Premium gas for 2021 TRD Pro?
Discussion in 'Performance and Tuning' started by Nflguy, Apr 6, 2023.
  1. Apr 8, 2023 at 10:09 PM
    #61
    OnespeedTRD
    OnespeedTRD New Member
    Don
    San Diego
    2020 Tundra Limited TRD Off-Road
    275/70r18 Cooper AT3 XLT on SCS Ray 10s, Eibach Coilovers, DD 12" Exhaust, AJT Blackout Kit, Truxedo Pro X15, paint match/chrome delete.
    Again, you're missing the point and your synopsis doesn't disprove anything, its just one side of the CBA on 87 vs 91. No one is talking about peak HP or MPGs. Pulling timing under load to prevent knock will reduce the power you need when you most need it. Day to day driving its not a big deal and you'll never know the difference. Towing or hauling heavy loads (or hard acceleration for some applications) is where you need it. I tow a trailer, so I'd much rather have the power when I need it than the ECU deciding to pull timing and thus, cutting power. The peak HP and MPG numbers between the two are within the margin of error, no one is debating that. Its what the motor is giving you in the meat of the powerband thats more important. No one drives around in 2nd gear at 4500 RPMs to get peak HP, and no one is hyper-mileing a Tundra to squeeze out a few extra MPGs. And no one is talking about longevity of the motors, that's has way more to do with oil and air filtration than fuel octane. Also, not sure where you're getting the +20-30% on cost. The difference between 87 and 91/93 in most places is around 7-8%, or about the cost of a Starbucks coffee per fill-up. Again, you're stuck on the fringes of measurable data, peak HP and final MPGs, (and somehow you brought motor longevity into it now)... its the time in between where your ECU decides to protect the motor in favor of power that it makes a difference. If you're never in that situation then it doesn't matter, but some folks are, and it does matter.
    Metro14536 likes this.
  2. Apr 8, 2023 at 10:35 PM
    #62
    txtundra311
    txtundra311 New Member
    Metro14536 and bulldog93 like this.
  3. Apr 8, 2023 at 10:48 PM
    #63
    OnespeedTRD
    Don
    San Diego
    Peak HP or better MPGs are not the point here. The advertised "381HP/401TQ" 5.7l makes less than 300HP/320 TQ at the wheels, and way less down lower where most people drive day to day. Now take a 4th gear, 3,500 RPM pull up a grade with a trailer on 87 octane and have the ECU cut your power by 20-30 HP to prevent detonation. You're gonna feel it, especially when you're only making about maybe 70% of your peak whp (we're talking right at 200 whp at this point). Don't get hung up on the advertised dyno run peak numbers and observed MPGs, its how the ECU is "managing" your motor in the real world that makes the difference.
    The logic and facts are solid, the cost benefit analysis for your particular situation is solely yours to make. If you use your truck like a commuter car then its not worth the extra cost, if you use your truck like a truck then it may be worth it.
  4. Apr 9, 2023 at 2:53 AM
    #64
    RichterScale
    Ron
    WNY
    2021 DCRB as base as it gets
    pin stripes (+5 hp)
    Interesting points. I'll have to do some research the next time I'm laid up for a while. Not that I don't believe you (don't take it personal).
    The part that has my brain locked up is this:
    Essentially, this all means that by default, the engine wants to run at 0* timing (TDC) and it takes for there to be pre-detonation and for the sensors to pick it up, for the ECU to pull the timing back (after TDC?). But,....at that point, the knocking already occurred. If this occurs every single time you tax the engine above normal commuter driving, then that means there's knocking pretty much all the time on 87 and that's no small thing for long term damage. Not to mention, they're waiting for damage to occur before adjusting, instead of programming it so damage doesn't happen in the first place.
    Just seems like a lot of extra design and ECU programming to protect the engine.
    I would think that they (Toyota) would recommend min 91 octane and have a disclaimer for using 87. Especially if you tow or have a heavy foot. That part doesn't make sense to me.
    In the OP, the quote says that the ECU pulls different timing for different levels of octane. Granted, I'm no Toyota engineer/ECU programmer, but that sounds off. It would make more sense that there are certain setpoints for timing (based on RPM?), regardless of octane and if the knock sensors pick up any pre-detonation, timing is pulled back further.
    It's hard to imagine that they would recommend 87, knowing that people are going to tow, drive like assholes, etc if there's a chance of engine damage.
    And if that's the case and they simply mitigate it by pulling the timing, it's still hard to imagine that the ECU is constantly monitoring "how much" knock and making constant adjustments on its own. Essentially, "knowing" what octane levels are and adjusting accordingly.
    Seems like an extremely complicated system to be computing all that, at the speeds in which the internal systems of these engines operate.
    Again, I have no idea what I'm talking about. Just thinking out loud about what I think makes sense and what doesn't. I have no problem with being wrong, surprised or educated.
  5. Apr 9, 2023 at 6:21 AM
    #65
    CTundraForMe
    CTundraForMe New Member
    Timing is definitely constantly adjusted for detonation.
  6. Apr 16, 2023 at 6:53 PM
    #66
    Gfgneo
    Gfgneo New Member
    California
    2021 tundra platinum
    I got way better performance with the 87 over the 91. It wasnt even close.
  7. Apr 16, 2023 at 9:42 PM
    #67
    Mike59
    Mike59 Kentucky Traveller
    Central Kentucky
    2021 Tundra DC Limited 4x4 SSM
    Because of this thread, I filled up with 93 the other day at Sam's Club. I know it isn't scientific or anything but I noticed much more power and actually thought it was in tow/haul mode after driving a few miles. Also, my mileage improved from 13 to 15.5 mpg. I like it. Well worth the extra $6.50 I spent.
  8. Apr 17, 2023 at 6:26 AM
    #68
    Terndrerrr
    Terndrerrr 923000 miles to go
    Music City
    6UR-FE
    Americans waste billions on premium fuel in vehicles that don’t require it.
    I searched a lot, but I can’t find a blind test where someone attempts to guess whether their vehicle is running on 87 or 91. I want to see someone correctly guess 8 fill-ups in a row by seat feel only. Particularly in a vehicle with a naturally aspirated engine that does not require premium fuel.
    Maybe some of you “it’s totally worth it” guys can do this for us?
    • Get some Tundras.com members in your area to help you out.
    • Have them randomly fill your truck with fuel.
    • Leave all your OBD stuff off.
    • Don’t look at the fuel receipts.
    • Write down your choice whether it is 87 or 91.
    • The other person who is helping you out will write down what each tank actually is.
    • After 8 fill-ups, compare your lists.
    To make the experiment go faster, you could run, say, 30 miles past E, and fill it only a 1/2 tank each time.
    According to some of you, you should be able to easily guess all 8 tanks in a row. Would love to see it. :pccoffee:
    bulldog93, PermaFrostTRD and PomDad like this.
  9. Apr 20, 2023 at 9:16 AM
    #69
    RichterScale
    Ron
    WNY
    pin stripes (+5 hp)
    More power AND better fuel economy. All from a slightly higher % of octane?
    Sounds magical.
    Sierradevil likes this.
  10. Apr 20, 2023 at 9:31 AM
    #70
    Tundra Dude 45
    Tundra Dude 45 New Member
    Eric
    2019 SR 4.6L DC 4X4
    8” BAMuffler, TRD airflow accelerator, front window tint/windshield sun stripe, debadged tailgate 4x4 emblem, trimmed mud flaps, antenna removed stainless screw added, TRD rear sway bar, AFE high flow air filter.
    I split the difference and run mid grade 89 from Shell 99% of the time. I’ll do a tank of premium every couple of months. The truck does seem to run better with 89 and above compared to 87. I have the 4.6L.
  11. Apr 20, 2023 at 10:07 AM
    #71
    Gfgneo
    Gfgneo New Member
    California
    Not for me. Didnt notice any power improvements and got way less mileage than 87 or 89.
  12. Apr 20, 2023 at 10:22 AM
    #72
    RichterScale
    Ron
    WNY
    pin stripes (+5 hp)
    But,.....it says,...."premium".
  13. Apr 20, 2023 at 11:49 AM
    #73
    Mike59
    Central Kentucky
    or... you could just take our anecdotal observations and say "interesting! Do what you think is best."
  14. Apr 20, 2023 at 11:49 AM
    #74
    Mike59
    Central Kentucky
    Because it is.
  15. Apr 20, 2023 at 11:56 AM
    #75
    RichterScale
    Ron
    WNY
    pin stripes (+5 hp)
    Cool. What's premium about it?
  16. Apr 21, 2023 at 11:09 PM
    #76
    Larly5000
    Larly5000 Local Scumbag
    NV
    07 Crewmax
    The pump/logo has checkered flags and a blue color(instead of red) around the word “premium”.
    Mike59 and RichterScale[QUOTED] like this.
  17. Apr 22, 2023 at 7:57 AM
    #77
    RichterScale
    Ron
    WNY
    pin stripes (+5 hp)
    I've been adding a scoop of salsa to my Bob Evans breakfast bowls for a few months now and haven't had any issues.
