Poll: 2018+ TSS Radar/Precollision Problems
Discussion in '2.5 Gen Tundras (2014-2021)' started by silverhack, Aug 22, 2018.
Do you have recurring TSS Radar/Pre-collision warning problems?
  1. NO: stock suspension (or new shocks set at stock height)
    44.9%
  2. NO: leveled/no rake (+2 front only or 3/1)
    12.4%
  3. NO: lifted with no rake (over 3" front lift and no rake or <1" difference front/back)
    4.7%
  4. NO: lifted with rake (1" or more difference front/back)
    8.4%
  5. YES: stock suspension (or new shocks set at stock height)
    20.5%
  6. YES: leveled/no rake (+2 front only or 3/1)
    4.2%
  7. YES: lifted with no rake (over 3" front lift AND no rake or <1" difference front/back)
    2.3%
  8. YES: lifted with rake (1" or more difference front/back)
    2.6%
  1. Feb 18, 2019 at 8:55 PM
    #61
    CamaroSsToTundra
    CamaroSsToTundra New Member
    Ohio
    2018 Tundra
    I don’t have this issue either with my 2018 stock Tundra. And I already put 10,000 miles on it.
  2. Feb 21, 2019 at 12:53 PM
    #62
    Chris57
    Chris57 New Member
    2018 Tundra
    None
    I’ve had my 2018 Tundra in the shop twice now for the PCS sensor. The 1st time they replaced it. The problem with the sensor actually got worse. It turns on and off everyday no matter the weather. I’m at the dealership today 2/21/2019 and the service department just informed me that Toyota has now admitted that there is a problem with the sensor and they don’t have a fix for it at this time. There’s really nothing they can do at this point until Toyota comes up with a fix. This has just been more of a nuisance than anything. Still the best truck I’ve ever owned. I’m confident that Toyota will figure this out.
  3. Mar 27, 2019 at 1:02 PM
    #63
    EMSpilot135
    EMSpilot135 New Member
    2018 Blue Long Bed SR5
    Got the same answer that Chris57 got the last time my light came on, last fall in the rain. Only time it would come on was in the rain while driving on the highway.... Until 2 days ago when it came on a couple of hours after I took it to get washed. Never had an issue with the wash before, just went over 20 k. Did the old turn truck off turn truck back on trick and light went out...until this morning after sitting in the driveway for a solid day and light was on at up on/off trick tried 5 times at multiple times during drive to work, light is still on. This will be second sensor replacement for me.
  4. Mar 28, 2019 at 3:07 PM
    #64
    EMSpilot135
    Update to yesterday’s post. Truck sat all day at work front end pointed I to the sun. Started up to go home, light went out after all the self check lasted about 10 seconds and came back on. On/off had no effect. Got it home parked it for the night, this morning started up no light. Made it all the way to work so far no issues today. Still have an appointment for Wednesday for them to look at it. Gal I have been dealing with at my dealership has been very up front with info and admitting Toyota has no idea how to fix this. I will mention that the first time they replaced the sensor. The dealership was out front f loaner vehicles so they paid for a rental. I ended up with some Nissan car and as I was driving to work in the rain IT HAD THIS SAME ISSUE! The PCs light came on and when I got to work the on/off trick worked. Maybe all the auto companies are using the same sensors from one manufacturer like the Takata air bags?
  5. Mar 28, 2019 at 3:30 PM
    #65
    HTGreen
    HTGreen New Member
    Halsey
    Central Virginia
    2018 SR5 TRD Tundra Quicksand
    recall time
    Service Campaigns:
    Title
    SPECIAL SERVICE CAMPAIGN K0B (Remedy Notice) - Certain 2018 – 2019 Model Year Tacoma and Tundra - Millimeter Wave Radar Sensor
    Status
    Remedy Available
    Description
    The involved vehicles are equipped with a Pre-Collision System (PCS) that may automatically apply the brakes if the system detects a potential collision. Due to the mounting of one of the system’s sensors, it is possible for water to enter the sensor. This can lead to PCS deactivation or inadvertent brake activation resulting in limited deceleration for a short duration of time.
    Remedy
    Any authorized Toyota dealer will update the PCS software and apply sealer to the millimeter wave radar sensor in the front grille. In the rare case that the vehicle is currently exhibiting the condition, dealers will diagnose the sensor and replace the sensor, as necessary, FREE OF CHARGE.
    Campaign Date
    March 28, 2019
    Dealer Reference ID
    K0B
    Title
    Special Service Campaign K0A- Remedy Notice Certain 2018 Model Year Camry, Sequoia, Sienna, and Tundra Engine ECU Software Update
    Status
    Remedy Available
    Description
    The engine ECUs in the subject vehicles are equipped with software to monitor the rear oxygen sensors. Under a specific condition, this software may not detect a malfunctioning sensor due to an error in the software. As a result, affected vehicles do not meet certain onboard diagnostic (OBD) regulations.
    Remedy
    Any authorized Toyota dealer will update the engine ECU software FREE OF CHARGE.
    For answers to frequently asked questions, please click here.
    Campaign Date
    March 14, 2019
    Dealer Reference ID
    K0A
    woodcan and silverhack[OP] like this.
  6. Mar 30, 2019 at 8:25 PM
    #66
    Bsincs2k
    Bsincs2k New Member
    Kansas
    2019 Voodoo Blue TRD Pro
    Hopefully the dealership can get this issue resolved.
    Any owners have good luck with the recall fix?
  7. Mar 31, 2019 at 8:22 PM
    #67
    Rod67
    Rod67 New Member
    Rod
    2019 SR5
    Mine was apparently just software. After the dealer "reflash" no more false alarms. Unit does occasionally disable in heavy rain.
  8. Mar 31, 2019 at 9:07 PM
    #68
    Bsincs2k
    Bsincs2k New Member
    Kansas
    Was it an easy in and out fix or one of those drop it off deals?
  9. Apr 1, 2019 at 4:12 AM
    #69
    Rod67
    Rod67 New Member
    Rod
    2019 SR5
    I dropped it off late afternoon because I didn't have time to wait.
    It was ready the next morning.
  10. Apr 8, 2019 at 7:26 AM
    #70
    Celt
    Celt New Member
    NY
    2019 Crewmax TRD/OR Cement
    My PCS off light turned on randomly this morning while driving to work in a light rain. I've had the truck for 10 days and it has 809 miles on it. It's a 2019 SR5 TRD off-road Crewmax.
  11. Apr 8, 2019 at 1:26 PM
    #71
    silverhack
    silverhack [OP] New Member
    Sacramento, CA
    2018 CrewMax Inferno
    There’s a recall to have the dealer do some work to fix the sensor. You’ll probably get a letter in the mail sometime.
    Celt[QUOTED] likes this.
  12. Apr 8, 2019 at 7:38 PM
    #72
    Bsincs2k
    Bsincs2k New Member
    Kansas
    Dealership had to order a part into mine. 2500 miles in and I’m starting to see the light more often. Hopefully the next visit fixes the problem.
  13. Apr 14, 2019 at 12:39 PM
    #73
    wyone
    wyone New Member
    2018 Tundra DC
    dashcam... more to come
    I posted this in another thread.. but I thought I would share here as well.
    I took my 2018 SR5 in yesterday for 10K oil change and inspection. Two recall notices show up. One is a software update to read the rear O2 sensor correctly. The other was to check the wave radar sensor. I have had zero issues with mine to date. Apparently, there is a sealant issue and typically they apply additional sealant and that is the repair. However, the second repair s to replace the sensor if it shows any signs of water penetration. Of course, mine does. And also, of course, they do not stock it, so it has to be ordered. I guess we will see if this makes things better or worse. As I said, to date I have had zero malfunctions.
  14. Apr 18, 2019 at 8:33 AM
    #74
    incredibillhulk
    incredibillhulk New Member
    Bill
    I took mine in today for the K0B recall and the dealership said they weren't going to do anything because of my lift kit. Waiting on a response from Toyota corporate now...
  15. Apr 19, 2019 at 5:13 PM
    #75
    eric05sti
    eric05sti New Member
    Eric
    Vermilion, Ohio
    2019 Cement Tundra TRD Off Road
    This is the official statement from Toyota on modified vehicles:
    I am a certified Toyota tech and have done a ton of the K0B recalls already.
