Possible heater core leak
Discussion in '1st Gen Tundras (2000-2006)' started by 2003stepside, Feb 13, 2020.
  1. Feb 13, 2020 at 1:14 PM
    2003stepside
    2003stepside [OP] New Member
    David
    2003 Tundra Stepside
    Hi all. Just noticed a small leak on passenger side floor mat on my 2003 Tundra . Just bought a month ago and have put 600 miles on it and just now seen the leak. Does anyone know if the radiator stop leak additives work on heater core leaks ? Do the additives do harm to cooling /heating system ?
  2. Feb 13, 2020 at 1:18 PM
    PCJ
    PCJ New Member
    State of Jefferson
    2004 DC Limited 4X4
    Lift, Rims, Bigger Tires, Nerf Bars, Black Out Emblems
    Yes, stop leak additives are bad for the cooling system and don't work. Do not use them.
  3. Feb 13, 2020 at 1:21 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Are you sure it's not just water? Has it been raining in your area? A leak in that location is not uncommon. It's leaking from the cowl area around the windshield wiper.
    he's got a picture of it in post #5.
    https://www.tundras.com/threads/the...vestment-‘build’-a-chronological-story.46816/
    mcharfauros likes this.
  4. Feb 13, 2020 at 1:24 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Do I assume correctly you already know it's coolant and not water leak from outside ?
  5. Feb 13, 2020 at 2:22 PM
    Professional Hand Model
    Hand Protectors
    Its most likely your clips that hold your cowl in place that have failed/old rubber gaskets.
    There is one directly over the blower motor and it drips straight down and rolls around and out of the motor casing onto the pass side floor mat.
    Caulk up those clips. Make sure you caulk all around the clip and down into the screw threads. I didn’t caulk the screw hole the first time (in pics) and ended up still having a slight leak. Ended up Gorilla Arming a handful of caulk up the blower hole onto the backside of the clip to finally resolve the problem.
    There are many other weak points for leaks which you can find on my build page above that @FirstGenVol provided.
  6. Feb 13, 2020 at 2:31 PM
    2003stepside
    David
    Thanks everyone for your input. It has been raining here a lot. When I saw the leak I just feared the worst cause ( heater core) . I’m going to keep an eye on coolant and hope that leak was just from all the rain. Thanks again
  7. Feb 13, 2020 at 2:31 PM
    02goes
    02goes New Member
    2002 Tundra Limited 4X4
    Think before using that stop leak for a moment...No, don't use it. It also coats all water passageways throughout the motor, radiator, etc.
    Like clogging your veins with good ole deep southern fried foods and other good stuff like a thin or thick slice o butter on crackers with your soup.
  8. Feb 13, 2020 at 2:35 PM
    Hand Protectors
    Hang out around here for a while and we’ll get your Tundra in top shape.
    Sounds like the rain is leaking in like we suspected based on your input. The other area for leaks is the back window slider track.
    02goes likes this.
  9. Feb 13, 2020 at 2:57 PM
    02goes
    02goes New Member
    Careful, they'll also get ya to wearing gloves during head breaks between mechanikin on the trk. :argue::annoyed:
