Potentially snapped Timing Belt
Discussion in '1st Gen Tundras (2000-2006)' started by thefish712, Jun 21, 2021.
  1. Jun 28, 2021 at 4:22 AM
    #151
    Richid
    Richid New Member
    Because something had to bend the valves - which is the piston. So you can't just swap a set of heads, you need to replace the pistons, and hope that any gouges can be bored out. At that point, it's a full rebuild.
  2. Jun 28, 2021 at 4:33 AM
    #152
    Richid
    Richid New Member
    You're in the wrong forum - old Camry's are non-interference engines and are 4 cylinders, not V8s. There's no such usage for 'hydraulic valves' in any gasoline powered automotive engine (diesels use HPOP injectors, not valves). Hydraulic lifters use oil filled lifters to buffer the connection between the cam and pushrods. Your first observance should have been that these are OVERHEAD cam engines (thus the timing belt). There are no lifters.
    So much misinformation in that post.
    07 Tundie, 2mchfun and KNABORES like this.
  3. Jun 28, 2021 at 4:44 AM
    #153
    Sirfive
    Sirfive Socially feral
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    They dont have hydraulic buckets or what have you keeping valve lash in check? One of the first novel bits of info i came across on dads vk45 was that the valves had to be measured and adjusted regularly. If 2uz’s didnt use hydraulics, there would be more talk about valve lash adjustment.
    but yea, our oil pumps are spun by the crank so oil pressure wouldnt die immediately.
  4. Jun 28, 2021 at 5:26 AM
    #154
    DanielDD
    DanielDD Too Old to Rock and Roll and Too Young to Die
    2001 TRD Tundra
    8F937656-190F-44C4-AE44-A280EA3507D0.jpg 8A8F93FF-A64A-4AC2-B6BF-6ABDFCE59097.jpg 67F89473-B1CE-4999-A240-2D9812E3A8B1.jpg
    You're making an assumption as to further damage. The connecting rods and bearings can endure a good deal more stress than the intake/exhaust valves. Case in point, I bought a Jeep Commander with a 4.7L engine, 177K miles. Owner overheated the engine which caused the valve seats to fall out of the heads. Bent the valves, slammed into one of the pistons. Compression on that one cylinder was zero. I pulled the engine, replaced the one piston and bought some remanufactured heads. Since the engine was out I inspected the rods and bearings. All looked like new with 177K miles. I put it back together and today its still running fine. The short block assembly is alot more robust and take a good deal of stresses before it is deemed unreliable.
    Wish I had a picture of the bad piston. It was beat to hell badly. I honed the cylinder, replaced the necessary valvetrain and still running:
  5. Jun 28, 2021 at 5:47 AM
    #155
    I am making no assumptions. I would be unwilling to assume that all is well in an interference motor that just lost it's timing belt at 65mph. Could have damage beyond just the bent valves, much like the engine you repaired also had piston damage. I described the same process you went through, full tear down inspection and rebuild as being what I would do in that situation.
    2mchfun and thefish712[OP] like this.
  6. Jun 28, 2021 at 8:50 AM
    #156
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Will leave rebuild or new to the experts. What I’m interested in seeing is pics of this initial 6K investment. Most here would definetely put another 6K or so into a 2005 without batting an eye IF the frame is in very decent shape….IMHO !
    Tundra2, 15whtrd and thefish712[OP] like this.
  7. Jun 28, 2021 at 9:47 AM
    #157
    thefish712
    thefish712 [OP] New Member
    Fish
    2005 Toyota Tundra 4.7L V8 4WD Double Cab
  8. Jun 28, 2021 at 9:48 AM
    #158
    thefish712
    Fish
    Couldn't find any pics of the frame. This is all I've got and the beaut' that I wanna save
    jpink, BubbaW and 15whtrd like this.
  9. Jun 28, 2021 at 9:50 AM
    #159
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Go for the big save
  10. Jun 28, 2021 at 9:53 AM
    #160
    I vote rebuild or re-motor. Whichever makes the most sense for you. Save her!!!
  11. Jun 28, 2021 at 9:54 AM
    #161
    thefish712
    Fish
    After all is said and done, and I have to sell a kidney to pay for all this, what do you guys think about powder coating the wheels black? Sure, it's the furthest thing that needs attention obviously, but now that you guys see the truck, I'd be interested to hear what you all think
  12. Jun 28, 2021 at 9:56 AM
    #162
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    I’ll do it first thing when I got the truck
    thefish712[OP] likes this.