    PermaFrostTRD and OHwendTrd like this.
  18. May 30, 2023 at 5:06 AM
    #78
    Mike59
    Central Kentucky
  19. May 30, 2023 at 5:21 AM
    #79
    RichterScale
    Ron
    WNY
    pin stripes (+5 hp)
    He's talking about higher octane gas ("premium") that doesn't have ethanol in it.
    Not all higher octane fuel is ethanol free. If it does have ethanol, then it doesn't have more power.
    So, it's not just "premium". It's gas with no ethanol. You'll get better results with ethanol free 87 also.
    GODZILLA, Larly5000 and Terndrerrr like this.
  20. Jun 4, 2023 at 7:37 PM
    #80
    Chad D.
    Chad D. New Member
    Western Oregon
    2018 CrewMax Platinum
    Yawn…
    You fellas have kicked this can half way to the moon! I’m headed back over to the thread where they still think the NSV light bar is the cat’s pajamas.
    I’m just kidding. There’s been some good input in this to go with the drivel. I’ve tried 87, 89, & 92 E10 fuels, and can’t tell any difference at all. I drive 25K miles per year in my 2018 Tundra, with a good amount of it towing up to 7,500#. I live in hill country, so I use the throttle plenty. And, I burn a lot of gas…
    You want better performance? Re-gear the axles and get a tune.
  21. Jun 5, 2023 at 3:22 PM
    #81
    endagon
    endagon New Member
    16 Tundra SR5 5.7
    The only difference I noticed is that 87 pings a friggin lot in 6th gear when it's hot outside and moving between 45-55 mph. 91 or up never does. Ethanol never does.
    There are motors that have a bigger difference. The Tacoma 1GR single vvt v6 was a good example. 236 hp and 266 lb-ft on 87, and 239 hp 278 lb-ft on 91 by official toyota numbers. Isn't the lexus gx570 listed as 383 hp 403 lb-ft with the only difference being premium fuel
    Mike59 likes this.
  22. Jun 5, 2023 at 5:48 PM
    #82
    Chad D.
    Chad D. New Member
    Western Oregon
    I think when this one is settled, we should move to a discussion regarding the best location for a brake caliper. Does it work best when mounted forward of the rotor? On the rearward side? Or is on top the best orientation for the strongest braking performance???
    Retired...finally and Mike59 like this.
  23. Jun 8, 2023 at 5:09 PM
    #83
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    2015 Platinum Super White Crewmax
    Harrop supercharger, TRD Pro Fox suspension, CB +1 shackles, 295/70-18 Toyo ATIII, TRD Pro forged rims
    I prefer calipers at bottom of rotors. Lower center of gravity.
    PomDad and Mike59 like this.
  24. Jun 8, 2023 at 9:31 PM
    #84
    Chad D.
    Chad D. New Member
    Western Oregon
    That’s sooooo ‘90s. Get with the times, Man! No calipers at all, to reduce unsprung weight…
  25. Jun 8, 2023 at 9:50 PM
    #85
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    calipers on the back have more cooling
  26. Jun 8, 2023 at 11:13 PM
    #86
    Chad D.
    Chad D. New Member
    Western Oregon
    Teasing aside, only the front or back positions make sense for ease of bleeding. The bleeder won’t be at the highest point in a top or bottom orientation.
    I hadn’t heard of cooling being superior in a rear mount setup. I’d like to see some wind tunnel proof of that, as it may be a weird air path in that spinning wheel. Seems like a turbulent spot…
  27. Jun 8, 2023 at 11:44 PM
    #87
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    IDK, but all high end sport have front caliper in the rear of wheel and rear caliper in front of the wheel.
  28. Jun 9, 2023 at 12:41 AM
    #88
    Retired...finally
    Reduced weight of metal lines and brake fluid. Excuse me for a sec...."Yeah, supersize the that for me.". Sorry about that. Driving my carbon fiber Ferrari through the McDonald's drive thru.
    Mike59 likes this.
  29. Jun 9, 2023 at 8:53 AM
    #89
    Chad D.
    Chad D. New Member
    Western Oregon
    Pretty hard to argue with your logic here!
    My guess is that the caliper location is chosen to accommodate other components like steering.
    More importantly, you guys wanna see a picture of a fish?
    nasher75, Mike59, PomDad and 2 others like this.
  30. Jun 9, 2023 at 8:56 AM
    #90
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    2022 Ram TRX Level 2
    Running 91 in my Ram brought me from 16.2 to 18.3 MPG hand calculated.
    Mike59 likes this.
