PROJECT: TACTICAL TUNDRA CREWMAX TRD PRO AUDIO UPGRADES
Discussion in 'Audio & Video' started by Tactical_TRD_Pro, Feb 5, 2021.
  1. Feb 18, 2021 at 9:56 AM
    #61
    Tactical_TRD_Pro
    Tactical_TRD_Pro [OP] New Member
    Scott
    2016 Toyota Tundra TRD Pro
    Background: Crutchfield shows Tundra with 6x9's in front and 6.5's in rear...so that became my reference point when considering what to swap out.
    Given your detail above, I understand. So 6.5's in both front/rear with tweeters in all panels, just need tweeter sail panels.
  2. Feb 18, 2021 at 9:58 AM
    #62
    smslavin
    smslavin New Member
    Hudson Valley
    2016 Tundra CrewMax SR5
    Some stuff
    Tactical_TRD_Pro[OP] likes this.
  3. Feb 18, 2021 at 9:58 AM
    #63
    Tactical_TRD_Pro
    Scott
    PNWTundra2021 likes this.
  4. Feb 18, 2021 at 10:03 AM
    #64
    Tactical_TRD_Pro
    Scott
    smslavin[QUOTED] likes this.
  5. Feb 18, 2021 at 10:10 AM
    #65
    Tactical_TRD_Pro
    Scott
  6. Feb 19, 2021 at 6:19 PM
    #66
    Tactical_TRD_Pro
    Scott
    Update: Ready to apply sound deadening tomorrow.
    Freeezen likes this.
  7. Feb 20, 2021 at 12:01 PM
    #67
    Tactical_TRD_Pro
    Scott
    Sound deadening installed on rear wall.
    smslavin likes this.
  8. Feb 20, 2021 at 12:05 PM
    #68
    619Tundra
    619Tundra New Member
    San Diego, Caifornia
    2017 Black Tundra Double Cab SR5
    Pictures
  9. Feb 20, 2021 at 12:14 PM
    #69
    Tactical_TRD_Pro
    Scott
  10. Feb 20, 2021 at 12:29 PM
    #70
    Freeezen
    Freeezen New Member
    Looks good. I have enough Kilmat left over that I think I'm going to take off the access panel and also do the exterior skin as well.
  11. Feb 20, 2021 at 5:40 PM
    #71
    Tactical_TRD_Pro
    Scott
    This is where I left off today with sound deadening.
    Also, captured decibel levels before sound deadening.
  12. Feb 20, 2021 at 6:42 PM
    #72
    Freeezen
    Freeezen New Member
    Going all in with the Kilmat. I like it.
  13. Feb 20, 2021 at 7:23 PM
    #73
    619Tundra
    Are you going to use CCF on top of the kill mat?
  14. Feb 20, 2021 at 7:43 PM
    #74
    Tactical_TRD_Pro
    Scott
    CCF, yes. I have the Noico Red 150mil. Plan to use on floor and ceiling. Not sure if I should put it on the back wall as the existing matting tabs may not fit back in place. If I have any CCF left over I'll use on top of kilmat on doors.
  15. Feb 20, 2021 at 7:51 PM
    #75
    Vector W8
    Vector W8 Old guy with a lot of expensive habits.
    FFV, TRD Supercharger, Bullydog FFV Tune, 2014 Fit Kit, TRD Dual Exhaust, Sequoia Front Sway Bar, TRD Rear Sway Bar, TRD Skid Plate, TRD Pro Grill, 040 White Mirror Covers, 040 White Door Handles, Ready Lift 3"/2", Anzo 3rd Brake Light, Winjet LED Tail Lights, LED Fog Lights, LED Rock Lights, Axle Vent Mod, SDHQ Hidden Winch Mount, 12,000lb Winch. Storm Trooper Shift Knob. BMF BATL Wheels.
    Sorry, I'm running a little late to the party. I will throw in my .02 cents.
    Ideally you want to run subs below 80 hz anything above that and vocals can begin to bleed through to the sub causing a vocal pull to the rear of the car. Ideally if you could fit subs in the front foot wells that would be the ideal scenario. You want to create a front stage that replicates a live performance. So ideally everything should sound like its coming from a distance outside the confines of the cab of the vehicle in front of you.
    As an example the sound stage should sound like it is 50 feet wide and 25 feet deep with the ability to listen to good recordings and place instruments and vocals with your eyes closed that are where they were located when the recording was created.
