RainMan Fabrications - Switch Panels and More
Discussion in '2.5 Gen Tundra Parts Marketplace (2014-2021)' started by RainMan_PNW, Dec 23, 2023.
  1. Dec 30, 2024 at 10:02 AM
    #301
    TundyManFL
    TundyManFL New Member
    2021 MGM TRD Pro CrewMax
    bulldog93 likes this.
  2. Jan 29, 2025 at 4:39 PM
    #302
    94Toy22re
    94Toy22re New Member
    I placed an order and sent money through Paypal last night!
    RainMan_PNW[OP] likes this.
  3. Jan 29, 2025 at 4:42 PM
    #303
    RainMan_PNW
    RainMan_PNW [OP] "Oz" SSEM #82 RGBA #4 Unofficial Forum Treasurer Vendor?
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    I’ve got a few orders that came in this week. The order tracking link in the first post is updated with status (payment confirmed on all those orders).
    I’m currently out of town for work but will be getting these orders printed on Friday and in the mail Saturday after I get back.
    thanks for the support!
  4. Jan 29, 2025 at 4:52 PM
    #304
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    Sounds like you need to hire an assistant
    :wave:
  5. Feb 2, 2025 at 1:03 PM
    #305
    RainMan_PNW
    Casey
    Clark County, WA
    How long will it take you to build my empire up to that of your current paycheck provider?
  6. Mar 16, 2025 at 6:08 AM
    #306
    bigmace
    bigmace New Member
    Oregon
    2021 Silver Tundra Limited / 2019 Black Sequoia SR5
    Just wanted to say thanks! Ordered late last week and arrived in like 2 days (helps that I am only 100 miles away). Now I have a spot to mount my anytime camera switch and lightbar switch!
  7. Mar 16, 2025 at 9:02 PM
    #307
    Randydw
    Randydw New Member
    Randy
    Ozark,mo
    2021 platinum crew cab
    Ordered me one,thanks rainman appreciate it. It just makes sense to have some controls at ur fingertips. Definitely doing rear window, and most likely tow haul. So when I’m up against a dodge ram they don’t see me reaching up to push a button before I step on it. Also think I’ll use rear window more.
  8. Apr 14, 2025 at 5:57 AM
    #308
    DiamondW
    DiamondW Stockblocker
    Kent
    CenTex
    ‘17 CM
    @RainMan_PNW do you think you could print a panel for the switch pro 12 (or 6 but 12 would be better) footprint for small Toyota switches? My idea is to use the SDHQ overhead panel but modified to look more oem for heated seat switches and whatever else I come up with. Thanks.
    edit- adding a drawing of where my mind went for the class to discuss. My thought is to cut the red line leaving a small lip, then hopefully slide a flush fit panel with as many small switches as possible into the recessed area that is secured with hidden screws from the backside.
    Tripleconpanna likes this.
  9. Apr 14, 2025 at 2:01 PM
    #309
    RainMan_PNW
    Casey
    Clark County, WA
    You will find that there is not enough "depth" to the overhead area to fit the OEM (or OEM-style) switches. You are looking at 2.5-3 inches of total depth from face of switch to the back of the wiring connector without figuring on some non-kinking bend in the actual wires. Even cutting a hole in the headliner and passing the switches through it you'd be looking at hitting the cab sheet metal before you had room to actually fit a standard switch.
  10. Apr 14, 2025 at 2:04 PM
    #310
    DiamondW
    Kent
    CenTex
    ‘17 CM
    Damn, I was hoping the drop in the SDHQ piece would provide enough room. I appreciate the feedback though.
  11. Apr 14, 2025 at 2:10 PM
    #311
    RainMan_PNW
    Casey
    Clark County, WA
    Yeah - I looked at it briefly early on and it's just not a good spot for something that doesn't hideously drop down below the main compartment.
  12. Apr 14, 2025 at 2:11 PM
    #312
    DiamondW
    Kent
    CenTex
    ‘17 CM
    With a bench seat and all my options used I’m thinking hideously dropped down may not be so bad:rofl:
    I had the Meso one for the sunglass holder in my Tacoma and loved it, if he ever makes them again a may order one and plastic weld and body filler it to work.
  13. May 7, 2025 at 9:03 PM
    #313
    RainMan_PNW
    Casey
    Clark County, WA
    UPDATE:
    Thanks to @BillyB sending over a sample to test, I now have a version of the RMF-001 that holds the sPOD Mini6 controller.
    I need to get it listed in the ordering form (kicking around a few tweaks to that form to simplify/clarify some things). In the meantime, if you are wanting one of these please reach out via PM and we can get you set up.
    Rc23, 15SR5CM, 1794TX and 8 others like this.
  14. May 15, 2025 at 5:28 PM
    #314
    BillyB
    BillyB New Member
    Billy
    AZ
    2021 SR5 TRD Sport 4x4
    Just checked the mail today and it came. It looks great! Thanks Casey! Maybe I'll even have it installed by next T2S!
  15. May 25, 2025 at 8:40 AM
    #315
    quintalope
    quintalope Lurkin…
    Quinn
    SEPA
    2019 Platinum
    Method 316s w/ BFG KO3; Full Chrome Delete; Retrax Tonneau Cover; TRD Skid Plate; TRD Dual Exhaust; TRD Rear Sway Bar; TRD Pro Grill; Interior LED Swap; Color-matched Door Handles & Mirrors; Rago Dash Mount; Hood Bulge Lights
    Order (finally) placed. Cheers man!
  16. May 29, 2025 at 1:47 PM
    #316
    Rc23
    Rc23 New Member
    Ross
    Chesapeake
    '16 Super White CrewMax
    Looks awesome! I used the blem one I picked up from you to mount my auxbeam 6 panel. Really just a filler but it's perfect. Will post a pic later tonight
  17. May 29, 2025 at 6:16 PM
    #317
    RainMan_PNW
    Casey
    Clark County, WA
    Kicking around putting these up… a bit niche, but someone might be looking for something like it.
    It’s an extended baseplate for the original P365 10-rd magazines so they will fit in the P365X grip. No added capacity, and I haven’t done any hard use testing, but to at least have them useable for range or other reasons…
  18. Jul 23, 2025 at 10:10 AM
    #318
    subspd
    subspd New Member
    Seth
    SW Florida
    2015 Tundra Platinum 4x4
    Magnuson Supercharger - TRD Exhaust - TRD BBK
    Any design to mount Auxbeam controller in the overhead area? Sunglass holder replacement or the envelope holder area?
  19. Jul 23, 2025 at 7:44 PM
    #319
    RainMan_PNW
    Casey
    Clark County, WA
    I use my sunglasses holder, and have the moonroof switches plus the SOS button so hadn’t really looked at making anything for up there.
    I used a pretty simple mount for my SwitchPro, but it’s not my design so I’m not going to be selling it.
    subspd[QUOTED] likes this.
  20. Jul 26, 2025 at 4:15 PM
    #320
    RainMan_PNW
    Casey
    Clark County, WA
    Moving the order form over to Google Forms, which isn't as user friendly but also doesn't cost anything.
    The link in the first post is the new form. If you have issues for any reason, please reach out to me in a PM.
  21. Jul 31, 2025 at 2:33 PM
    #321
    Lord_Sawzall
    Lord_Sawzall New Member
    Ryan
    Maine
    2019 Gray Offroad TRD
  22. Jul 31, 2025 at 10:30 PM
    #322
    joseph_womack
    joseph_womack @ 4x4bound
    Joe
    Louisiana
    2007 RCLB, 4WD, 4.7L V8
    3/1 Lift, 35s, Front Bumper, etc etc
    Would you happen to have a 3D print for an auxbeam 8 gang switch panel instead of the spod?
  23. Aug 2, 2025 at 9:18 AM
    #323
    RainMan_PNW
    Casey
    Clark County, WA
    I have one flavor of auxbeam in my possession to do some prototyping with, but things have been stops busy lately. One issue with the Auxbeam is its bigger than the opening, so the unit will have to sit above. I need to figure out a way to make it look clean.
  24. Aug 2, 2025 at 9:33 AM
    #324
    subspd
    subspd New Member
    Seth
    SW Florida
  25. Aug 2, 2025 at 12:13 PM
    #325
    Qbert
    Qbert New Member
  26. Aug 2, 2025 at 1:38 PM
    #326
    joseph_womack
    Joe
    Louisiana
    Mines the standard 4x2 panel; I’ll keep my eye out for when you got something figured out, thank you!!
