Poll: 2018+ TSS Radar/Precollision Problems
Discussion in '2.5 Gen Tundras (2014-2021)' started by silverhack, Aug 22, 2018.
Do you have recurring TSS Radar/Pre-collision warning problems?
  1. NO: stock suspension (or new shocks set at stock height)
    44.8%
  2. NO: leveled/no rake (+2 front only or 3/1)
    12.4%
  3. NO: lifted with no rake (over 3" front lift and no rake or <1" difference front/back)
    4.9%
  4. NO: lifted with rake (1" or more difference front/back)
    8.3%
  5. YES: stock suspension (or new shocks set at stock height)
    20.4%
  6. YES: leveled/no rake (+2 front only or 3/1)
    4.2%
  7. YES: lifted with no rake (over 3" front lift AND no rake or <1" difference front/back)
    2.3%
  8. YES: lifted with rake (1" or more difference front/back)
    2.6%
  1. May 15, 2019 at 1:31 PM
    #91
    BC.TRD
    BC.TRD New Member
    2019 TRD OFF ROAD CEMENT
    Truck went in this morning. On the way there the sensor went on and off and gave me the dirty or malfunction alert multiple times. Hope there is a proper fix. I want to lift it soon and don't want to have my wheels tires and suspension lay around for something so absurd on a brand new truck.
  2. May 16, 2019 at 12:17 PM
    #92
    BC.TRD
    BC.TRD New Member
    Update: So after the campaign update and being in the dealership twice, the TSS Sensor still malfunctions and still says it is dirty. My dealership has booked me in on the 29th to have it diagnosed for 4 days and have a toyota regional tech come test the truck. I have emailed toyota Canada as well.
  3. May 19, 2019 at 8:17 PM
    #93
    Knooger
    Knooger New Member
    2018 Limited TRD Off Road CM
    Haven't been on here in a while, I've had the thing shut off a couple times and the "brake" warning come on a few times for no reason, but it didn't occur enough for me to care. I had the recall done and haven't noticed it since, but it never was much of an issue. I've got a little over 26,000 miles on my '18.
  4. May 30, 2019 at 8:19 PM
    #94
    BC.TRD
    BC.TRD New Member
    So, Toyota Canada sent a rep down to check my truck out. He determined that the sensor itself is faulty and has water inside of it causing moisture when the sun hits it messing up the system and making the light turn on. They agreed to replace the sensor however, it is on back order and they'll call when the part is in.
  5. May 31, 2019 at 9:33 AM
    #95
    B0G4RT
    B0G4RT New Member
    Bo
    2018 SR5 TSS
    Coming soon
    There is an open recall for all systems on the tundras. They are on back order right now. I just went to my dealership last week and they ordered the new item for me. If you are having issues not caused by rake or lift then call your local dealership and get it ordered.
  6. Jun 7, 2019 at 6:10 PM
    #96
    Xtaco16
    Xtaco16 New Member
    2018 Tundra TRD sport
    My second 2018 tundra... Long story.. First one had many false alerts never applied the brake. Second tundra no false alert. Still wonder if brakes will apply.
  7. Jun 8, 2019 at 8:58 AM
    #97
    RLHULK
    Rich
    2022 Silverado LT.
    Still rolling stock baby....
    Here is what I do not understand, so someone please educate me if needed..
    The recall is due to a faulty seal on a sensor from what I understand that lets moisture into the sensor and causes false readings, correct?
    If that's the case then how can Toyota say that they will not warranty a vehicle that has been lifted or leveled with non Toyota parts or even parts that are Toyota but not specific to the model they are installed on?
    When the recall has nothing to do with suspension parts at all.
    Sounds like they are not sure what to do and are grasping at straws.
    I have a 2019 with 3500 miles so far and thankfully no issues. All stock at the moment
  8. Jun 14, 2019 at 3:09 PM
    #98
    bamelanc
    bamelanc New Member
    Orange, Texas
    2018 Magnetic Grey Platinum 4x4
    Addictive Desert Designs Stealth Fighter bumper w/ 40" Baja Designs Onyx6 arced dual control combo light bar and Smittybuilt X20 Comp 10k winch. Baja Designs S8 10" amber fog lights. sPod Control for lighting and compressor. ICON Stage 3 Suspension with tubular UCA set at 3". ICON Alloys Six Speed 17" machined/satin black wrapped in 285/75/17 Nitto Ridge Grapplers. TRD Performance Intake. TRD Cat Back Exhaust. LED Kit inside and out. ARB onboard compressor. Amp Research Power Step w/LED kit. Retrax XR Pro bedcover. Armadillo Bed Liner. Tint - 35/5/5 ceramic. Center Console Safe. Weather tech mats.
    2018 3” lift on 34’s with 1.25” rake. 15000 miles. I have only had the PCS unavailable come on a few times (heavy rain)...maybe 5, but it always returns to normal.
    Scheduled for millimeter wave recall and ecu flash this Saturday. No pushback from dealer.
  9. Jun 15, 2019 at 5:45 PM
    #99
    msbaugh440
    msbaugh440 2019 limited, TRD package, cement
    Utah
    2019 Tundra limited, TRD off road, Cement
    Just bought a 19... no issues yet, but it only has 150 miles on it so far so don’t count my vote!
    They did apply the above TSB above which keeps the PCS from defaulting to on after each ignition cycle, they did it for free for me when I bought the truck. Just glad I knew about it from this thread and was able to ask. Doesn’t matter much at this point, as plan on leaving it on. Figured I might be glad I did it once I get around to my 3-4” lift. Want to work through the first 20-30k miles on this truck before I get crazy with a lift though.
  10. Jun 16, 2019 at 2:29 PM
    #100
    Drew C
    Drew C New Member
    I have a 2018 Tundra. I've had a few issues here and there. Maybe 3-4 episodes where the "Brake" light came on. One was on a curved road with oncoming traffic. The others were random, straight highway with nothing in front of me. I have seen several "clean sensor" warnings (with a clean sensor tho). Completely random.
    The other day I power washed the truck and had the 'clean sensor' light come on. A day later I swapped the grille and a new (but different) emblem and I've had several issues since. Some of that is on me but I've had other issues before that as well. Other than a cap the truck is stock.
    PS - I have also had issues off road with various warning lights but never gave that much thought (and not part of the issues above).
  11. Jun 25, 2019 at 10:46 PM
    #101
    BC.TRD
    BC.TRD New Member
    Trucks been great. Warranty work resulted in an updated vented sensor which my advisor stated that the seal is not needed for on my truck as well as a reflash and ecu update. No issues for 1000 kms driven in rain and shine.
  12. Jun 26, 2019 at 8:58 AM
    #102
    msbaugh440
    Utah
    What off-road issues have you had? I bought this truck for off-road use and want to make sure to set my expectations where they should be before going crazy with lift/tires/re-gear/rear air locker
  13. Jul 3, 2019 at 6:26 PM
    #103
    Mark18TRD
    Mark18TRD New Member
    Mark
    Cypress TX
    2018 White Tundra TRD
    6" RC lift, 20" Fuels, RC rear bumper w/ lights, RC front bumper light bar, (NSV light bar ordered and on the way)
    had my truck for a very short while but have experienced issues with the cruise radar and the little light showing the truck with the stars above it. cruise will not function and only seems to happen in intense rain! i have a 6" lift
  14. Jul 5, 2019 at 3:31 AM
    #104
    Jtundra81
    Jtundra81 Just a member
    Joe
    2019 cement tundra crewmax
    2019 crewmax 5.7l with 2250 miles on it , never had an issue.
    Last week pulling my trailer 5000lb on the highway and an SOB brake-check me, got the orange light and truck helped Me with the break to avoid collision
  15. Jul 23, 2019 at 10:01 PM
    #105
    rallypanam
    rallypanam New Member
    2019 Doublecab Limited 4x4
    2019, Icon Stage 9 with 35s for the last 1000 miles, bone stock for the first 2000 miles. No issues, knock on wood.
  16. Aug 11, 2019 at 6:20 PM
    #106
    Drew C
    Drew C New Member
    I got a ‘brake’ warning earlier today. Clear weather, no one, nothing at all in front of me.
  17. Aug 11, 2019 at 7:21 PM
    #107
    Hammerdog
    Hammerdog YCMTSUP
    Robbie
    Louisa VA
    2018 tundra sport crew max
    Tint Bed cover Red Tow Hooks TRD Intake 7 inch BDS 22x12’s 35 Toyo’s Rigid ditch lights RC light bar in bottom grille One bad ass stereo
    7 inch BDS, zero issues or warnings. Recall done before lift.
  18. Aug 12, 2019 at 4:32 AM
    #108
    Drew C
    Drew C New Member
    I take the truck on the beach, several times I've - warning messages - PCS unavailable, don't remember the other one. Restart the truck once back on the pavement and everything is back to normal.
  19. Sep 20, 2019 at 10:31 AM
    #109
    bigandtall
    bigandtall New Member
    Indianapolis Motor Speedway
    Stock 2019, made last month 2019s were made, July of 2019. Keep getting this alert now after only 2200 miles and a month of ownership.
  20. Sep 20, 2019 at 10:42 AM
    #110
    timsp8
    NY
    Check your VIN for the recall to see if it was done. Then go get gas.
  21. Sep 20, 2019 at 2:27 PM
    #111
    bigandtall
    Well, no open recall on my truck per the Toyota website. And yes, trying to squeeze 600 miles out of a tank of gas has become a real nail biter!
  22. Sep 20, 2019 at 3:08 PM
    #112
    timsp8
    NY
    Still under warranty. You can try the dealer. But if it comes in and stays on, make sure you go to the dealer with it on or they probably won’t look at it. If it comes in then goes off, take a video of it to the dealer.
  23. Oct 13, 2019 at 7:55 PM
    #113
    dasunsrule32
    dasunsrule32 New Member
    Arizona
    2019 Tundra SR5 Silver Double Cab
    Tonneau Cover OEM Headlight LED Lights Morimoto LED Fog Lights Sports Antenna Running boards LED Turn Signals 18" Vision Manx 2 wheels
    I too was coming up on a car that was turning slowly and it lit the brake light up as well, but it didn't actually brake.
  24. Oct 16, 2019 at 8:06 AM
    #114
    HEINE THE HUN
    HEINE THE HUN New Member
    HENRY
    SKY SILVER TRD
    NONE
    Same problem and No recall, bought my Tundra SR5 TRD off road August 2nd . Vehicle was built Feb. 2019. No mods. I am having the problem with the PCS collision dashboard light and yellow triangle on in the rain today (did not turn off till I shut the vehicle off and restarted), also the Radar is unavailable when I attempted to use the cruise control.
    Called Toyota, my vin number is not on the list for the special service campaign, went ahead and and got a claim number. On my own I'm taking it in the dealer for diagnostics tomorrow.
  25. Oct 16, 2019 at 9:13 AM
    #115
    timsp8
    NY
    Mine turns off in the rain. I think that’s common as the radar doesn’t work with rain. Mine always comes back on though on its own.
    glowblue likes this.
  26. Oct 31, 2019 at 4:44 PM
    #116
    YoTundra
    YoTundra New Member
    2018 Tundra SR5 Quicksand
    Had a 2.5" level kit put on along with wheels and tires today. Now dealing with all these lights on. Front is little higher than rear but I've never had them come on when I pulled it up on my ramps and started it. Why would all these lights be on?
  27. Nov 4, 2019 at 12:33 PM
    #117
    aussieaarons
    aussieaarons die with memories, not dreams
    2019 Cavalry Blue TRD
    2” level, roof mount DVD, interior LED bulbs, sumosprings out back, OEM folding cover, Blackout emblems
    2” front spacer installed, stock rear with stock tires. No problems.
  28. Nov 5, 2019 at 11:45 AM
    #118
    glowblue
    glowblue From time to time
    VA
    2021 Tundra SR5 —> 2021 F-250 XLT
    Mine does the exact same thing. I had a 2018 Camry rental with the TSS and it did the same thing turned off in rain and turned back on...seems to be a generic issue with TSS And rain.
  29. Dec 28, 2019 at 6:45 PM
    #119
    Jpneely
    Jpneely New Member
    White SR5 5.7
    Had mine malfunction on a road trip during a heavy rain. it was random during the rain, not as it started or lightened up. just randomly in the middle of it. bone stock 2019
  30. Dec 29, 2019 at 4:24 PM
    #120
    MGM2018OR
    MGM2018OR New Member
    Craig
    2018 MGM OR dbl cab ( gone but not forgotten )
    My 2018 Tundra has not done this since the update. Did it once but some fool changed 2 lanes and cut right in front of me and the system worked correctly.
    My wife’s 2019 Honda Pilot does it like 2-3 times a week. Super annoying..
