RainMan's 2021 Lunar Rock TRD Pro Build
Discussion in '2.5 Gen Builds (2014-2021)' started by RainMan_PNW, Oct 30, 2020.
  1. Oct 18, 2022 at 6:04 PM
    #661
    RainMan_PNW
    RainMan_PNW [OP] "Oz" SSEM #82 RGBA #4 Unofficial Forum Treasurer Vendor?
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    I could not find one that would plug into the factory plug.
    In the second part of this install post I detailed how I did it - I bought some matching make/female connectors that use the factory terminal pins, and I swapped out the factory connectors.
    If I EVER (doubtful, since all my factory bumper parts are now recycled) want to revert back I can determinate and switch back over to the original connectors.
  2. Oct 18, 2022 at 6:13 PM
    #662
    2point5seconds
    2point5seconds Wish I didn't have so much money
    Sensei
    Nor Cal
    2019 Tundra SR5 TRD 4WD Double Cab
    Icon Stage 9 lift, 700 pound rated Eibach spring, Sumo Springs (rear), RCI engine skid plate. RCI Lower Control Arm Skid Plates, RCI Transmission Skid Plate, RCI Cat Guards, Rago dash plate. RAM phone holder. Bed rails. Tint. 17x8 Icon Rebound wheels. 315/70/r17 Falken Wildpeaks. AAC Trigger 6 Shooter, midland MTX-115 radio, Chassis Unlimited front bumper, OLB Bar light and ditch lights, Baja Fog lights, Smittybilt winch, Husky floor liners, bed rail, Cali Raised Bed Stiffeners, driver's side grab handle, Wheeler's Offroad front bump stops, Decked Tool Box
    Great idea. I just wired my cubed lights with the AAC trigger connectors which use similar male female connectors. That way if I have to replace my lights, I just unplug them instead of cutting wire and rewire. Thank you!
  3. Oct 23, 2022 at 4:55 PM
    #663
    RainMan_PNW
    Casey
    Clark County, WA
  4. Oct 23, 2022 at 5:17 PM
    #664
    RainMan_PNW
    Casey
    Clark County, WA
    Update on the rear bumper - did a little hardware swapping (end of this post)
    bulldog93 and T-Rex266 like this.
  5. Oct 23, 2022 at 5:21 PM
    #665
    memario1214
    Colton
    Missoula, MT
    '21 Limited MGM CrewMax
    Do you have any contact on the bottom of your tailgate?
  6. Oct 23, 2022 at 5:26 PM
    #666
    RainMan_PNW
    Casey
    Clark County, WA
    How so?
    I haven’t noticed any, but haven’t been looking for any either.
  7. Oct 23, 2022 at 5:47 PM
    #667
    memario1214
    Colton
    Missoula, MT
    TRDFerguson, bulldog93 and T-Rex266 like this.
  8. Oct 23, 2022 at 7:02 PM
    #668
    RainMan_PNW
    Casey
    Clark County, WA
    Tripleconpanna, reywcms and T-Rex266 like this.
  9. Oct 23, 2022 at 7:05 PM
    #669
  10. Oct 24, 2022 at 11:04 AM
    #670
    needsmoresalt
    needsmoresalt New Member
    Patrick
    2020 Tundra TRD Pro
    A few
    Thanks, I ordered the fronts and dome light, and wouldn't you know it, the dome light only works for red on one side. So I put in a support request, and after a few questions, they just ghosted me on any further support and replacement. Not at all what I would have expected.
  11. Oct 24, 2022 at 6:19 PM
    #671
    WillTunBlack20
    WillTunBlack20 New Member
    William
    Houston, Tx.
    2020 Tundra TRD PRO Midnight Black
    Grille Lights, Bumper Lights, Front Facing Camera, Interior Upgrade, Leer Topper
    sudobash, SAGE63, Kenreau and 2 others like this.
  12. Oct 24, 2022 at 8:29 PM
    #672
    RainMan_PNW
    Casey
    Clark County, WA
    That sucks. Not sure if anyone out here has personal relationship with MESO or not…
  13. Oct 24, 2022 at 8:38 PM
    #673
    RobertD
    Robert
    DFW, Texas
    @Squatting Pigeon might be able to help
  14. Nov 3, 2022 at 1:06 PM
    #674
    Kenreau
    Kenreau New Member
    Kenny
    Peoples Republic of Portlandia
    2021 Tundra TRD Pro
    Just getting started (Nov 2022)
    I am very interested in doing this as well. Are you also upgrading the speakers?
    Thx
    Kenreau
  15. Nov 3, 2022 at 1:16 PM
    #675
    WillTunBlack20
    William
    Houston, Tx.
    That was the plan, and @james@tech12volts, suggested listening to the factory speakers, with just the amp upgrade.
    Tripleconpanna likes this.
  16. Nov 3, 2022 at 2:16 PM
    #676
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    At a minimum add the single sub/custom box from @james@tech12volts ... you won't be disappointed!!
    bulldog93 likes this.
  17. Nov 3, 2022 at 2:27 PM
    #677
    WillTunBlack20
    William
    Houston, Tx.
    I have the JL Audio Stealth box, the subwoofer had to be replaced.
  18. Nov 3, 2022 at 5:00 PM
    #678
    Tripleconpanna
    Sweet... the amp will push that much harder
  19. Nov 3, 2022 at 5:03 PM
    #679
    RainMan_PNW
    Casey
    Clark County, WA
    All stock speakers for me for now. I may upgrade the sub at some point, but it’s not a priority for me at the moment
    WillTunBlack20 likes this.