    That being said, 80hz up to about 5000hz should be covered by your 6.5" drivers in the door and the tweeters should take over from 5000 hz up to 20,000hz plus.
    The best way to achieve a broader sound stage is to use the windshield glass to your advantage and reflect off of it to disperse highs. Other methods can be used to try and create equidistant signals from each speaker to the drivers ears. You can maximize speaker locations by measuring from the drivers ears to each speaker placement. Example: placing mids in the left and right kick panel and tweeters at the far right and left of the knee bolster area would give you a better placement and be closer to achieving equidistant placement to the drivers left and right ears than placing mids in the door locations in the tundra and using the door tweeter locations.
    The best way to cheat this is to use time alignment to your advantage. A good DSP will allow you to cheat and create the illusion of equidistant speaker placement in the car to the drivers left and right ears.
    As for electrical requirements, the factory alternator is somewhere between 120 and 175 amps. There are a lot of electronics running in the cab of a Platinum Tundra, so the alternator is sized pretty close to what the vehicle requires. There are several ways to overcome this issue.
    1. buy a high output alternator. Something with 250 amps of output. This will help keep your battery charged.
    2. Add a capacitor or bank of capacitors. This is an absolute must. It will help with the longevity of your vehicles battery. A car battery is meant for slow discharge and slow charge conditions. Place the demands of a high powered audio system on the battery and the fast discharge requirements to meet the demands of a large amplifier or several amplifiers will kill the battery very quickly. Using capacitors will allow the battery to charge and discharge at a slower rate while allowing the capacitor to handle transient musical peaks.
    Typical rule of thrumb has been 1 farad of capacitance for every 1000 watts. So if you add up a 5 channel amplifier with 4 channels at 75 wpc and a subwoofer output of 350 wpc you would have a total of 650 watts and a 1 farad capacitor would handle that just fine. I live by the rule of thumb more capacitance the better. So I run a 50 farad capacitor bank.
    It doesnt matter if you run 2 or 4 ohm speakers. It wont do anything to your system as long as the amplifiers are rated to run the lower ohm load of 2 ohms. The lower the ohm load the harder it is to drive the speakers with an amplifier. 4 ohms is very common and does not place a lot of demand on an amplifier. There are amplifiers that are rated down to 0.5 ohm loads. This is almost a dead short. But usually a very good competition amplifier will double or triple its power output at these loads. So an old school 25 watt per channel amplifier at 4 ohms from Orion that was a cheater amp years ago at 0.5 ohm load is capable of 300 watts per channel as an example.
    Just be careful as lower ohm loads place a lot of demand on a cars battery as you are producing a lot more power output with the amplifier. Also a lot more heat is generated and will need to be dealt with.
    Hopefully that answers some of your questions below.
    Scenario:
    Read that it is best to use a crossover to limit subwoofer to producing sound between 20Hz and 100Hz.
    Question:
    Even if a subwoofer can go up to 500Hz or 1000Hz, are you missing any quality audio by limiting the subwoofer to 100Hz and having a gap in bandwidth/frequency if Mid Range only goes down to 300Hz?
    Scenario: I seen some Subs with bandwidth/frequency levels that exceed 500Hz – 1000Hz. I’ve also seen Mid Range speakers that produce 300Hz that creates a crossover frequency with Subs. I’m wondering what’s the best way to maximize the handshake in audio so the components work in concert of one another.
    Questions:
    •What is the ideal bandwidth/frequency settings between the Subwoofer and Mid Range speakers to get best audio experience? Meaning, do you want to allow for overlap in bandwidth/frequency so Sub goes up to 500Hz and Mid Range is allowed to go down to 300Hz?
    •Or is it better to have the crossover to match exactly (Sub stops at 300Hz and Mid Range Pick up at 300Hz?)
    •Or is it better to have a gap between bandwidth/frequency? Meaning, should sub crossover be stopped at 100Hz and Mid Range picks up at 300Hz?
    Scenario: I’ve read that if you want quality bass tones you need to get 4Ohm subs, not 2Ohm. I’ve also read that a 4Ohm system demands a lot of power from your system.
    Question:
    •Will running a 4 Ohm damage my existing battery/alternator setup?
    Scenario: I’ve seen where you can wire 4 Ohm Subwoofers as 2 Ohm.
    Question:
    •Do you lose any audio quality by wiring a 4 Ohm sub as a 2 Ohm?
    •I’ve read that wiring a 4 Ohm sub as 2 Ohm runs hot and can start a car fire. Is this true?
    •If I get 4 Ohm subwoofers, it would be best to get a 4 Ohm Amp…correct?
  16. Feb 20, 2021 at 8:58 PM
    #76
    Tactical_TRD_Pro
    Scott
    Always great feedback, much appreciated @Vector W8 ! I'll definitely stick with the frequency recommendations and work to implement the other suggestions.
  17. Feb 21, 2021 at 8:33 AM
    #77
    Tactical_TRD_Pro
    Scott
    Hit a snag. Thought this was a screw push pin and unscrewed both driver & passenger sides. Tried popping off part on diverside and something broke as a piece of plastic dropped. Anyone know how to undue this screw/pin to release the center console?
  18. Feb 21, 2021 at 3:44 PM
    #78
    Tactical_TRD_Pro
    Scott
    Finished Installing CCF. Next, put it back together.
    619Tundra and Freeezen like this.
  19. Feb 21, 2021 at 3:58 PM
    #79
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    Looks good!
  20. Feb 21, 2021 at 7:39 PM
    #80
    619Tundra
    Good boy.
  21. Feb 22, 2021 at 6:10 AM
    #81
    Tactical_TRD_Pro
    Scott
    Question on speakers...
    Why do JL speakers (JL C3 600 6.5) that support 75 watt RMS cost $499 versus other 6.5 speakers that cost $150, support 150 watt RMS, and have the same setup (speaker, tweeter, crossovers)? They seem to be made of the same materials/components and outside of a brand name I don't see what garners that higher price. Is there something I'm missing or are you paying for the brand? Just want to see if I'm spot on or if there is a detail I'm overlooking to improve my knowledge on this.
    Thanks!
  22. Feb 22, 2021 at 6:23 AM
    #82
    619Tundra
    Marketing.
  23. Feb 22, 2021 at 6:31 AM
    #83
    Tactical_TRD_Pro
    Scott
    Got it, thanks! :)
  24. Feb 22, 2021 at 6:42 AM
    #84
    619Tundra
    What speakers are you running?
  25. Feb 22, 2021 at 7:22 AM
    #85
    Tactical_TRD_Pro
    Scott
    Great question @619Tundra.
    Rear will be newer Kicker Dual 12" Subs (48CWRT124), planned install 3/3/21.
    Rear door and front door speakers are undecided. Considering 6.5's (speaker, tweeter, crossovers) in no particular order...JBL, Kicker KS series, Pioneer and want to ensure they support at least 150 watts RMS.
    Just received the sub enclosure yesterday.
  26. Feb 22, 2021 at 7:37 AM
    #86
    619Tundra
    Are you looking for sound quality or spl?
  27. Feb 22, 2021 at 6:00 PM
    #87
    aparker813
    aparker813 New Member
    Save some money in the rear speakers by skipping the components and going with coax and put that money towards better components for the front. Most of your sound should come from in front of you to begin with (think of a concert - all the sound comes in front of you), and the other issue is where the rear tweeters are mounted in the doors they're much closer to your ears than the front tweeters are and your sound stage will be pulled to the back of the truck.
  28. Feb 23, 2021 at 3:24 PM
    #88
    Tactical_TRD_Pro
    Scott
    Update:
    • Subwoofers have arrived.
    • Install conflict came up so 3/3 install date has moved to 3/10
    • Deciding to go with Focal speakers in doors. Talked with Crutchfield and got a great deal on a nice component set for front doors and going with coax in rear doors.
    DeesCrewMax likes this.
  29. Feb 23, 2021 at 3:49 PM
    #89
    g35man
    g35man New Member
    League City Tx
    2019 TSS CM 4x4
    Morimoto LED'S, Remote start, Color match bumper covers, hood bulge and grill surround
    This^
    I run one on my setup and its amazing! Due to my minimal knowledge of tuning (did get some help) I have only gone so far adjusting it. It's not for amateurs like myself. Lol
    Transferred it over from my Tacoma. PS8 running an alpine pdx-v9 with hybrid audio components up front, hybrid audio rears, and 2 10" jlw1's.
    With that said my system sounds pretty damn amazing!
  30. Feb 23, 2021 at 6:05 PM
    #90
    Tactical_TRD_Pro
    Scott
    Nice!
