Possible to get 600rwhp?
Discussion in 'Performance and Tuning' started by Xcali89, Apr 27, 2022.
  1. Apr 30, 2022 at 11:23 AM
    #61
    Saltyhero13
    Saltyhero13 Throbbing Member
    Stage 2/3 is where the value is at unless you are tracking the car, E85 running cooler may be worth it.
    nobodyintexas[QUOTED] and 1UP like this.
  2. Apr 30, 2022 at 2:10 PM
    #62
    Saltyhero13
    Did you find the 1st and 2nd shift harsh? Seems to be a common complaint. Reading up on it it sounds like it an be remedied with different springs. Also did you look at their full transmission kit? What are your thoughts on it?
  3. Apr 30, 2022 at 2:16 PM
    #63
    nags
    nags New Member
    2008 SC RCSB w/ all the goodies.
    Agreed.
  4. Apr 30, 2022 at 3:26 PM
    #64
    Fastlane47
    Fastlane47 New Member
    Maryland
    24 TRD Pro
    It is a bit harsh, but nothing bad. I had an issue hitting the rev limiter, after the valve body was installed that went away. Shifts great under full throttle.
    https://photos.app.goo.gl/Mbt4mxfQBaPMNVqJ7
    YotaMan, nags and Saltyhero13[QUOTED] like this.
  5. May 8, 2022 at 3:51 PM
    #65
    Saltyhero13
    Speaking of... under the right conditions it is easy to have the back end swing out. Dicking around in a wet parking lot I was surprised how easy it was to get the back end to swing out.
    nobodyintexas and 1UP[QUOTED] like this.
  6. May 8, 2022 at 4:17 PM
    #66
    Fastlane47
    Maryland
    24 TRD Pro
    I still lose traction up until 70mph when everything is turned off, with 305 tires. Hopefully adding the LSD will help some.
    nobodyintexas and Saltyhero13 like this.
  7. May 8, 2022 at 5:05 PM
    #67
    Saltyhero13
    I'm on the stock AT2 on 18s. With nannies off you can get the ass to swing out even with a muted throttle.
    Fastlane47[QUOTED] likes this.
  8. May 9, 2022 at 3:05 AM
    #68
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    We grow old, we don't grow up.
