Phone mount
Discussion in '2.5 Gen Tundras (2014-2021)' started by ErikTRDTUNDRA, Feb 4, 2021.
  1. Feb 14, 2021 at 4:30 PM
    Rockgate
    Rockgate New Member
    Terry
    Middle TN
    2022 CMLB TRD OR Prem. 4X4 and 2002 RCLBV65Spd
    I rock a Moto Edge plus with a clear case. I put the metal plate, inside the case and stuck to the case. No problems of it coming off yet. I'm using the bigger of the 2 metal plates. But no hardcore off-roading either.
  2. Feb 15, 2021 at 9:36 AM
    Do you know if you can get the charger power straight from the USB port or do you have to use the cig lighter adapter? The 2020 only has 1 port and my dash cam uses it.
  3. Feb 15, 2021 at 9:43 AM
    Rustedfenders
    Rustedfenders If it ain't broke, don't fix it.
    Wally
    Rosedale Md.
    2016 Blazing Blue Pearl TRD Tundra Crew Max
    Aries 4" Bull Bar, 3-2 Level Lift Havoc Stainless hoop steps.
    Should be able to use the USB port. It comes with the cable.
  4. Feb 15, 2021 at 10:26 AM
    Thanks!!
  5. Feb 18, 2021 at 10:47 AM
    vl184009
    vl184009 Cheers Boys!
    Vicky
    Southern, Ca.
    2016 MGM CM SR5 4x4 w/Tow Pkg
    Just got a Scosche mount, love it. Not that I do any off roading or anything crazy, but phone doesn't shake or vibrate at all. I can pivot it any which way I want, and the magnet is rock solid.
    Rica25, Rockgate and chuffaluffigus like this.
  6. Feb 18, 2021 at 11:39 AM
    chuffaluffigus
    chuffaluffigus New Member
    2021 Limited
    Same one I have, and I put it in exactly the same place. I love it. Perfectly places the phone right next the main vehicle screen, easily accessible, doesn't block any controls, and doesn't block any vents. Perfect IMO.
    Boerseun likes this.
  7. Feb 18, 2021 at 11:44 AM
    Boerseun
    Boerseun MGM XP-Series
    Ferdie
    Sarasota Florida
    That's what I have also. I have the plate on the inside of my phone cover, and even with that the magnet is still strong enough to hold it even while off-road.
    I just got one for my daughter also.
  8. Feb 18, 2021 at 1:05 PM
    Minarets
    Minarets New Member
    Nashville
    2021 TRD PRO
    Same spot for me. It’s perfect.
  9. Feb 18, 2021 at 1:14 PM
    ezdog
    ezdog New Member
    Gateway To The West
    Perfect unless you have the Column Shifter at least!
    Not so much though if you do.
    Gabrielo93 and Minarets[QUOTED] like this.
  10. Feb 18, 2021 at 3:48 PM
    2010bigdog
    2010bigdog New Member
    Chuck
    Chicago
    2018 MGM SR5 TRD
    where did you order from ? how much ?
  11. Feb 26, 2021 at 10:16 AM
    ManFam
    ManFam New Member
    King of Prussia, PA
    2015 Tundra TRD Pro
    burtlively likes this.
  12. Apr 15, 2021 at 8:33 AM
    burtlively
    burtlively New Member
    2017 Tundra 4x4 CrewMax Platinum
    3AB40295-4D7C-438E-9D87-8F2FD774CF85.jpg 9B41BB73-D816-42A5-A119-E6BE0AC88ACE.jpg
    I second the Offroam mount. Very solid. Easy to install with no modifications needed. Doesn’t move at all in normal driving circumstances. I wouldn’t consider anything else. Just my 2 cents.
    Lassie likes this.
  13. Apr 15, 2021 at 9:38 AM
    vl184009
    Vicky
    Southern, Ca.
    Amazon, it was like $11.00 bucks. They have another which is the exact same one but claim the magnet is stronger for $20.00 but honestly, this one is totally fine...
  14. Apr 15, 2021 at 8:19 PM
    Minarets
    Minarets New Member
    Nashville
    2021 TRD PRO
    Won’t be cheap but considering a Mous case for iPhone and their wireless charger pad that can mount on dash of the Tundra and then get wireless CarPlay. Hmmm may consider that.
    https://youtu.be/HRtE_05r-Zg
  15. Apr 15, 2021 at 9:13 PM
    Avi8or
    Avi8or New Member
    Johann
    MO
    2020 Limited Crewmax
    ProClip is where it’s at. Been using them for a while and they are great. They make vehicle specific mounts that have stay put for me so far.
    Sumo91 likes this.
  16. Apr 16, 2021 at 6:18 AM
    Minarets
    Minarets New Member
    Nashville
    2021 TRD PRO
    It’s very nicely built. I just don’t care for it’s placement.
  17. Apr 22, 2021 at 4:20 PM
    GaFFLe
    GaFFLe New Member
    Atlanta, GA
    2020 Toyota Tundra Platinum
    Undercover bed sway cases
    THE ABSOLUTE BEST phone holder for your Tundra... NO DOUBT!
    It auto-opens and closes with infrared movement and has a very, VeRy tightly integrated fit within the dashboard. You'll never knock this thing off. Oh yeah, it wirelessly charges too if your phone supports that. https://www.amazon.com/ProHolder-Co...ords=tundra+pro+holder&qid=1619133434&sr=8-10
    TRDFerguson likes this.
  18. Apr 22, 2021 at 4:44 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    those are great with a smooth surface to mount. There is even a cleaner version.
  19. Apr 22, 2021 at 5:10 PM
    #49
    Kevin80
    Kevin80 New Member
    2016 SR5 Crewmax
    Another vote for Pro Clip... definitely on the expansive side but it’s rock solid and it has outlasted previous mounts by a long shot.
    GaFFLe likes this.
