Pickup bed lean…bad leaf bushing, shock?
Discussion in '1st Gen Tundras (2000-2006)' started by Jack McCarthy, May 8, 2022.
  1. Nov 24, 2022 at 7:10 AM
    #121
    Jack McCarthy
    Jack McCarthy [OP] It’s always the fuel filter
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    I’m only doing one at a time as needed. All the bolts are seized in the nut welded to the frame due to rust so unless I can jack the side up 6 inches to clear an impact wrench, I’ll just be cutting them off and replacing with grade 8 lock nuts.
  2. Nov 29, 2022 at 11:58 AM
    #122
    Richid
    Richid New Member
    Wow - didn't realize this thread was still alive...
    If you need space, loosen the other mounts on that side. I did the same thing at first, used a old bent box wrench to remove the mount - what a waste of time. Once it was loose, I realized I needed more space to get the new mount in.
    If you loosen the other mounts on that side, you can easily lift the cab 6 or more inches.
    Hope that saves someone some time in the future.
  3. Nov 29, 2022 at 12:00 PM
    #123
    Jack McCarthy
    Bill
    North of Boston
    Not so easy when the bolt is rusted into the nut welded to the frame.
  4. Nov 29, 2022 at 12:05 PM
    #124
    Richid
    Richid New Member
    Just loosen the center bolts on the other mounts and jack the cab up, the only mount you need to remove the frame bolts on is the one being replaced.
  5. Nov 30, 2022 at 7:55 AM
    #125
    azimuth
    azimuth New Member
    2010 double cab SR5
    I had a sag on my 2000 Tundra. It started around 20 years old. It exhibited many of the symptoms you described. Turns out it was the leaf spring pack failing. Replaced them both and straightened it right up.
    Jack McCarthy[OP] likes this.