  16. Apr 19, 2019 at 5:43 PM
    #76
    Beastmode1794
    Beastmode1794 Masshole
    2019 tundra 1794 edition smoked misquite
    I had it shut off on me the other night just happened to be right after I picked up my truck for a new head unit install and it freaked me out lol I was ready to put the stock one back in but the next morning it was fine I did notice a few mosquitos on there but other than that it was spotless only got 3500 on the truck and it has only happened once I hope it's not a recurring problem cuz I want to do a lift and tires and other stuff
  17. Apr 19, 2019 at 6:10 PM
    #77
    owb2gp
    owb2gp New Member
    ID
    So are you doing the recalls if the truck is modified or no?
  18. Apr 19, 2019 at 6:16 PM
    #78
    eric05sti
    Eric
    Vermilion, Ohio
    I personally am not if it's modified because I don't want the liability.
  19. Apr 19, 2019 at 6:25 PM
    #79
    Vizsla
    Vizsla 2 = 2.5
    I would not if no issues, but screwed eventually. When you go in with it modded, doesn’t matter lifted, switched to 19 Pro grille, or have a relocation kit to run an older Pro grille, Toyota is being deceptive, when the mods are noted, warranty on the system is void unless returned to as built at the factory so this recall can be applied. The value of these trucks takes a huge hit without this recall, and can’t be resold at a dealer till remedied.
    ColeMine likes this.
  20. Apr 19, 2019 at 7:06 PM
    #80
    owb2gp
    owb2gp New Member
    ID
    Mine is scheduled Monday. Asked the service advisor if they were not doing the recall because of mods and he said no. We'll see Monday morning. I don't plan on selling my truck in the next 20 years.
  21. Apr 22, 2019 at 11:55 AM
    #81
    owb2gp
    owb2gp New Member
    ID
    Dealership took care of both recalls this morning. They put the sealer over the sensor mounted on ares relocation bracket.
    bhuff92 likes this.
  22. Apr 22, 2019 at 8:53 PM
    #82
    Bsincs2k
    Bsincs2k New Member
    Kansas
    I got mine back from the dealer and now I can’t leave my city lights on and just have it turn off when I arm the truck. It beeps and stays on as if I had the lights on.
    Does anyone have this issue?
  23. May 1, 2019 at 2:42 PM
    #83
    ninjajay
    Spoolston, TX
    2018 MGM 1794 TRD 4x4
    both of my tundras have beeped when I left the parking lights on after turning the truck off and opening the door
    Bsincs2k[QUOTED] likes this.
  24. May 3, 2019 at 1:24 PM
    #84
    AZ2019
    AZ2019 New Member
    Brand new 2019 Crewmax was fine until today when I installed 6112's up front. Now every single system is showing a malfunction, including ABS, 4WD, traction control and all the TSS features. I figured I'd have problems with the sensors but wasn't expecting all the other stuff. Any ideas?
  25. May 3, 2019 at 4:16 PM
    #85
    TundraLaw
    TundraLaw New Member
    Northern Nevada
    Wow that makes me nervous, as I'm about to put on 6112s up front. What height did you put it at? It may just need to be recalibrated by Toyota.
  26. May 3, 2019 at 4:19 PM
    #86
    AZ2019
    AZ2019 New Member
    1.9" I left the rear alone. It sits just a tad above level in the front but it should in perfectly.
  27. May 3, 2019 at 4:21 PM
    #87
    TundraLaw
    Northern Nevada
    Thanks. Maybe that might be the root of your problem then. When you lose that rake, things go haywire. I'm going to do the 1.3 inch set up, and hope for the best!
  28. May 10, 2019 at 1:03 AM
    #88
    P-Factor
    P-Factor New Member
    bhuff92 likes this.
  29. May 10, 2019 at 1:10 AM
    #89
    P-Factor
    P-Factor New Member
  30. May 10, 2019 at 2:18 AM
    #90
    steve-smith
    steve-smith New Member
    2019 Toyota Tundra
    310 to 381 hp
    i also have this problem but didn't get exact solution yet though i try to recover and talk with dealer.
    they just like silent!! :confused:
