Procomp lift
Discussion in 'Suspension' started by Dustydirt19, Mar 30, 2017.
  1. Apr 24, 2017 at 9:46 AM
    #91
    Dustydirt19
    Dustydirt19 [OP] Hoghead
    Dustin
    Duluth, MN
    2015 Blue Ribbon Metallic 5.7L 4WD SR5 TRD DC
    ProComp 6" stage 2 lift 18x9 Fuel Vapor -12 offset 35x12.5 Nitto Ridge Grapplers BullyDog Tuner Gibson Metal Mulisha cat-back exhaust, S&B cold air intake, Color matched TRD PRO Grille, Compustar Remote Start N-Fab Hooped Nerf Bars, AMI Big stick antenna, Salex organizer and tray, Weathertech laser cut floor mats, Weathertech window deflectors Black out badge Black out front and rear bumper Black out flags 24/7 black out TRD Off-road decals Spray in Line-X Bedliner Scosche phone mount Soft rolling tonneau cover TRD pedals and footrest
    Did you do control arms too or just left the stock ones
  2. Apr 24, 2017 at 9:47 AM
    #92
    Dustydirt19
    Dustin
    Duluth, MN
    Are you running the stock control arms with your PC lift?
  3. Apr 24, 2017 at 12:55 PM
    #93
    andy9743
    andy9743 New Member
    andrew
    nw ohio
    08 tundra cm 4x4 trd sc, +2 pulley, 4.88s, 37's, other things
    I did light racing. Bc they look cool. Didnt need them. I had worn busings, good excuse to upgrade.
  4. Apr 24, 2017 at 1:03 PM
    #94
    Dustydirt19
    Dustin
    Duluth, MN
    Did you not have the stage 2 the entire time? I thought you said you bought yours with the lift on it. Is it absolutely necessary to get UCA'S or will it be ok with what they send?
    GNTundra likes this.
  5. Apr 24, 2017 at 1:04 PM
    #95
    Dustydirt19
    Dustin
    Duluth, MN
    But you're saying I don't absolutely need them for right now?
  6. Apr 24, 2017 at 1:41 PM
    #96
    Dustydirt19
    Dustin
    Duluth, MN
    Ok just wasn't sure if I should just bite the bullet and put on aftermarket ones or not. Like we had talked about before I don't plan on wheeling all that much.
  7. Apr 24, 2017 at 2:18 PM
    #97
    Dustydirt19
    Dustin
    Duluth, MN
    Or I guess what i should be asking is if you guys think I should put UCAs on if I'm lifting that much? Or will all the parts that come in the kit do the trick for me?
  8. Apr 24, 2017 at 4:08 PM
    #98
    Puud
    Puud Graveyarder
    Nebraska
    2017 Crewmax
    I have the BDS 7" lift with the coilovers. I kept the stock arms and they are working great
    Jsena likes this.
  9. Apr 24, 2017 at 4:13 PM
    #99
    Dustydirt19
    Dustin
    Duluth, MN
    Oh that's right. My bad! But still helpful thank you
  10. Apr 24, 2017 at 9:53 PM
    #100
    Bear
    Bear Fargin' Iceholes
    Bear
    Custer, SD
    2022 GMC Sierra 3500 Dually
    Pulsar Edge V3; MBRP side dump exhaust
    I left the stock UCAs for now...it's a new truck. They should last a hot minute, even at the angles they're currently seeing. As soon as they go, it'll be a uni-ball UCA. I ran Camburgs on my FJ, but I was forced into that $700 decision because the stock UCAs were shot and wouldn't hold alignment. But for now, I'm good
  11. Apr 24, 2017 at 10:25 PM
    #101
    Dustydirt19
    Dustin
    Duluth, MN
    Ok. I've been asking around. I was hoping I could get away with leaving stock for now. Only 29k for miles on my truck
  12. Apr 25, 2017 at 8:19 AM
    #102
    Bear
    Bear
    Custer, SD
    Yup. Pay now...or pay later. :p
    GNTundra and Jsena like this.
  13. Apr 25, 2017 at 8:58 AM
    #103
    Dustydirt19
    Dustin
    Duluth, MN
    I guess the way I was looking at it was...spend 600-700 bucks on UCA'S but if they weren't necessary and my stock ones would work I'd put that money towards a BullyDog and a hypertech speedometer calibrator
    Bear, GNTundra and Jsena like this.
  14. Apr 25, 2017 at 10:40 AM
    #104
    Dustydirt19
    Dustin
    Duluth, MN
    @Bear and @GNTundra are either of you guys running with programmers or isn't it affecting you guys enough to warrant getting one? You're both on 35s right?
  15. Apr 25, 2017 at 10:44 AM
    #105
    andy9743
    andy9743 New Member
    andrew
    nw ohio
    I'll have a programmer and a TRD intake for sale in a few weeks. Putting on a blower.
    To answer your question I did notice a nice increase in power with the hypertech. I'm rolling 37s with 4.88s.
    I spent the $ on ucas because I would rather be safe...and I needed bushings.
  16. Apr 25, 2017 at 11:51 AM
    #106
    Dustydirt19
    Dustin
    Duluth, MN
    Any codes?
  17. Apr 25, 2017 at 12:26 PM
    #107
    Bear
    Bear
    Custer, SD
    Hyper tech was the first mod I did. Same week. Haven't done the speedo calibrator yet, and I'm not if I will. Stock tires had me indicating 2-3 mph faster than actually measu ed by GPS. Now the 35's have me indicating 2 SLOWER than GPS. It all balances out. Haha. Hand calculated MPG is coming in right at 16.2...can't complain. Still way better than my FJ
  18. Apr 25, 2017 at 12:26 PM
    #108
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    Lmao
  19. Apr 25, 2017 at 7:21 PM
    #109
    Dustydirt19
    Dustin
    Duluth, MN
    Another question for you guys..shocker I know... did the pro comp stage 2 lift come with a carriage bearing drop kit? The list of parts on their site isn't the greatest but I didn't order it through their site either so...?? If it didn't is it something I should get?
  20. Apr 25, 2017 at 7:26 PM
    #110
    Bear
    Bear
    Custer, SD
    Looking at the truck, it appears a carrier "drop" is incorporated into the front carrier, so no need for a separate drop kit
  21. Apr 25, 2017 at 7:47 PM
    #111
    Dustydirt19
    Dustin
    Duluth, MN
    Ok thanks. I'm not 100% on what a carriage bearing drop is. Just had read something about it on a different thread. You know what your rough height is with the lift and 35s?
  22. Apr 25, 2017 at 7:58 PM
    #112
    Bear
    Bear
    Custer, SD
    Overall about 7.32" including the larger rubber
    The carrier drop is literally nothing more than extended carrier bolts and some spacers.
  23. Apr 25, 2017 at 8:04 PM
    #113
    Dustydirt19
    Dustin
    Duluth, MN
    Sorry I meant of your truck. Roof height
  24. Apr 25, 2017 at 8:06 PM
    #114
    Bear
    Bear
    Custer, SD
    Haven't measured. But it still fits in the garage!! (Height, not length). Couldn't do that with the FJ due to the roof rack and monstrous HIDs on top
    Dustydirt19[OP] likes this.
  25. Apr 25, 2017 at 8:07 PM
    #115
    Bear
    Bear
    Custer, SD
    It fits in car washes too...no issues
  26. Apr 25, 2017 at 8:07 PM
    #116
    Dustydirt19
    Dustin
    Duluth, MN
    Gotcha. Again thank you for the help
  27. Apr 25, 2017 at 8:08 PM
    #117
    Bear
    Bear
    Custer, SD
    No worries!
  28. Apr 25, 2017 at 8:24 PM
    #118
    Dustydirt19
    Dustin
    Duluth, MN
    Got any pics of your rig? Don't remember if I've seen it or not
  29. Apr 25, 2017 at 8:33 PM
    #119
    Dustydirt19
    Dustin
    Duluth, MN
    Found em!! :transformer:
  30. Apr 26, 2017 at 3:19 PM
    #120
    Dustydirt19
    Dustin
    Duluth, MN
    Are the 2 bars in this pic traction bars? If not are any of you guys running the stage 2 running traction bars?
