Potentially snapped Timing Belt
Discussion in '1st Gen Tundras (2000-2006)' started by thefish712, Jun 21, 2021.
  1. Jun 25, 2021 at 1:15 PM
    #91
    thefish712
    thefish712 [OP] New Member
    Fish
    2005 Toyota Tundra 4.7L V8 4WD Double Cab
    Every time I post on here, I further realize how little I truly know about my truck haha but I enjoy learning and tinkering around. Thank you for the input
    jpink likes this.
  2. Jun 25, 2021 at 1:15 PM
    #92
    Coal Dragger
    Coal Dragger New Member
    Kung Fu Dick
    If I’m wrong my apologies. The VVTI versions of the 4.7L may be interference motors.
  3. Jun 25, 2021 at 1:17 PM
    #93
    Coal Dragger
    Kung Fu Dick
    I just hope I’m correct. The Toyota dealer I worked for back in 2005-2006 the techs all insisted the 4.7L and all Toyota engines on timing belts were non interference engines.
    I really hope all you need is a new belt and the cams set to the correct timing.
  4. Jun 25, 2021 at 1:41 PM
    #94
    RalphKaz
    RalphKaz New Member
    On the subject of timing belts - just got this 2005 from a family member and it only has 35k miles on it! Timing belt has NOT been changed. I'm getting various opinions from mechanics - some are saying it should be changed simply due to age of vehicle - others say age doesn't matter at all and it's just mileage... what do you guys think? change it or is it OK for another 4-5 years?
  5. Jun 25, 2021 at 1:43 PM
    #95
    2mchfun
    You have a great truck in your possession, change that belt and keep it great.
    Sampson, 2002tii, jimf909 and 3 others like this.
  6. Jun 25, 2021 at 1:46 PM
    #96
    RalphKaz
    RalphKaz New Member
    I'm leaning towards doing it but dealer wants around $900 for the job so cost is a bit of a factor... if it's OK then would like to hold off for a bit. Someone said there is a way to see the belt pretty easily - is that true?
  7. Jun 25, 2021 at 1:49 PM
    #97
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    You should change it. Those mechanics are wrong. Toyota specifically says 7 years or 90,000 miles. Not based on mileage alone. Have them do the water pump while in there.
    ToyotaJim and 2mchfun like this.
  8. Jun 25, 2021 at 1:55 PM
    #98
    15whtrd
    15whtrd Mr. Blonde
    That’s a really good price, especially if it includes the water pump, thermostat and fluids. Also see if they are doing the cam shaft seals and crank seal at the same time along with the tensioner. OEM or aisin/oem parts. I would jump on it. I know it’s really low mileage, and you very likely could be OK leaving it. My Sequoia belt didn’t get changed for 170,000 miles. The belt looked decent. But I’ve seen evidence on this forum of them with less miles and more time, look really bad. At least open up the timing belt cover and give it a look. I still suggest just doing it and knowing you’re good for another 90,000/7yrs.
  9. Jun 25, 2021 at 2:09 PM
    #99
    2mchfun
    $900 bucks, let's suppose it broke, just the tow truck alone will be $200 minimum. Another way to put this, remember that day after when you were so thankful that you wore that raincoat? Yeah!!!
  10. Jun 25, 2021 at 2:13 PM
    #100
    RalphKaz
    RalphKaz New Member
    Sorry, just checked my notes and the $900 was just labor and did not include the water pump or seals (just tensioners & idler)... Total was around $1500 which also included new drive belt&tensioner
    OK, I think I'll just need to get it done. Will start shopping around for prices...
  11. Jun 25, 2021 at 2:52 PM
    #101
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    Glad to hear, OP. Although a pop sound is not as dramatic as throwing a rod through your block when the oil runs out and your low oil light has blown.
    Been there, done that on my parent’s beater when I was a teen. :D
  12. Jun 25, 2021 at 4:35 PM
    #102
    ToyotaJim
    ToyotaJim New Member
    On miles, it's ~40% spent. But on age it's ~200% spent.
    It's a (correction) 7 year service interval, or thereabouts. It's time to change the belt. And as repeatedly mentioned, there's other things there that are 15+ years old and engine-critical like the water pump, serpentine, coolant, thermostat, idler arms, etc. You're risking a $15,000 truck trying to save a needed $1200 service... penny wise but pound foolish.
    thefish712[OP], 15whtrd and 2mchfun like this.
