PNP amp/speaker overhaul
Discussion in 'Audio & Video' started by 4Yotasince99, Apr 3, 2020.
  1. Apr 14, 2020 at 11:50 AM
    4Yotasince99
    4Yotasince99 [OP] New Member
    Eric
    2018 CM Tundra TRD Sport
    Bilstein 5100 (middle setting) - front only, Driver's side grab handle installed, JL Audio upgrade from Tech 12
    I have a non-JBL system, I'm not aware I received a DSR1 nor did Tech12 suggest it. Is this a good, better, best thing... like the upgrade alone sounds good, but even better with a DSR1??
  2. Apr 14, 2020 at 12:02 PM
    Mater
    Mater New Member
    Nick
    SD
    2016 MGM Platinum
    If you run your power wire through the passenger side just tuck it up under the valence thing. There are 5 plastic nuts that unscrew and drop the cover. Run the wire and put the cover/nuts back on. It won’t go anywhere
  3. Apr 14, 2020 at 12:05 PM
    4Yotasince99
    Eric
    Oh great, thanks for the tip! See this is why I wanted to keep hittin the forum, lots of good install knowledge do's and don'ts.
    Mater[QUOTED] likes this.
  4. Apr 19, 2020 at 6:22 AM
    4Yotasince99
    Eric
    I’m in the middle of my install, how does the JL bass knob come apart? Does the black knob just pull off? Or unscrew?
  5. Apr 19, 2020 at 6:59 AM
    DSTundra
    DSTundra New Member
    Dave
    Albuquerque, NM
    2017 Tundra Platinum
    Pulls straight off if it's the RBC-1. I don't know if you determined where you're going to put yours yet, but here's where I put mine -- right in the middle of the plastic piece under the center console lid. My hand naturally rests there so I don't even have to move it to adjust the bass.
    619Tundra, Bama, TXTundra2722 and 4 others like this.
  6. Apr 19, 2020 at 8:12 AM
    DCB500
    DCB500 New Member
    David
    Oklahoma City
    2019 Tundra SR5 TSS Double Cab
    Wheels, sound system, antenna, tailgate letter inserts, Grill/Hood Bulge, Exhaust, Leather
    the LOC simply converts/decodes the signal from the factory head unit to be usable on your aftermarket amp. For The DSR1, once you update the software and flash for your specific vehicle then there is an app you download on your phone where you can adjust time correction, crossover points, and also has a 31 band EQ so that will give you much more sound adjustment than the bass, treble, and mid that you have on the factory HU.
    Black Wolf likes this.
  7. Apr 19, 2020 at 10:24 AM
    4Yotasince99
    Eric
    That’s very clean, nice job. I ended up using the blank next to the USB port.
    Black Wolf and TomC843 like this.
  8. Apr 19, 2020 at 2:35 PM
    TomC843
    TomC843 The wheel weaves as the wheel wills.
    Tom
    Charleston, SC
    16, 4X4, 4U3, Katzkins, Flowmaster, ARE MX, Swing cases, TRD skid plate, Volant CAI....
    Nice. I was lucky enough to win one of James' raffles he runs on Tundra Crew. JL amp, 2 JL 10s, and sub box for my SR5 non JBL. I added a double USB in that blank. See mine close to arm rest. I seem to adjust it a lot. Still with OEM head unit it hits hard. Lots of WTF from the wife.
    Black Wolf and Cfincke like this.
  9. Apr 20, 2020 at 5:14 AM
    aggie_tundra
    aggie_tundra Always Tired
    2021 2500 Custom
    what's the depth on that box to allow it to fit under the rear seat?
  10. Apr 20, 2020 at 5:27 AM
    4Yotasince99
    Eric
    Is that the double cab set up? That rear seat area looks different than my 2018 CM. My box is behind the seat.
    TomC843[QUOTED] likes this.
  11. Apr 20, 2020 at 5:51 AM
    aggie_tundra
    2021 2500 Custom
    ah i thought it was a crewmax at first glance. You're right though, looks like a double cab now that i look at it
  12. Apr 20, 2020 at 6:03 AM
    4Yotasince99
    Eric
    So on that JL amp... the set screws that hold the speaker wire... that little tiny speaker wire on those harnesses was tricky to get those set screws to bite down on it, had several that I had to try 2 or 3x before I could pull on it and it not come out. When I first energized/ tested the system, my left rear door was quiet and sure enough when I looked, that wire had popped out of the amp. I’m now thinking I should’ve crimped little blades on the ends of the speaker wire harness and put those into the amp. What has everyone else seen or done on this?
  13. Apr 20, 2020 at 7:25 AM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    Trim off an inch of insulation. Then fold the wire back and twist thus giving you double the wire . Can put a dab of solder if you want.
    1lowlife and AZBoatHauler like this.
  14. Apr 20, 2020 at 7:53 AM
    newguy
    newguy New Member
    2016 CM TRD off road limited.
    TRD Dual Exhaut TRD Pro wheels BFG KO2 275/70/18 GoRhino RB20s Blacked out tail lights Bilstein 6112/5160 combo Coach builder +1 in the rear
    Where do you buy these?
  15. Apr 20, 2020 at 8:02 AM
    newguy
    newguy New Member
    I’m in the “plan of attack phase” here. My full speaker package arrived over the weekend from James and trying to put this together in my head first.
    When running the power wire from the amp to the firewall, where are you putting the wire? Are you running it through the passenger door jam?
    How about the speaker wire to the sub. Is that though the back passenger door jam as well? Or are you just feeding it under the carpet.
  16. Apr 20, 2020 at 8:24 AM
    TomC843
    Tom
    Charleston, SC
    DC
  17. Apr 20, 2020 at 8:24 AM
    TomC843
    Tom
    Charleston, SC
    yes, DC
  18. Apr 20, 2020 at 8:42 AM
    Kung
    KG, VA
    So to key in on something....
    To clarify, are you saying that anytime an aftermarket HU is installed, the stock microphones can't be used? If at all possible I'd like to keep the stock HU (even if this means installing a DSP/LOC), simply because with a new truck, side steps and a new sound system, National Command Authority (heh) is already fussing about the cost, even though it's out of a slush fund. LOL
  19. Apr 20, 2020 at 11:07 AM
    #49
    AZBoatHauler
    So.Arizona
    That is my understanding. To be honest though, it didn’t take more than a hour to pull the dash speaker and A-pillar cover run the wire and install the new mic in the stock location of the overhead console.
  20. Apr 20, 2020 at 11:13 AM
    #50
    AZBoatHauler
    So.Arizona
    This video shows the route I chose for the power wire to the amp.
    https://youtu.be/4IPB-SsbEsE
    For the sub wire, I ran it back in the door sill.
    Black Wolf and newguy[QUOTED] like this.
  21. Apr 20, 2020 at 11:23 AM
    #51
    DCB500
    DCB500 New Member
    David
    Oklahoma City
    There is a grommet with I “nipple” on the bottom side of it that allows you to push a wire through....you just have push something though it to poke it out and then cut the end off. Here are a couple of picks for where I ran my power wire, the second one is on the inside just above the driver kick panel.
    3248852A-405B-4E48-BFCA-35189116454B.jpg 7ABF02E0-1494-4878-BDA8-757B3E7F0524.jpg
    1lowlife likes this.
  22. Apr 20, 2020 at 11:33 AM
    #52
    Kung
    KG, VA
    Oh, well that's a tad different. I was thinking one of those cheesy aftermarket mics just hanging out there somewhere. Still, to keep it stock, I'd rather upgrade almost everything else first.
  23. Apr 20, 2020 at 11:41 AM
    #53
    DCB500
    DCB500 New Member
    David
    Oklahoma City
    You will not keep your stock microphone with the aftermarket HU but no extra cost, it should come with it. You can just run the wire out the side panel on the dash to the left of the steering wheel and the run it up the a pillar and the across the headliner over to above the RVM. This is where I have mine and no issues with people hearing me on the other end.
  24. Apr 20, 2020 at 9:43 PM
    #54
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Put mine very close to the same area.
    It sits at my fingertips and is easily adjusted and adjusted almost every song listening to crappy XM signal..
    4DD469E0-92EA-4AA9-8767-41A633C7CCDB_zps_451dd4d3f255df9429d73ebfca0747bb2817933d.jpg
    A13AB5B7-6F61-4853-AC2C-9200DA0D74AD_zps_5a20ccbc30e1815e784036136e6c444a382aaf31.jpg
    TomC843 likes this.
  25. Apr 20, 2020 at 9:46 PM
    #55
    1lowlife
    DADA
    2014 MGM DC SR5
    @DCB500 is correct, you can't use the stock mic with an aftermarket HU.
    Mine is tucked up with the mount clip, clipped to the headliner.
    Don't even notice it..
  26. Apr 20, 2020 at 9:52 PM
    #56
    ToyoMafia
    Magic carpet.
    Cool slaps and plastiDip
    Non jbl does not need Dsr1.
  27. Apr 21, 2020 at 7:44 AM
    #57
    FirstTruck
    FirstTruck New Member
    18 Tundra MGM CM TRD Sport
    Stock, for now
    Im not a professional at this. Im just saying because of what I have been learning.
    You are right. They do not NEED one. According to what I have been seeing on this installations you can go 2 ways. First leave the stock amp. With this setup you will be at the mercy of the amp for yr output sound, which is crappy and has a lot of drawbacks. Second option is to delete the amp and loose the dataBUS voice commands. Again its not a NEED. DSR1 will clean and organize the frequencies coming from the HU into the amps. Please correct me if Im wrong.
  28. Apr 21, 2020 at 8:02 AM
    #58
    DCB500
    DCB500 New Member
    David
    Oklahoma City
    If you are using the factory HU you will need a loc or DSP to get a usable signal. If you are using an aftermarket HU but not adding in your own amp then all you have to do is get the harness adapters for the behind the radio connections. You will have more sound adjustment with the aftermarket HU but you will still only have the factory amp power. If you remove the factory amp with aftermarket HU and use aftermarket amps then you will not need a LOC/DSR1/DSP.
    FirstTruck[QUOTED] likes this.
  29. Apr 21, 2020 at 8:03 AM
    #59
    ToyoMafia
    Magic carpet.
    Kinda correct. Never leave the stock amp lol. The dsr1 will improve the sound quality but I don’t run one in my truck and I keep my gain structure at 11 o’clock so the noise floor is not that bad. I don’t lose any functions not using a dsr1. With that said I installed a complete system yesterday in a 2018 jbl truck with a dsr1 and I have to admit it sounds better after tuning and setup. If you have a non jbl system and it’s worth the $300 to reduce the noise floor then by all means have at it.
  30. Apr 23, 2020 at 11:15 AM
    #60
    4Yotasince99
    Eric
    Ok, I could be wrong, but I swear before my install the compass on my driver display "twisted" as I drove to show direction/heading. It is now a stationary compass (north always up) with a red needle that spins around indicating the heading? Did I lose a setting when I disconnected the negative terminal all weekend doing my install? I've been through all the options, setup, etc. and can't find anything on the compass settings.