  20. Nov 4, 2022 at 5:00 PM
    #680
    Kenreau
    Kenreau New Member
    Kenny
    2021 Tundra TRD Pro
    Regarding the stock oem speaker locations in front, I see a mid-bass and tweeter in each door and what appears to be three speakers across the dash (left center and right). I've played around with the fader and balance and sound adjustments and I only hear music coming from the dash. I don't hear the door speakers at all. My usual speaker tuning is with 75% front stage and just barely perceptible rear speakers.
    Does the tech12volts DSP JBL replacement amp use all the oem speaker locations/channels?
    Thx
    Kenreau
  21. Nov 4, 2022 at 5:02 PM
    #681
    Tripleconpanna
    yes
  22. Nov 5, 2022 at 10:51 AM
    #682
    Kenreau
    Kenreau New Member
    Kenny
    2021 Tundra TRD Pro
    Did you replace your speakers?
    I just sold off a 2020 4Runner TRD Pro and had installed AudioFrog speakers, but didn't upgrade the amp. Reportedly the AudioFrog speakers are super efficient and can be driven by the cheesy oem JBL amp module. They did make a nice improvement, but I also went through the doors and cargo area panels and floor with second skin sound deadening materials. That helped bring down the highway road noise around -3dB. I was really disappointed in how thin the door, quarter panels and rear hatch sheetmetal panels are on the 4Runner. That plus the droning TRD exhaust was...exhausting.
    Intending to do a similar sound deadening treatment to my Tundra once the warm weather returns in the spring.
  23. Nov 5, 2022 at 11:28 AM
    #683
    Tripleconpanna
    I just replaced the amp, sub and sub box; right now still on factory speakers. I think one of the biggest issues w/the stock JBL system is the way the system processes sound signal. The new JBL/DSP does a much better job at sending the proper frequency ranges where they belong and at appropriate levels.
    So, yes, I'd assume just replacing the speakers would help, but I think you're ahead of the game to start at the heart of the system (amp/DSP) and then work from there.
    It is my plan up upgrade door and dash speakers at a later date when I'm more inclined to popping off door panels and such.
  24. Nov 5, 2022 at 11:37 AM
    #684
    RainMan_PNW
    Casey
    Clark County, WA
    Couldn’t agree more.
    I might add sound deadening art the point I decide to go in and replace speakers. For now, I need to just use it as a truck for a while.
  25. Nov 6, 2022 at 11:27 PM
    #685
    2point5seconds
    Sensei
    Nor Cal
    Finally got around to installing my rear bumper. I took your advice and order connectors from the website.
    I have another question though. When I tested the factory wires for the license plate lights the green didn't come back with a current. The white/black wire did. So I figured that was positive. So I hooked the red wire to the factory white/black. Then the black wire to the factory green. Lights didn't work. After a couple of hours of testing I just swapped the wires. The lights worked. Green to red and white/black to black. Is that how you wired yours?
    I saw a video where some guy wired his this way too. I would think positive to positive and negative to negetive. Positive should come back with a current on the meter. Or am I wrong?
  26. Nov 10, 2022 at 4:00 PM
    #686
    colenation
    colenation What’s next?
    Cole
    Alabama
    2018 Tundra TRD Sport
    Readylift 4”F/2”R SST LIFT Kit Fuel Sledge D595 (20x9 +20) Thunderer Ranger A/TR (35x12.5R20) Havoc HS2 black hoop steps
    Can you tell me what size pin will work for the shackle mounts? I wanted to order some shackles but I see there are 1/2” and 7/8” pins.
    should be getting my bumper in a few weeks.
  27. Nov 13, 2022 at 11:22 AM
    #687
    RainMan_PNW
    Casey
    Clark County, WA
    The wiring diagram for those lights clearly shows green is powered and W/B is ground. Not sure how you are testing, but you should get +12V if you use a multimeter between the green wire and a frame ground if you have the headlights on. It might be possible you were getting current on the ground because you were reading current from another wire that is in the same ground circuit? I didn't bother testing the factory wiring because I've got faith in the EWDs being correct. I just put the terminals into my connector in the same configuration as it was from the factory (pins 1 and 2) and then hooked up the light for the one side.
    The light itself, it really depends on what they are buying/shipping to customers. Most LEDs have polarity, so you just have to get the power running in the right direction. My license plate light from CBI came with a white and a black wire and I don't remember if they even stated in the instructions which was which - I just tested it before putting the terminal pins into the connector and made sure to plug them in the way I needed to for it to work. Sounds like yours came with a red and black wire, which would (normally) align with RED=(+) and BLACK=(-).
  28. Nov 13, 2022 at 11:29 AM
    #688
    TaquitoBandito
    Joel (AKA Bif)
    I have no idea what you are talking about but it sounds smart. I want to look smart so I liked it. :)
    Kung, Tripleconpanna, Mater and 3 others like this.
  29. Nov 13, 2022 at 11:29 AM
    #689
    RainMan_PNW
    Casey
    Clark County, WA
    The holes in the SSO front bumper and the CBI rear bumper are both 15/16" DIA inside.
    a 7/8" pin is standard for a 3/4" bow shackle, and they make the holes for that size shackle.
    bulldog93 and colenation[QUOTED] like this.
  30. Nov 13, 2022 at 3:52 PM
    #690
    RainMan_PNW
    Casey
    Clark County, WA
    Back when I bought my SDHQ Billet Battery Terminal Kit, it didn't come with the Terminal Protection Kit. So, while recently on a trip to AZ, I stopped into SDHQ and picked one up. And I got it installed today just to tidy things up a little more.
    (and after posting the picture, realized I had left my winch negative cable disconnected, so I just went and put that back on as well).