  13. Jun 25, 2021 at 4:42 PM
    #103
    ToyotaJim
    I bought the OEM parts thru Toyota online during a big sale, which they often have, and my mechanic agreed to install them. That saved me probably a few hundred dollars. You might try the same thing.
    15whtrd likes this.
  14. Jun 25, 2021 at 4:47 PM
    #104
    SouthWestGA
    SouthWestGA New Member
  15. Jun 25, 2021 at 10:07 PM
    #105
    Captain Tenneal
    Captain Tenneal New Member
    NNV
    2005 SR5 Double Cab Off-Road Package, Sunroof
    Bilstein 5100 - 1 groove up
  16. Jun 25, 2021 at 10:18 PM
    #106
    thefish712
    Fish
    Still waiting to hear. Will keep you all posted
  17. Jun 25, 2021 at 11:09 PM
    #107
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    my belt at 192k looked that good and i knew it was original. Owner even said he kept putting it off since 100k. LOL.
    that being said, my fathers 02 tacoma with 78k miles the belt was cracked to high hell... where a vehicle is parked, if it sits alot, age. All this plays into belt condition. i think toyota states 90k or 6 years if you want to be 100% by the book
    Filthyphil and ToyotaJim like this.
  18. Jun 26, 2021 at 12:37 AM
    #108
    TheSilentObserver
    TheSilentObserver New Member
    2001 Tundra 4.7 RWD
    I'm rooting for you! Posts like these are why I just got my '01 into the shop on Wednesday. Hoping that it all goes well. I've only had mine for about a month, but I'm slowly learning to love her, despite her flaws.
    thefish712[OP] and ToyotaJim like this.
  19. Jun 26, 2021 at 7:14 PM
    #109
    thefish712
    Fish
    Welllll, got a call from the shop today. We've got bent up valves, folks! Time for a new engine! Woowoo!
    I will be posting my venmo username as well as creating a kickstarter for the bill I am about to receive lol all are welcome to donate!
    Glock 40 likes this.
  20. Jun 26, 2021 at 7:17 PM
    #110
    Glock 40
    Glock 40 I'm here to break shit
    Yukon Cornelius
    Way up thar
    2000 AC Limited 4X4 4.7L
    Deadpool Edition
    My condolences.
    Filthyphil and thefish712[OP] like this.
  21. Jun 26, 2021 at 7:21 PM
    #111
    Sirfive
    Sirfive Socially feral
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    How bad is it? Valves and valve guides? Or piston damage?
  22. Jun 26, 2021 at 7:26 PM
    #112
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Wow. The shop lifted your spirits and then kicked you in the balls...
  23. Jun 26, 2021 at 7:26 PM
    #113
    thefish712
    Fish
    He just said bent valves and said that they could rebuild the engine but recommended a newer engine. I tend to agree - it seems like a better investment to get a "new" engine than to rebuild an engine with 220k miles
  24. Jun 26, 2021 at 7:33 PM
    #114
    Sirfive
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    Filthyphil, Booney and Lil Steve like this.
  25. Jun 26, 2021 at 7:35 PM
    #115
    Toyoda Tundra
    Toyoda Tundra Boxing and Tundras
    2WD 2004 AC Tundra. V8 strong
    Damn! I had my fingers crossed for ya! Now I’m more scared about mine.
  26. Jun 26, 2021 at 7:39 PM
    #116
    Coal Dragger
    Kung Fu Dick
    Well crap I guess the 4.7L is an interference motor. That sucks, shows how much I didn’t know about the VVTI 4.7L.
  27. Jun 26, 2021 at 7:50 PM
    #117
    2mchfun
    Been there, twice actually, sucks a big one! Good luck with your repairs!!
    FrenchToasty likes this.
  28. Jun 26, 2021 at 7:54 PM
    #118
    ToyotaJim
    That sucks OP. Sorry to hear it. Others warned me, and I try to do my best to tell everyone to change those belts and other parts in every thread when it comes up. Hard lesson to learn.
    Hey, there's a guy with a totally rusted out frame Tundra on this forum. You might investigate buying his engine. I recall it was relatively low miles. Good luck.
    thefish712[OP] likes this.
  29. Jun 26, 2021 at 7:57 PM
    #119
    JimboSlice413
    JimboSlice413 Super Nice Guy
    Bakersfield
    2016 Limited 4x4, 2003 Sequoia
    Sorry to hear that.
  30. Jun 26, 2021 at 7:59 PM
    #120
    ToyotaJim
