*PLEASE VOTE HERE* Who DOES/DOES NOT have a leaking cam tower seal?
Discussion in '2.5 Gen Tundras (2014-2021)' started by BuckWallace, Feb 21, 2018.
Have you had a leaking cam tower?
  1. Yes - 2nd gen (07-13) Non-FFV
    16 vote(s)
    3.7%
  2. Yes - 2nd gen (07-13) FFV
    14 vote(s)
    3.2%
  3. Yes - 3rd gen (14+) Non-FFV
    34 vote(s)
    7.8%
  4. Yes - 3rd gen (14+) FFV
    19 vote(s)
    4.3%
  5. No - 2nd gen (07-13) Non-FFV
    34 vote(s)
    7.8%
  6. No - 2nd gen (07-13) FFV
    8 vote(s)
    1.8%
  7. No - 3rd gen (14+) Non FFV
    175 vote(s)
    40.0%
  8. No - 3rd gen (14+) FFV
    138 vote(s)
    31.5%
  1. Feb 22, 2018 at 9:17 AM
    #61
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    No, you should do the bypass until they extend the warranty to us 15's. Then take it off once they do.
    15whtrd[QUOTED] and TheBeast like this.
  2. Feb 22, 2018 at 9:20 AM
    #62
    TheBeast The Beach
    for the AIP, it's related to moisture right ? unless you drive through water often, we should be ok in california no ?
  3. Feb 22, 2018 at 9:27 AM
    #63
    Tacogrande
    Tacogrande New Member
    Jeremy
    2016 SR5 dbl. cab long bed gray
    Husky weatherbeaters,short antenna,window deflectors
    What about smoking pole?
  4. Feb 22, 2018 at 9:38 AM
    #64
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    I think it's both water and dust.
    TheBeast[QUOTED] likes this.
  5. Feb 22, 2018 at 9:45 AM
    #65
    71_340
    71_340 The German
    Hans
    FLW, MO
    That is about the dumbest thing I ever heard...."monitor". If it leaks it leaks and they need to fix it, especially on a near new truck. I wonder if that is Toyota's policy or the dealer's policy to "monitor"?
    With that said, I turned 5K this morning and after reading this thread went out and checked my truck. Not sure If I was looking at the right spot but I looked through the wheel wells at the front corner of each head (not where it mounts to the block but above that) and everything is bone dry and has gray silicone sealer. I bought a Tundra because I was tired of having my F-150s fixed under warranty on a regular basis, so far the Tundra has proven that I made the right decision and tomorrow it is going in for it's first oil change/service and for the EDR software update. I also found another recall for the center airbag which was published just two days ago, I hope they take care of that at the same time.
    BuckWallace[OP] and BTBAKER like this.
  6. Feb 22, 2018 at 10:02 AM
    #66
    Nike21
    Nike21 New Member
    2018 SR5 CrewMax TSS 4X4 Black Beast
    X2. Where do I look (not sure I want to :eek: ), and what bad things can happen because of this leak?
  7. Feb 22, 2018 at 10:07 AM
    #67
    BuckWallace
    BuckWallace [OP] Ball don't lie.
    Oregon
    Sierra 3500 AT4 L8T
    Look inside your wheel wells right above the exhaust manifolds. The first picture is of mine (not leaking), and the second picture is of someone's leaking (not mine).
  8. Feb 22, 2018 at 10:23 AM
    #68
    15whtrd
    15whtrd Mr. Blonde
    It’s just confusing. I've read something to the effect that if the dealer does an update of the ECU that makes the pump run for less time that it deems the bypass useless at that point.
    So please correct me but all the bypass does is fool the ECU that the pump is still working even if it fails? Which is why I thought about doing the relocate as to help prevent it failing in the first place. But then if you wait and the pump does fail you can’t use the bypass anyways because the pump gets stuck in the open position? My brain hurts LOL
    So maybe I should just put the bypass on if I get called in for a recall remove the bypass kit? Would I then reinstall the bypass kit after they did a recall?
    Then of course you have the dealer that likes to do things as a “favor” while you’re in there for something else. Like “hey bud we just updated your ECU for you while you were in for a service” LOL
  9. Feb 22, 2018 at 10:50 AM
    #69
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    LOL, yeah, I meant do the Relocate, not the bypass. I believe they've extended the warranty to the 2012's now. I'm gonna relocate mine soon. Hopefully it lasts until they extend the warranty to the 15's.
    TheBeast and 15whtrd[QUOTED] like this.
  10. Feb 22, 2018 at 11:10 AM
    #70
    Jettech
    Jettech New Member
    Jesse
    Nashville, TN
    08' Tundra CM
    TRD Exhaust, DC 305/55/20s, TRD PRO Shocks, HID's, JOBOX, Bully Dog Tuner, TRD sway bar, Shorty FM Int,
    2008 with 128K. No Leaks.....My engine has the grey/ tan gasket sealer for the tower. Sounds like this is more of a problem on the 3rd gen's. Correct?
  11. Feb 22, 2018 at 2:45 PM
    #71
    BuckWallace
    Oregon
    Sierra 3500 AT4 L8T
    Yeah, it seems like more people are having the issue with 3rd gens. It seems like if this affected the 2nd gens equally we'd be seeing a whole lot more since they've obviously been on the road a lot longer.
  12. Feb 22, 2018 at 4:19 PM
    #72
    Casper3
    Casper3 New Member
    Jay
    CT/OH
    2017 Super White 5.7 SR5 TRD off road
    Someone correct me if I'm wrong, but aren't the orange arrows indicating the valve cover gasket/leak and red arrow the cam tower seal? Which in your picture seems to have some residue or maybe just dirty.:notsure:20180222_190559.jpg
    Watt maker and BTBAKER like this.
  13. Feb 22, 2018 at 4:55 PM
    #73
    Alloutdrs1
    Alloutdrs1 New Member
    Andrew
    Virginia Beach, VA
    Orange arrow is the valve cover, your red arrow needs to move up some to the gray bead of sealant directly under the little bump out with the hole in it.
  14. Feb 22, 2018 at 4:58 PM
    #74
    Casper3
    Casper3 New Member
    Jay
    CT/OH
    yeah excuse my sloppy arrow Lol
    TheBeast likes this.
  15. Feb 22, 2018 at 5:07 PM
    #75
    YTThao530
    YTThao530 New Member
    2015 is the best! lol
    15whtrd likes this.
  16. Feb 22, 2018 at 5:08 PM
    #76
    Casper3
    Casper3 New Member
    Jay
    CT/OH
    So this is wrong? Someone else posted this picture Screenshot_20180222-200434.jpg
  17. Feb 22, 2018 at 5:23 PM
    #77
    careyrob
    careyrob In the field
    Carey
    Massachusetts
    2008 Crewmax TRD 4x4 Silver
    LRO 3/1 leveling lift 35x12.50's on 20x9's Hellwig rear sway bar B&M 70264 SuperCooler Transmission Cooler Firestone airbags Daystar cradles Air Lift WirelessONE Compressor System
    2008 with just over 160k. No leaks.
  18. Feb 22, 2018 at 5:40 PM
    #78
    TheBeast The Beach
    my buddy with a 2011 rock warrior does not have it. I just checked :spy:
  19. Feb 22, 2018 at 6:19 PM
    #79
    BuckWallace
    Oregon
    Sierra 3500 AT4 L8T
    Here's a little bit better view. I kind of thought what you were thinking at first, but that's just dirt/discoloration from the heat. You can see the gray sealant beads inside the orange circle.
    Watt maker and Casper3[QUOTED] like this.
  20. Feb 22, 2018 at 6:27 PM
    #80
    Casper3
    Casper3 New Member
    Jay
    CT/OH
    I'm just thankful I have neither leaking, at the moment :pray:
  21. Feb 22, 2018 at 7:53 PM
    #81
    71_340
    71_340 The German
    Hans
    FLW, MO
    You would think that Toyota uses some upgraded sealant, ideal would be a groove with a continuous o-ring style gasket. I just check mine every once in the while now and if it leaks they just have to fix it. I am going on a 700+ mile round trip Saturday, that will put the engine to the test.
    Stroke250 likes this.
  22. Feb 22, 2018 at 8:46 PM
    #82
    BuckWallace
    Oregon
    Sierra 3500 AT4 L8T
    I wish I had your attitude! If it were any issue that didn't involve breaking into the engine I don't think I'd really worry about it, but it just makes me cringe thinking of driving around with a molested top end.
  23. Feb 22, 2018 at 11:11 PM
    #83
    Alloutdrs1
    Andrew
    Virginia Beach, VA
    I had the same thought, a grove with a gasket in it would of been ideal.
    Exactly!
    Watt maker likes this.
  24. Feb 22, 2018 at 11:21 PM
    #84
    Alloutdrs1
    Andrew
    Virginia Beach, VA
  25. Feb 23, 2018 at 2:42 AM
    #85
    Adam New Member
    How many of these leaks have actually been an issue? I have had other cars and trucks in my life were, yeah, there is a little drip of oil here or there. It wasn't a bomb ready to go off. I drove it. Everything was fine. What is this hurting when there is a leak found? Is indicative of oil getting where it isn't supposed to?
  26. Feb 23, 2018 at 3:21 AM
    #86
    Les7311
    Les7311 Look up, what do you see
    2008 Blue Tundra TRD 4x4
    I had same picture leak which happened to be the Valve Cover Gasket.
    08 bought with 121k
    DIY on the weekend —- piece of cake.
    https://www.tundras.com/threads/changing-valve-cover-gaskets.10035/
  27. Feb 23, 2018 at 3:25 AM
    #87
    Les7311
    X2.....
  28. Feb 23, 2018 at 5:03 AM
    #88
    Alloutdrs1
    Andrew
    Virginia Beach, VA
    Biggest issue I have read about is it starts dripping onto the manifolds and burning because of the location of the leak. As for frequency of how much it leaks that's more shooting in the dark. Some just seep and I have read of others that leaked a bunch, mine has lost 1/2qt in 6k miles for example. If it was an older truck with say 100k plus miles it would be a little more acceptable, but trucks that are not even a year old leaking is ridiculous.
    2018TundraLimited and BTBAKER like this.
  29. Feb 23, 2018 at 6:32 AM
    #89
    Hattori
    Hattori STOP SHIMMING COILOVERS!!!!
    Tommy
    Nashville
    2012 Tundra CM TRD
    Me.......
    142k with no leaks. Holla!
  30. Feb 23, 2018 at 6:55 AM
    #90
    RonW
    RonW New Member
    No leaks. 2018 with about 6500 miles.
