RainMan's 2021 Lunar Rock TRD Pro Build
Discussion in '2.5 Gen Builds (2014-2021)' started by RainMan_PNW, Oct 30, 2020.
  1. Mar 26, 2023 at 10:02 AM
    #751
    Blue Thunder
    Washington
    I went 4k miles last time around and it was full. Trying 3,500 but might have to go back to 3k.
  2. Mar 26, 2023 at 10:30 AM
    #752
    RainMan_PNW
    RainMan_PNW [OP] "Oz" SSEM #82 RGBA #4 Unofficial Forum Treasurer Vendor?
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    You have the ABC one?
  3. Mar 26, 2023 at 10:45 AM
    #753
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Not really sure as it was in the truck from the previous owner but I believe so. I need to redo the whole thing. The wiring job is not great.
  4. Mar 26, 2023 at 2:57 PM
    #754
    RitcheyRch
    RitcheyRch New Member
    Richard
    Santa Clarita, CA
    TRD Lowered and Supercharged
  5. Mar 26, 2023 at 2:59 PM
    #755
    RainMan_PNW
    Casey
    Clark County, WA
    Just wrapped up the Brite Box Fogster installation.
    So, way back when I had my 2008, I had done the “Fast Eddy” mod to have my fog lights stay on even if the high beams were on (by default, they turn off - I assume because of laws regarding the maximum number of active forward facing lights in most states). When I got the 2021, doing a little research through the wiring diagram showed that on the 2018+ trucks, they revised how the fog lights were powered and the “Fast Eddy” would result in lights that were ALWAYS on anytime the switch was turned to on (including when the truck was off).
    Somewhere along the line (through the never ending help of this forum to give me things I want to do to my truck), I became aware of the Brite Box Fogster. This box takes the “hot” signal from the high beams and triggers the fog lights to stay lit. I had added to my list of things to do some day, and kept running into other things more important.
    Then, while helping @RegGex get the BSM installed in his truck, he offered to give me one that he had in his pile of parts that he decided he wasn’t going to use. Score (and THANKS man)!
    So, I needed to figure out where to mount it, because the directions are very clear about mounting it vertical with “UP” clearly defined. It also has to be near one headlight and close enough to hook power up to the battery or power distribution. The trick is, the natural place to put it (next to the battery on the fender wall) happens to be a VERY BUSY area in my truck already…
    Then I remembered I had an SDHQ Switch Pro mount that @Squatting Pigeon had gifted me a long time ago that I hadn’t used for my Switch Pro install. But I also had the issue of that area having all my winch power leads routed through it, so I needed to get creative.
    Since the Brite Box isn’t very big, I chopped down the SDHQ mount so that two bolt holes were still used but the main plate was shorter to provide clearance for the winch cables underneath it.
    Then I bolted the box to the plate using a couple button head cap screws and nylock nuts.
    And mounted it down in that small space in front of the battery - that was a bitch to reach and get those screws in place without pulling the battery or the front grill. I had also added a hole in the bottom of the plate to fish a zip tie through to help anchor the winch power lines as well.
    With the “easy part” out of the way, I needed to get to the headlight plug and the fog light plug. This involves fishing the connectors from the Brite Box down through this small gap under/behind the head light. Of course, it started raining like hell at about this point as well.
    Then pulling the lower fender liner and peeling back the upper fender liner to get up inside half-blind and find the wires and unplug the head light.
    With the two headlight leads from the box plugged into an adapter harness for the LED headlight, and then that adapter harness plugged into the factory plug and the back of the headlight, I then needed to plug the fog light into another set of connectors and tidy up the wiring.
    Then there is a power lead to route, which has an in-line 15A fuse in it. For now, I piggy-backed it onto the circuit for one of my air compressor pumps, but I’ll probably re-work it to connect into a dedicated spot on the other side of the distribution block at some point in the future (and get rid of the in-line fuse at that time).
    Finally - gave it a test:
    Low beams
    High beams
  6. Mar 27, 2023 at 8:57 PM
    #756
    RegGex
    RegGex I noticed you copied my beard
    Oregon
    2021 TRD Pro CM
    No sir, thank you! :fistbump:
  7. Apr 2, 2023 at 2:07 PM
    #757
    RainMan_PNW
    Casey
    Clark County, WA
    Got my air up/down setup finally put together. Sweet jesus that has been a process. I'm still not totally satisfied with it (the only way I think I'll be totally satisfied is to mount a tank under the truck and run dedicated lines to individual ports).
    Anyway, I drew from @TRDFerguson's setup here (link). However, there were a few things I wanted (or needed) to do differently.
    1. My compressor is mounted under my driver's seat. This is a great way to keep the compressor out of the elements of dust and dirt and mud under the hood, but it makes it less convenient for hanging a distribution manifold/gage when using the system. I plan on hanging the manifold from my front bumper cross bar when using it, so that means a longer whip to get from the compressor to the manifold.
    2. Jake used 3/8" for all of his hoses, but said it was bulky and heavy. Other "packaged kits" I've seen use 1/4" hoses so I went with those to the tires. I stuck with 3/8" hose for the whip from the compressor - hopefully to help with heat (more volume = less heat in the hose I hope).
    3. Most setups I've seen use a "Y" manifold and then have a T in the hose splitting a single hose out for the front and rear tires. I wanted a dedicated hose to each tire from the manifold...my thought process here was that if I only needed to do one tire I would only need to drag out one hose.
    Now, that last point may be flawed logic as I've been putting this thing together. It most certainly has meant that I needed to buy more hose (because from the manifold to the front tire, I basically have to have that amount of hose twice). This adds up to more bulk to the whole setup - likely offsetting any weight and bulk savings I gained by using 1/4" hose. I may revisit this at some point, but I'm also reconsidering the setup of the hoses themselves and may redo more of the configuration in time. One thing that I think might be beneficial is to actually set up the ends at the tires to have female quick connect chucks, and then put the tire fill valves on male quick connects. This would add a little bulk, but would also provide more flexibility with the system - I could chain two hoses together if I was needing to reach further to help assist someone else with filling up a tire perhaps. We'll see...for now, this at least gives me the ability to air up or down all four tires at once, or just two tires at once, or just one, as I see fit.
    The final parts list (after a few rounds of failed attempts at trying a few different scamazon parts to get the right combo).
      • There are four FPT x male quick connect ends that go on each of the four tire hoses.
      • On my "whip" I used the FPTxFTP coupler with one of the MPT x male quick connect ends to connect to the compressor, and then used one of the FPT x female quick connect ends for the end connecting to the manifold.
      • On the manifold (after removing one of the female quick connects), I threaded in the MPT x FPT ball valve into the manifold and then one of the MPT x male quick connects into the valve.
      • I cut two pieces 10 feet long each that have the factory ends on them, and put the male quick connects onto those factory ends (they are stiffer than the "pro" and field repair ends) and then used field repair "pro" ends on the other end with the air chucks. These two 10 footers reach the front tires from the manifold at the middle of the front bumper (with a little slack).
      • I cut a single 25 foot piece out of the remaining hose and put two field repair "pro" ends on this with a male quick connect on one end and an air chuck on the other. This will reach ONE of the rear tires.
    One reason that I used non-pro ends on the two shorter hoses is that I can easily identify them by hose size and end type. If I grab a 1/4” hose male quick connect with a “pro” end I know it’s a 25’ hose and if it’s a non-pro end then it’s a shorter one.
    I still need to do a test run on this on the truck, but I've pressure tested everything together and it's working inside the garage.
    Making up the hose ends
    Finished bundle
    I got to test this setup out when I was at T2S and it worked great! It is a lot of hoses though…so I’m still interested and looking at building a dedicated OBA system with air couplings closer to the individual wheels.
    ToyoMafia, bulldog93, Fotnot and 7 others like this.
  8. Apr 2, 2023 at 2:20 PM
    #758
    TaquitoBandito
    Joel (AKA Bif)
    Sounds like a lot of work to keep your inflatable doll aired up, but who am I to judge?
    (short video from my wedding below)
  9. Apr 2, 2023 at 2:22 PM
    #759
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    Looks good!
    You’ll see lots of other setups in Sedona to give you further ideas. I used mine this morning before I hit the highway.
  10. Apr 2, 2023 at 2:56 PM
    #760
    RainMan_PNW
    Casey
    Clark County, WA
    I’m almost afraid of the wish list I’m going to have when I get back from Sedona
    SAGE63, ToyoMafia, reywcms and 5 others like this.
  11. Apr 2, 2023 at 2:58 PM
    #761
    FrenchToasty
    Mo
    Bone stock
    Hahah you need some mod blinders! You’ll definitely get excited for the raffle! There’s always a bunch of cool stuff!
  12. Apr 2, 2023 at 2:59 PM
    #762
    RainMan_PNW
    Casey
    Clark County, WA
    Dropped a hundred on tickets already…
  13. Apr 2, 2023 at 3:01 PM
    #763
    FrenchToasty
    Mo
    Bone stock
    Hahahah more can be purchased on site.
    @Cruzer looked like a kid that just won big at chucky cheese with all the tickets in his pockets, don’t try to win what he’s throwing in for……. That’s the only secret
  14. Apr 4, 2023 at 7:42 AM
    #764
    IMXPLRN
    IMXPLRN New Member
    Rescue, CA
    2020 Tundra Limited on 35's
    I've been very interested in the Brite Box. One question, can you have your fogs on with just your DRL's?
  15. Apr 4, 2023 at 7:53 AM
    #765
    mustangr2
    mustangr2 New Member
    nice build!
  16. Apr 5, 2023 at 8:34 PM
    #766
    RainMan_PNW
    Casey
    Clark County, WA
    Sorry for the slow reply. I will need to double check...
    IMXPLRN[QUOTED] likes this.
  17. Apr 6, 2023 at 7:49 AM
    #767
    RainMan_PNW
    Casey
    Clark County, WA
    The 2018 and newer trucks will run the foglight with just DRL’s on (this was a change in the wiring in 2018).
    Just confirmed this morning that this is still the case with the BriteBox Fogster installed.
  18. Apr 6, 2023 at 8:47 AM
    #768
    Fotnot
    Fotnot SSEM #69; LRCS#1
    Andy
    SW Louisiana
    Swimmers gonna swim
    i loved (and was pleasantly surprised) that my 21 came with the option to run just fogs without needing any modifications.
  19. Apr 8, 2023 at 7:22 AM
    #769
    Terndrerrr
    Terndrerrr 924000 miles to go
    Music City
    6UR-FE
    Must be a sequoia thing? Mine shut off if I turn the headlights off on my 21.
    Fotnot[QUOTED] likes this.
  20. Apr 8, 2023 at 7:27 AM
    #770
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    Did you have factory halogen or LED headlights? My fogs stay on with the parking lights, which I think is what the point of the convo is - and my truck came with LED btw.
    RainMan_PNW[OP] and Fotnot like this.
  21. Apr 8, 2023 at 8:06 AM
    #771
    RainMan_PNW
    Casey
    Clark County, WA
    Headlights fully off (switch not in off position) - yes, fogs go off too. But the parking/DRL lights on will still leave the fogs on. Basically any switch position except OFF, or AUTO when the headlights themselves are off, and your fogs should stay on.
  22. Apr 8, 2023 at 8:34 AM
    #772
    Terndrerrr
    Music City
    6UR-FE
    LEDs. I took @Fotnot’s message to mean he can do fogs only.
    DRLs + fogs is cool, too :headbang:
    Fotnot, Mater and TRDFerguson[QUOTED] like this.
  23. Apr 8, 2023 at 10:04 AM
    #773
    Fotnot
    Andy
    SW Louisiana
    Swimmers gonna swim
    This is with "fogs only"
    ToyoMafia, bulldog93 and Blue Thunder like this.
  24. Apr 12, 2023 at 1:10 PM
    #774
    RainMan_PNW
    Casey
    Clark County, WA
    I've been working on a clean and splice/tap-less version of the DIY Automatic Traction Control Disable setup originally posted by @TRDFerguson and I'm down to just needing to make the final connection to my switch.
    To make the connections to the VSC Off switch clean, I found the needed Sumitomo TS connectors (male and female) to mate up with the factory VSC connector and ordered them. I only needed one of each, but a 5-pack leaves me some room for other possibilities (this connector shape is used a few other places in the instrument panel area).
    Next up was finding a timer/relay that could be set up to do a ground sink instead of power signal when it was activated (this eliminates needing a separate relay for the setup). I came across this WiFi-programmed one and ordered it up.
    My switch is actually a custom dual switch from CH4x4 that came about as part of a mis-hap when I was putting together my original winch power setup (which needed a momentary ON and momentary OFF switch). The first order they sent me was latching. As it turned out, when I re-did my winch power to use a constant power magnetic switch, the latching dual switch was perfect. And by dumb luck, the icon and lettering I chose for the lower half "works" for setting it up as a Traction Control disable switch.
    When the headlights are on, the entire switch is illuminated blue. When one of the two buttons is "on" that part of the switch illuminates green.
    I programmed the timer using the instructions from their website, and then saved out a "BIN" file of that configuration to simplify doing it again in the future (attached zip file).
    Next up is the break-out harness. I have attached a wiring diagram for doing this with a standard AOB or CH4x4 switch and using the VSC break-out harness to also provide illumination. I didn't need that (my double-switch already has illumination from my previous mod of making an illumination distribution harness), so I only tapped off the CSW/VSC and GND circuits in my break-out harness.
    The red wire here will connect to the output on my "TEQ OFF" switch.
    FULL wiring diagram (again - my own harness doesn't have the two illumination wires in it).
    Note for others - different years of trucks have different wire colors. The 2007 also has a different connector and different pin numbers.
    Now, pull the lower trim piece where the VSC OFF switch lives and plug the break-out harness in line. I also pulled the AC controls so I could fish the red wire through to the area by my start button, brake controller, and TEQ OFF button.
    Then I soldered the red wire to the output from my switch, and tested things out.
    With the switch pressed in before starting the truck, as soon as I start the truck it starts cycling the VSC function - first to Auto LSD on the left gage and the collision sensors and VSC OFF symbol on the right gage. Then they all go off for a few seconds and next TRAC OFF shows on the left gage while the other two show on the right gage.
    If I press the VSC OFF button, the system resets.
    I did notice that if I then turn off the TEQ OFF switch and try turning it back on, I get some mixed results for the system fully returning to TRAC OFF. It’s like the timer doesn’t go the full cycle for the first steps except from a cold start. I may have fiddle a bit more with the timer steps/settings - maybe introduce an “off” count before the first “on” count. I’ll just have to fish out the timer and expose the white wire again… :censored:
  25. Apr 12, 2023 at 2:27 PM
    #775
    RainMan_PNW
    Casey
    Clark County, WA
    Ouch!
    There's a good chance that you'll have to replace the outer sub-frame piece under the plastic in addition to the plastic piece.
    Terndrerrr[QUOTED] likes this.
  26. Apr 12, 2023 at 3:31 PM
    #776
    RainMan_PNW
    Casey
    Clark County, WA
    It's all good!
  27. Apr 22, 2023 at 4:45 PM
    #777
    prozac
    prozac New Member
    Zach
    Southern California
    2015 Inferno Orange Tundra TRD Pro
    see my build thread - https://www.tundras.com/threads/prozacs-2015-inferno-orange-trd-pro-build.122370/
    Dumb questions Casey, but did the sensors snap fine into the 7/8 hole?
    I recently ordered some new painted bumper caps from a vendor I'll leave unnamed until they have time to make it right and they sent me one with a hole for the sensor and one without it (of course I did not notice this until they were both installed :annoyed:)
    I just wanted them without sensor holes at all but as luck would have it the one they sent with the sensor hole was the one that needed to be replaced for damage.
    I bought a sensor on Amazon to snap in there and it looks better but I think it'll drive me nuts only having one sensor, then once I have them I almost feel obligated to go ahead and install the actual parking assist too...
  28. Apr 23, 2023 at 12:35 AM
    #778
    RainMan_PNW
    Casey
    Clark County, WA
    Yes
    They snapped into the 7/8 hole perfectly
    bulldog93 likes this.
  29. May 2, 2023 at 9:05 PM
    #779
    RainMan_PNW
    Casey
    Clark County, WA
    I can confirm, the new Voodoo VRS 22” Overland Rack will work with the Truck Covers USA retractable tonneau cover. I picked up the 22” one and got it just the week before I left for T2S, so it was a bit of a treat getting it installed after work during a week where we had rain, snow, sleet, hail, lightning, wind…
    First step was to pull the TCUSA cover off and get the VRS rails mounted to the bed sides. Because the TCUSA cover requires relocating the factory utility rails down, you use the Voodoo no-drill clamps to anchor to the truck bed sides.
    Hold these bolts down a little from the top of the slotted channel to allow clearance for the tonneau cover rails. In retrospect, I would recommend getting these rails temporary installed with clamps just snug, then proceed to reinstall the roll-up canister and side rails (again, just getting things temp snugged up). THEN, final clamp the VRS rails to ensure the nuts clear the tonneau rails and finally shim and anchor the tonneau rails.
    You can see here where the VRS anchor nut was too high the first time and rubbed on the tonneau rail (actually kept the tonneau rail from fully seating on the other side). Then the position had to move when I lowered the nut because the carriage bolt head was hitting the rail drop bracket bolt. So there is a little tweaking you need to do to be sure everything is fitting right.
    Also note that the middle anchor point is very close to one of the rail relocation bracket bolts - you may have to adjust your fore/aft spacing of the VRS rail to ensure the two don’t interfere with each other.
    At the end of day 1, with hail, snow, and rain, I had the rails mounted and the TCUSA cover anchored back down. A nice thing about the VRS rails is that they simplify the shimming of the TCUSA rails, and seem the lock it down more positively than the bedsides by themselves.
    Next up was assembling all of the rail components. The top angle pieces get assembled to the uprights using stainless carriage bolts with stainless nylok nuts. Any time I’m using stainless hardware, I dab a little nickel anti-seize on the threads to reduce the thread of galling.
    With the rack pieces all assembled on night two (the one nice weather night that week), the NEXT night was final assembly…in the dark while it was raining, snowing, hailing, and lightning. Needless to say, I did not get any pictures during the install. I did get an installed picture the next morning though.
    Some observations/comments on the assembly of the uprights and cross-bars:
    The uprights have slots cut in them that key into slots in the rail - sort of how the dividers in a beer box slip together. This makes the whole assembly very solid when just the upright is bolted up, but it does require a little bit of “tilt and twist” to get things together. At the cab uprights, the TCUSA canister cover doesn’t provide enough room for this, so you have to remove the canister cover to install the two front uprights, and then slide the canister cover into place under the uprights (they are notched and provide ample clearance once in place).
    I used a quick-acting “F” clamp to hold the extruded cross bars flush with the upright brackets while adjusting the spacing and tightening the bolts. This allowed the uprights to sit even and square to the cross bars. It took a few tries to get everything lined up, but the process is pretty straight forward.
    With the rack all tightened up, it is ROCK SOLID. I can jump up and down hanging on it and the whole truck moves. There’s no movement in the rack. I also ran Broken Arrow at T2S and after getting back to camp it had no loose parts or wobble.
    With the VRS rails in place, the Yakima tracks on the TCUSA rails (if you have them) are not really useable. Both the Rhino rack uprights that I have and the Yakima “control towers” won’t have enough clearance to open/close their locking mechanism.
    The 22” height rack sits just right that anything mounted on top of it will clear the shark fin on the 2020/2021 trucks.
  30. May 2, 2023 at 9:10 PM
    #780
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    That rack looks really good in person and is built!
