PCV Valve Replacement Instructions-4.7L
Discussion in '1st Gen Tundras (2000-2006)' started by FirstGenVol, Jan 14, 2019.
  1. May 11, 2025 at 9:55 PM
    #91
    Fragman
    Fragman New Member
    TX
    2006 Tundra DC SR5 2WD V8
    Ha. Just did mine today. Still 'rattled', but definitely a little black. Given how quick it is to do and how reasonable the part it OEM, I guess I would suggest just doing it same time as the timing belt.
    FrenchToasty likes this.
  2. May 12, 2025 at 3:45 AM
    #92
    I want to say Toyota calls for every 30k? Or maybe 50k. I forget but looked it up at one point.
    Fragman[QUOTED] likes this.
  3. May 12, 2025 at 7:57 AM
    #93
    Fragman
    Fragman New Member
    TX
    Well dang, I guess every 90k won't cut it! Maybe when you do the diff fluid would be better.
    It's a 10 minute job and about a $10 to $11 part (even less in a '25 percent off' sale). Can do it while the fluid is draining.
  4. May 12, 2025 at 7:58 AM
    #94
    I'd probably say to change PCV valve at same time as the rear diff vent. As long as you're not towing and thus doing diff juice every 30k per the book, maye a good time. Or every other diff juice change would likely be fine also.
  5. May 21, 2025 at 9:27 AM
    #95
    Tamarack
    Tamarack New Member
    2005 Tundra 4.7 TRD AC (Green)
    Unmodified
    You show two vent hoses in your cart here. I ordered the pcv vent hose at my dealer (by phone), will pickup this weekend. But it was just one that I ordered (for my 05 4.7 TRD). Is there another one is should order?
    (Sry for typos, fixed)
  6. May 21, 2025 at 11:23 AM
    #96
    For some reason I can't find the post you quoted of mine ... so I can't comment on that.
    Wait, it's on last page. I found it. There are two PCV hoses as I explain in that post. I also tell you which # is which. #2 is passenger side. #1 is driver side. Eliminate which one you ordered from dealer, and order the other one, I think?
    Tamarack[QUOTED] likes this.
