RainMan Fabrications - Switch Panels and More
Discussion in '2.5 Gen Tundra Parts Marketplace (2014-2021)' started by RainMan_PNW, Dec 23, 2023.
  1. Aug 12, 2024 at 12:59 PM
    #271
    RainMan_PNW
    RainMan_PNW [OP] "Oz" SSEM #82 RGBA #4 Unofficial Forum Treasurer Vendor?
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    If you have the standard SR5 honeycomb grill, then you won't need the shim and adapter setup that I offer to be able to mount a camera. Instead, you can directly bolt the camera using this plate (you will still need to source an oversized washer to mate up behind the grill).
    Toyota Tundra Sport / SR5 Universal Mounting Bracket | Lights & Camera | Yota Leds
  2. Aug 12, 2024 at 2:03 PM
    #272
    Wallygator
    Awesome man, thanks!!
  3. Sep 9, 2024 at 9:05 AM
    #273
    DoublePro
    DoublePro New Member
    Thank you, fits and matches now.
  4. Oct 19, 2024 at 8:27 PM
    #274
    RainMan_PNW
    Casey
    Clark County, WA
    New offering released tonight - the RMF-001C
    This is a 3-slot Carling switch panel for behind the shifter!
    Hit up the first post, where you can find details, order form, and links. Also available are matching textured hole covers.
  5. Nov 22, 2024 at 11:06 PM
    #275
    Bullshawrk
    Bullshawrk New Member
    Hi just wonder what is the difference in V2 to carling switch is it just the material? I have a 2015 limited if that matters? I just want it to look color matched basically which would be the original V2 i am guessing?
    Also i have the older gen trd pro grill would that camera shim work?
    Where did you buy the front camera? from trdgridpro?
    Thank you sorry for all the questions!
  6. Nov 23, 2024 at 1:22 AM
    #276
    RainMan_PNW
    Casey
    Clark County, WA
    1. The difference between RMF-001 and RMF-001C is the style of switch that can be mounted. Both are made from the same material and finished with the same SEM Trim Black paint that will tie in well with the factory black trim. You can also paint them any color you like if you want to do something special.
      • RMF-001 is used to mount Toyota OEM “small rectangle” sized switches - like all of the switches currently in your truck (including the rear window switch).
      • RMF-001C is used to mounting “Carling” style / size switches, which have long been a standard in various industries from off-road to marine.
    2. The RMF-002 shim is specifically for use with the 19-21 TRD Pro “honeycomb” grill and the YotaLED bracket (sold separately) for that grill. The 15-17 TRD Pro grill is shaped differently, and does not have the same profile. I’m not entirely sure what people have done for mounting cameras with that grill, but I am sure there are threads here on the forum that will have that info (might start with the FRAC harness thread).
    3. Clicking the hyperlink (blue text) for the name of the RMF-002 shim/mount will take you to the detailed product description. There is a link to the specific camera there - it’s a Natika WD-011 camera from Amazon specifically.
    4. Depending on what else you are swapping out, you’ll also need some sort of camera switching switch/harness - either using an aftermarket head unit or something like the FRAC Harness for the factory head unit.
    bulldog93 likes this.
  7. Nov 23, 2024 at 3:55 AM
    #277
    littlebus01
    littlebus01 New Member
    Tobias
    21 trd off-road
    Iron Man lift, still-cai, list goes on
    Have not received my order yet??
  8. Nov 23, 2024 at 6:38 AM
    #278
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    No hyperlink for the paint... ;)
  9. Nov 23, 2024 at 7:34 AM
    #279
    RainMan_PNW
    Casey
    Clark County, WA
    I don’t show an order on my order sheet from your user name. And I don’t have any payments that aren’t matched up to orders. Can you tell me what you ordered and when?
  10. Nov 23, 2024 at 7:34 AM
    #280
    RainMan_PNW
    Casey
    Clark County, WA
    I didn’t hyperlink the SEM Trim Black because I paint them before I ship them.
    if someone wants to paint other colors, that’s up to them.
  11. Nov 23, 2024 at 7:41 AM
    #281
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    That explains why he hasn’t received his order
  12. Nov 23, 2024 at 7:56 AM
    #282
    memario1214
    Colton
    Missoula, MT
    '21 Limited MGM CrewMax
    And I thought I had bad organizational skills... :anonymous:
  13. Nov 23, 2024 at 9:43 AM
    #283
    RainMan_PNW
    Casey
    Clark County, WA
    Crisis averted.
    The missing order has been found, and it is heading into manufacturing today!
  14. Nov 23, 2024 at 9:50 AM
    #284
    littlebus01
    Tobias
    21 trd off-road
    Was my fault I apologize. We are all good now:yes:
  15. Nov 23, 2024 at 9:51 AM
    #285
    RainMan_PNW
    Casey
    Clark County, WA
    :fistbump:
  16. Nov 23, 2024 at 10:01 AM
    #286
    TaquitoBandito
    Joel (AKA Bif)
    @TRDFerguson Call off the attack drones! All is good! I repeat, ALL IS GOOD!!
  17. Nov 23, 2024 at 10:14 AM
    #287
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Um… I couldn’t call off all of them. Sorry @littlebus01. Luckily I think it was just the ones that drop the bees, so it shouldn’t be too bad, unless you’re allergic to bees.
  18. Nov 23, 2024 at 10:19 AM
    #288
    littlebus01
    Tobias
    21 trd off-road
    :hattip:Thank ya
    Tell the wife and kids stay off their phone and here I am :burnrubber:can’t get enough of this site :spending:
  19. Nov 23, 2024 at 10:20 AM
    #289
    TaquitoBandito
    Joel (AKA Bif)
  20. Nov 26, 2024 at 8:11 AM
    #290
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Casey, These are great and the fit and finish look factory! I alway seem to have things drop on the switch panel area under the arm rest and wondering if you could almost have a ribbed version or a guard of some sort so if say my dog's feet step there, the switches don't all turn on...similar to what I threw in on my 4th Gen 4runner:
    TaquitoBandito and RobertD like this.
  21. Nov 26, 2024 at 4:59 PM
    #291
    RainMan_PNW
    Casey
    Clark County, WA
    Interesting - so basically extending the overall height of the unit above the top surface (or recessing the switches down into it deeper) to create a recess for each switch.
    There are a few challenges in doing that and trying to keep the textured face if also trying to make something more "contoured" or aesthetic about how the recesses are formed. Not sure when I'll have time, but I could play around with a few ideas.
  22. Dec 21, 2024 at 4:07 PM
    #292
    DoublePro
    Thank you again, my titanium pen fit perfectly.
  23. Dec 21, 2024 at 8:13 PM
    #293
    RainMan_PNW
    Casey
    Clark County, WA
    Nice!
    I was wondering what sort of pen you were putting in there when you were talking about putting a hole in one of the blanks.
  24. Dec 21, 2024 at 9:00 PM
    #294
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Pendrick Lamar. Right @AZBoatHauler?
  25. Dec 21, 2024 at 9:57 PM
    #295
    AZBoatHauler
    So.Arizona
    John F. Pennedy.
    :oldglory:
  26. Dec 22, 2024 at 6:22 AM
    #296
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    Penzel Washington
  27. Dec 22, 2024 at 6:28 AM
    #297
    TRDFerguson
    Jake
    2018 MGM CrüeMax
  28. Dec 22, 2024 at 6:40 AM
    #298
    1794TX
    Steven
    N.TX
    '20 1794
  29. Dec 22, 2024 at 7:03 AM
    #299
    RainMan_PNW
    Casey
    Clark County, WA
    Penjamin Franklin
  30. Dec 22, 2024 at 7:24 AM
    #300
    FrenchToasty
    Mo
    Bone stock
    Jimi Pendrix
