Procomp lift
Discussion in 'Suspension' started by Dustydirt19, Mar 30, 2017.
  1. Apr 26, 2017 at 4:16 PM
    #121
    Bear
    Bear Fargin' Iceholes
    Bear
    Custer, SD
    2022 GMC Sierra 3500 Dually
    Pulsar Edge V3; MBRP side dump exhaust
    They are not...well, not exactly. They stabilized the front rack.
  2. Apr 26, 2017 at 4:18 PM
    #122
    Bear
    Bear
    Custer, SD
    Haven't seen a need for the traction bars out back. They tend to get beat up pretty bad when crawling over stuff. There is a lift block on the axle, but also an add a leaf. Haven't noticed or seen evidence of major axle wrap.
  3. Apr 26, 2017 at 4:31 PM
    #123
    Dustydirt19
    Dustydirt19 [OP] Hoghead
    Dustin
    Duluth, MN
    2015 Blue Ribbon Metallic 5.7L 4WD SR5 TRD DC
    ProComp 6" stage 2 lift 18x9 Fuel Vapor -12 offset 35x12.5 Nitto Ridge Grapplers BullyDog Tuner Gibson Metal Mulisha cat-back exhaust, S&B cold air intake, Color matched TRD PRO Grille, Compustar Remote Start N-Fab Hooped Nerf Bars, AMI Big stick antenna, Salex organizer and tray, Weathertech laser cut floor mats, Weathertech window deflectors Black out badge Black out front and rear bumper Black out flags 24/7 black out TRD Off-road decals Spray in Line-X Bedliner Scosche phone mount Soft rolling tonneau cover TRD pedals and footrest
    Ok. Was just curious about that. Staying stock gears for now but might go to 4.88 later and didn't know. If axle wrap was a problem would changing from the 3 in block to a 1 1/2 in block and toytec shackles set 1 1/2 to get back to 3in would that help with the axle wrap?
  4. Apr 26, 2017 at 4:33 PM
    #124
    andy9743
    andy9743 New Member
    andrew
    nw ohio
    08 tundra cm 4x4 trd sc, +2 pulley, 4.88s, 37's, other things
    I spoke to coach builder about this.he recommended ome drakar Springs and his +3 shackles to help and to eliminate the lift block.
    Bear and Dustydirt19[OP] like this.
  5. Apr 26, 2017 at 4:36 PM
    #125
    andy9743
    andy9743 New Member
    andrew
    nw ohio
    So that's what I bought.
  6. Apr 26, 2017 at 4:54 PM
    #126
    Dustydirt19
    Dustin
    Duluth, MN
    That keep you level then or do you have any rake with that setup?
  7. Apr 26, 2017 at 5:04 PM
    #127
    andy9743
    andy9743 New Member
    andrew
    nw ohio
    Haven't installed yet. That and one of his steering kits waiting to go on. Just need some time.
    Dustydirt19[OP] likes this.
  8. Apr 27, 2017 at 7:24 PM
    #128
    Dustydirt19
    Dustin
    Duluth, MN
    I'm hearing from some other forums that the abs gets messed up when lifting. Something about going around corners and lights will come on. How is this remedied? I again apologize for all the questions just have to take my truck 6 hours to get this done and I don't want any issues because of the distance factor if I need to take it back
  9. Apr 27, 2017 at 7:48 PM
    #129
    andy9743
    andy9743 New Member
    andrew
    nw ohio
    Lies.
  10. Apr 27, 2017 at 7:49 PM
    #130
    Puud
    Puud Graveyarder
    Nebraska
    2017 Crewmax
    Not usually the ABS but the VSC can get out of wack. Just do the zero point calibration.
  11. Apr 27, 2017 at 7:59 PM
    #131
    Dustydirt19
    Dustin
    Duluth, MN
    Is that what is meant in the install instructions about recalibrating the abs? I'm taking this to a reputable shop so is a zero point calibration something that they would do after the install?
  12. Apr 27, 2017 at 8:03 PM
    #132
    Bear
    Bear
    Custer, SD
    The first thing to do is to in sure you have a no kidding, spot on alignment. After that, if it is still a slight issue, a VSC reset or recalibration might be in order.
    Puud likes this.
  13. Apr 27, 2017 at 8:07 PM
    #133
    Puud
    Puud Graveyarder
    Nebraska
    2017 Crewmax
    There a little module that more or less senses if the truck is level or not. After lifting, if its off thats where people have had problems with vsc coming on when turning and such. Like bear said have a good alignment done and then if needed do a zero point calibration if the traction control starts messing with ya.
  14. Apr 28, 2017 at 8:45 AM
    #134
    Dustydirt19
    Dustin
    Duluth, MN
    How do you do a vsc reset and a zero point calibration?
  15. Apr 28, 2017 at 9:03 AM
    #135
    Bear
    Bear
    Custer, SD
    Techstream can do it...and there are some "cheater" ways as well. You can YouTube the crap out of that topic.
    Jsena and Dustydirt19[OP] like this.
  16. Apr 28, 2017 at 9:37 PM
    #136
    Dustydirt19
    Dustin
    Duluth, MN
    I might be over thinking all of this. I just want everything set up right and not have to dump too much more cash in over the lift tire and wheels cause I don't wanna hear the old lady bitch if I have to drop more money
    Bear and Jsena like this.
  17. Apr 28, 2017 at 10:01 PM
    #137
    Dustydirt19
    Dustin
    Duluth, MN
    I know the BullyDog has a lot of features. If I don't really mind the speedometer being off would it be necessary to get both BullyDog and the Speedo calibrator? I guess a better way to put it is besides the Speedo is there anything that the hypertext Speedo calibrator does that the BullyDog doesn't? Or would I be ok getting the BullyDog and just dealing with the Speedo being off?
  18. May 13, 2017 at 8:51 AM
    #138
    Dustydirt19
    Dustin
    Duluth, MN
    Just got my BullyDog in the mail the other day! Was your BullyDog pretty easy to install? And where did you hook your power wire into?
  19. May 13, 2017 at 2:43 PM
    #139
    Dustydirt19
    Dustin
    Duluth, MN
    An add a fuse? I guess I'm confused. In one of the open spots or used that fuse tap? If you use one of the open spots what size fuse and was it the cab fuse box or the one under the hood?
  20. May 13, 2017 at 3:08 PM
    #140
    Dustydirt19
    Dustin
    Duluth, MN
    So you just put a fuse in one of the open spots with the tap on it? What size fuse and does that still allow it to turn on and off with ignition or is it always on?
  21. May 13, 2017 at 3:41 PM
    #141
    Dustydirt19
    Dustin
    Duluth, MN
    Haha!! Any example of switched fuses?
  22. May 13, 2017 at 3:57 PM
    #142
    Dustydirt19
    Dustin
    Duluth, MN
    Ok thanks. I would guess that the windshield wipers would be one of those that would work but I'll do some digging
    GNTundra likes this.
  23. May 13, 2017 at 4:15 PM
    #143
    Dustydirt19
    Dustin
    Duluth, MN
    No not yet. I'm gonna be out of town for the next two weeks so I'm just getting all my info straight so I can knock it out when I get back
  24. May 13, 2017 at 4:29 PM
    #144
    Dustydirt19
    Dustin
    Duluth, MN
    Lift is going in in 10 days! I was gonna do it then but I don't want to be 250 miles from home when I'm installing it in case I do something wrong. So I'm going to put it in when I get back from lifting it
  25. May 13, 2017 at 4:30 PM
    #145
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    I was informed a tuner voids warranty?
  26. May 13, 2017 at 4:43 PM
    #146
    Dustydirt19
    Dustin
    Duluth, MN
    You can set up 3 tunes plus a stock tune if I'm not mistaken. So if you take it to a dealer reinstall the stock tune back on it and pull the cables and you should be good.
    Yeah but in the same respect where's the fun in that :dancingbacon:+:burnrubber:
    Puud, Jsena[QUOTED] and GNTundra like this.
  27. May 13, 2017 at 5:37 PM
    #147
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    Lol hahaahhaha I've been there
  28. May 18, 2017 at 8:34 PM
    #148
    Dustydirt19
    Dustin
    Duluth, MN
    5 more days!! Going with 35s how much height did it add to the rear end total with the stage 2? 4 1/2?
    Puud likes this.
  29. May 19, 2017 at 12:12 AM
    #149
    Dustydirt19
    Dustin
    Duluth, MN
    I should rephrase that... going from stock tires to 35s plus the lift how much higher is the rear bumper from stock?
    Jsena likes this.
  30. May 19, 2017 at 12:35 AM
    #150
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    3 inches I think
