Parts hoarding build
Discussion in '2.5 Gen Builds (2014-2021)' started by Sterlinglwood, Apr 10, 2018.
  1. Jun 11, 2018 at 2:56 PM
    #61
    Sterlinglwood
    Sterlinglwood [OP] Never enough!
    Sterling
    Newbury Park, CA
    2017 Tundra Double Cab SR5 4X4
    Took her out for a quick spin. Felt pretty good. Mid settings all around on DSC. Skipping leg day sucks! Wheels are almost here.
    jewsNbrews likes this.
  2. Jun 11, 2018 at 3:31 PM
    #62
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    Looks great!
  3. Jun 11, 2018 at 3:40 PM
    #63
    Sterlinglwood
    Sterling
    Newbury Park, CA
    Thanks man!
  4. Jun 11, 2018 at 3:58 PM
    #64
    VinnyEsq
    VinnyEsq New Member
    What's an estimate on the cost for the lift?
  5. Jun 11, 2018 at 4:38 PM
    #65
    Sterlinglwood
    Sterling
    Newbury Park, CA
    There are so many different lifts you can do and get the same look but different capabilities. I chose this setup based on tons of research, intended use and quality. The lift was installed by me which saves on labor. There is no limit to how much money you can put into these trucks. Look up Fox factory series w/dsc for cost plus shackles and spacers etc.
  6. Jun 11, 2018 at 7:38 PM
    #66
    Sterlinglwood
    Sterling
    Newbury Park, CA
    Chrome delete has begun..
    Juddrussell, TomC843 and jewsNbrews like this.
  7. Jun 12, 2018 at 7:48 PM
    #67
    Sterlinglwood
    Sterling
    Newbury Park, CA
    Loving this setup! Waiting on black trd shift knob.
    Finally put on the grille. Huge chrome death ray is gone! Going to work on bumpers after this weekend. Spyder’s were delivered and put on in about an hour. Motors installed and manually adjusted at mid level setting. Eventually going to get HID kit from Toytec.
  8. Jun 12, 2018 at 8:05 PM
    #68
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    How long did the shifter area take to dechromed? How hard/easy is it to take apart?
  9. Jun 12, 2018 at 8:06 PM
    #69
    Juddrussell
    Juddrussell New Member
    Jacob
    Bentonville, AR
    2016 MGM Tundra TRD Pro
    BAMF Bedrack, 295/70/r18 General Grabbers, Bedslide, Weathertech floor mats, and Tepui Autana Sky RTT.
    Nice! I am doing the same thing right now, what paint did you end up going with? Looks great!
  10. Jun 12, 2018 at 8:29 PM
    #70
    Sterlinglwood
    Sterling
    Newbury Park, CA
    Had a hell of a time getting the cover off. Didn’t realize it was the whole part and not just the silver area. Hardest part is masking and not bridging. Did 5-6 coats starting light to a little heavy. Still use a razor when pulling tape off very slowly.
  11. Jun 12, 2018 at 8:32 PM
    #71
    Sterlinglwood
    Sterling
    Newbury Park, CA
    It’s Plati Dip. No sanding or anything like that. Cleaned surface with isopropyl alcohol. Most important is the masking
  12. Jun 12, 2018 at 8:34 PM
    #72
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    Thanks. I want to do the same, along with the vents.
  13. Jun 12, 2018 at 8:40 PM
    #73
    Sterlinglwood
    Sterling
    Newbury Park, CA
    Me too. But I was like “shit then I have to do the door trim, the handles etc.” maybe eventually.
  14. Jun 12, 2018 at 8:50 PM
    #74
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    I just want the chrome gone. The grey is ok for now. May decide on a different secondary color but if I did it all black I think it would be too much for me. I just can't stand the glare off of the chrome pieces at just the right angles. Was almost thinking a red or blue color for the secondary pieces.