  13. Jun 28, 2021 at 9:56 AM
    #163
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
  14. Jun 28, 2021 at 9:59 AM
    #164
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    The Tundra Gods will shine down upon you if you choose that route with that "beaut", otherwise you will be forever banished from
    I hesitate to quess what @Darkness will say but have idea :yes:
  15. Jun 28, 2021 at 10:05 AM
    #165
    empty_lord
    05 rollover special
    Are those American racing ATX Mojave wheels?
  16. Jun 28, 2021 at 10:08 AM
    #166
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I actually like how it currently looks. Definitely worth saving.
  17. Jun 28, 2021 at 10:11 AM
    #167
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Bet that sounds crazy
  18. Jun 28, 2021 at 10:12 AM
    #168
    Sirfive
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    Gotta love the jingle of a dry clutch ducati.
    bmf4069 and Lil Steve like this.
  19. Jun 28, 2021 at 10:16 AM
    #169
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Save it! By the way that access cab isn't Jimwagon from TS forum is it?
  20. Jun 28, 2021 at 10:17 AM
    #170
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    Upgrade to newer 4.7 it have more hp
  21. Jun 28, 2021 at 10:23 AM
    #171
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    Filthyphil, bmf4069 and Darkness like this.
  22. Jun 28, 2021 at 10:37 AM
    #172
    I powdercoated my wheels black 15 years ago and they've held up well. Similar style to yours.
  23. Jun 28, 2021 at 1:16 PM
    #173
    Sirfive
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    Wait… you have tires that big, and wont rebuild an engine? Im gonna have to ask you to buy some 22’s and put the leafsprings under the axle.
    Darkness likes this.
  24. Jun 28, 2021 at 1:43 PM
    #174
    Richid
    Richid New Member
    They're shim and bucket and you're supposed to check them every 60K miles / 4 years according to the Toyota maintenance guide.
    Sirfive[QUOTED] likes this.
  25. Jun 28, 2021 at 3:44 PM
    #175
    ToyotaJim
    ToyotaJim New Member
    Oh, that truck is worth a replacement motor. That lift job is probably worth thousands of dollars alone. We have similar looking truck @thefish712
    Darkness and thefish712[OP] like this.
  26. Jun 28, 2021 at 3:44 PM
    #176
    thefish712
    Fish
    Well, they found an engine. 55K miles and comes from a reputable source apparently. $3,500 for the engine. For everything,,, engine, parts for timing belt/water pump/etc, and labor would be TOTAL of $7,200.
    Thoughts?
    What would this truck be worth afterwards with the new engine if I were to sell it? That is NOT the plan, but it will help guide my decision. I bought it for $9K and it's got brand new tires as well for what its worth.
    Sirfive likes this.
  27. Jun 28, 2021 at 3:50 PM
    #177
    ToyotaJim
    Any other mechanical, electrical, or RUST problems to consider? Look carefully for any rust on the underside.
    If the engine is the only issue, you'd be into it for about $16,200. You're probably still around break-even at that price with a low miles engine. I assume it's a 4x4 if it's lifted like that, so I'd venture that with a essentially new motor and no other problems, you could recoup your investment and at least break even.
    I have a very similar 2000 lifted 4x4 with 155k miles. I would put the value on that between $15 - $20k right now. I wouldn't sell it for less than $20k. You'd end up with a slightly newer truck than I have, albeit with higher miles on the body and transmission and other parts, but a nearly new engine. I would do it.
    The alternative is parting it out and you might get 1/2 your money back... or sell it as is, to someone who will immediately put a motor in it and get a great truck for not much money.
    Trucks are extremely valuable right now.
  28. Jun 28, 2021 at 3:52 PM
    #178
    Sirfive
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    Sounds like that engine sat for a long while.
    cheap, current, and local, and theres folks who can make anything fit anything.
  29. Jun 28, 2021 at 3:56 PM
    #179
    thefish712
    Fish
    It's in GREAT shape otherwise
  30. Jun 28, 2021 at 4:04 PM
    #180
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    That honesty seems high to me. What state are you in?
    tvpierce and Darkness like this.
