I decided I wanted to find something else that would 1. clear the bigger shackle and 2. potentially be easily removed if I wanted to when going off road.
    That led me to browsing Agency6's website over Memorial Day weekend and discovering that they make a flip up license plate mount that bolts to two threaded holes they have designed in the top of their fairleads...and the mount is specifically sized to clear their winch shackles. With 15% off the whole site and finding a 1" fairlead in their "garage sale" section for a nice additional discount, I pulled the trigger.
    And it works GREAT.
    The license plate mount is aluminum, so no rust issues. It also has slots to give some adjustment (I have it adjusted all the way back against my bumper - if I had bought the 1.5" fairlead there would have been room to push it farther back). ALL of the hardware supplied is stainless steel (the fairlead bolts and the hardware for the mount). I did add a little nickel anti-seize to the fairlead mounting bolts. It is a bit of a gap, but that is because that shackle block is thick.
    I also like that it sits and a slightly downward angle (this is because my bumper is at that angle, so the fairlead is at that angle). It is basically 90* to the face of the bumper, and the license plate matches the face of the bumper.
    When flipped up, it provides WAY more room surrounding the fairlead for pulls that might be angling upward.
    (and yes, my truck needs a bath)
    Removal of the mount simply requires taking out the two 1/4-20 socket head screws from the top of the fairlead using a 5/32" hex wrench. At which point, I could mount a GoPro or something else there instead while off road.
  8. Jun 3, 2023 at 11:13 AM
    #788
    RainMan_PNW
    Casey
    Clark County, WA
    I also swapped out the two outer lenses on my S8 lightbar with amber driving combo ones (photo taken before the A6 fairlead install).
  9. Jun 11, 2023 at 12:19 PM
    #789
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Where did you mount this on a 1st gen?
    RainMan_PNW[OP] likes this.
  10. Jun 11, 2023 at 5:24 PM
    #790
    alb1k
    Left Coast
    It's good
    Same as everyone else, but I think DC has the advantage. I couldn't do it on a 4R and I'm guessing no on an 1st AC?
  11. Jun 11, 2023 at 5:36 PM
    #791
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    Aren’t center consoles the same for AC/DC? I’m a bench seater, so I don’t have fancy stuff to mount to
  12. Jun 11, 2023 at 5:39 PM
    #792
    alb1k
    Left Coast
    It's good
    maybe - now I have to find a picture of mine in case
  13. Jun 11, 2023 at 5:50 PM
    #793
    alb1k
    Left Coast
    It's good
  14. Jun 11, 2023 at 5:51 PM
    #794
    FrenchToasty
    Mo
    Bone stock
    Two?!
    Tripleconpanna and bulldog93 like this.
  15. Jun 11, 2023 at 5:51 PM
    #795
    bulldog93
    bulldog93 Usually tired...
    Jeff
    Santa Rosa, California
    2020 Super White CM Tundra TRD Pro
    One for each person.
  16. Jun 11, 2023 at 5:53 PM
    #796
    alb1k
    Left Coast
    It's good
    Yup. 2 for the win
    BiggHertz, Mater and bulldog93 like this.
  17. Jun 11, 2023 at 6:28 PM
    #797
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Same. :( I forgot some of the DC's have that center floor console.
  18. Jun 12, 2023 at 1:37 PM
    #798
    RainMan_PNW
    Casey
    Clark County, WA
    In case you’re wondering - you should be required for seat heaters. That’s what those two round blanks are for.
    My brother recently installed aftermarket seat heaters with the factory switches and wiring in his 05 DC SR5
    alb1k[QUOTED] and FrenchToasty like this.
  19. Jun 12, 2023 at 1:38 PM
    #799
    RainMan_PNW
    Casey
    Clark County, WA
    I need to add a second one. It’s a long reach to the passenger side
    TRDFerguson likes this.
  20. Jun 12, 2023 at 1:40 PM
    #800
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    Twss?
  21. Jul 19, 2023 at 9:25 PM
    #801
    RainMan_PNW
    Casey
    Clark County, WA
    Pulled the trigger on a Sherpa Big Bear roof rack today thanks to @memario1214 and HotShot Off Road. Note the wait begins for it to ship so I can install…
    SAGE63, BiggHertz, RobertD and 7 others like this.
  22. Jul 19, 2023 at 9:32 PM
    #802
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    That guy’s a freaking pusher.
    Mater, Blue Thunder and bulldog93 like this.
  23. Jul 19, 2023 at 9:35 PM
    #803
    RainMan_PNW
    Casey
    Clark County, WA
    Yeah. No Shit.
  24. Jul 19, 2023 at 9:36 PM
    #804
    RainMan_PNW
    Casey
    Clark County, WA
    Wish it would be hereI’m time for the “Work from home” week I’ve got coming up the first week of august, but don’t think that will happen…
  25. Jul 19, 2023 at 9:42 PM
    #805
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    You might be surprised. My shocks got here fast as hell. I was… shocked. Then I told myself I wasn’t going to install them until the weather cooled down.
  26. Jul 19, 2023 at 9:42 PM
    #806
    FrenchToasty
    Mo
    Bone stock
    Sounds like you rebounded well
  27. Jul 20, 2023 at 9:14 AM
    #807
    memario1214
    Colton
    Missoula, MT
    '21 Limited MGM CrewMax
    Hopefully we can shorten the timeline! I have already put the feelers out there...
    I believe I was contacted first!
  28. Jul 20, 2023 at 9:18 AM
    #808
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    :D
  29. Jul 20, 2023 at 12:05 PM
    #809
    RainMan_PNW
    Casey
    Clark County, WA
    Yeah… this time
    but that’s only because you gave me my first taste for so cheap
  30. Jul 20, 2023 at 12:10 PM
    #810
    Mater
    Mater New Member
    Nick
    SD
    2016 MGM Platinum