  15. Jun 12, 2018 at 8:53 PM
    #75
    Sterlinglwood
    Sterling
    Newbury Park, CA
    Not really a big fan of Fox’s newer single collar design. I know you’re supposed to remove the coilover to make adjustments but have also heard it’s possible on the truck. Just trying to get a 1/4” after barely loosening collar lock maybe got a third of the way around with full droop and this started happening.
    3/16” fits perfect but it looks like I’m going to need a spring compressor. Got spooked about jumping threads or not being able to tighten the collar back down.
  16. Jun 12, 2018 at 8:55 PM
    #76
    Sterlinglwood
    Sterling
    Newbury Park, CA
    I was thinking of using some sort of paint pen for the rings. Gotta look into it more.
  17. Jun 12, 2018 at 9:05 PM
    #77
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    Keep me posted on that, I would be interested in that as well.
  18. Jun 14, 2018 at 12:03 AM
    #78
    Sterlinglwood
    Sterling
    Newbury Park, CA
    Haha didn’t realize how much my wife was watching..
    Mater and jewsNbrews like this.
  19. Jun 15, 2018 at 11:23 AM
    #79
    Bates5450
    Bates5450 Elephantitus
    Jacob Bates
    Dickinson, ND
    2018 SR5 CM Cement 4x4
    Looking good @Sterlinglwood, looking forward to seeing your continued de hoarding of parts! I think you've pushed me over the edge on painting chrome trim pieces in the interior those look great.
    Sterlinglwood[OP] likes this.
  20. Jun 15, 2018 at 4:44 PM
    #80
    Sterlinglwood
    Sterling
    Newbury Park, CA
    Little break in Vegas. Cheers!
    Jsena and jewsNbrews like this.
  21. Jun 15, 2018 at 4:50 PM
    #81
    TheBeast The Beach
    ha ! same happened to me with my Kings. @Vizsla @Samoan Thor
    https://www.tundras.com/threads/adjusting-king-front-coil-overs-for-tundra-lean.21143/
  22. Jun 16, 2018 at 6:36 PM
    #82
    Samoan Thor
    Samoan Thor God is technically an alien
    Limited 2014 crewmax 4X4
    Kings F&R, no sway bars
  23. Jun 16, 2018 at 8:20 PM
    #83
    Sterlinglwood
    Sterling
    Newbury Park, CA
    CB bumper shims on
    Coachbuilder1 likes this.
  24. Jun 16, 2018 at 10:26 PM
    #84
    Sterlinglwood
    Sterling
    Newbury Park, CA
    Front caps in progress..
    Erichudgins and 4x4_Angel like this.
  25. Jun 17, 2018 at 3:48 PM
    #85
    Sterlinglwood
    Sterling
    Newbury Park, CA
    Turned out really good! See how long they hold up. On to the rear bumper now.
    TheBeast likes this.
  26. Jun 17, 2018 at 9:38 PM
    #86
    Sterlinglwood
    Sterling
    Newbury Park, CA
  27. Jun 17, 2018 at 11:16 PM
    #87
    Sterlinglwood
    Sterling
    Newbury Park, CA
    Well my wife was not happy with the ride after the lift. It is a little harsh even on mid settings. Pulled over and backed out the DSC and WOW!! She couldn’t believe the difference in the ride. Very happy I went with adjustable suspension. Really does make a difference. Rode like a Cadillac on our 600 mile drive. Crank em up when it’s time for desert runs.
  28. Jun 18, 2018 at 3:56 PM
    #88
    da_jeep_luva
    da_jeep_luva New Member
    Paul
    2017 CM and 2008 RCSB
    TRD Pro suspension, powder coated bumpers, wheels, tires, lowered, coated, list keeps going.
  29. Jun 18, 2018 at 5:53 PM
    #89
    Sterlinglwood
    Sterling
    Newbury Park, CA
    TRD knob looks good!
    Rica25, jewsNbrews and TheBeast like this.
  30. Jun 18, 2018 at 6:35 PM
    #90
    Sterlinglwood
    Sterling
    Newbury Park, CA
    Back bumpers done
