Painting Brake Calipers
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by TruPatriot, Apr 6, 2021.
  1. Apr 14, 2021 at 7:37 PM
    Dalandshark
    Dalandshark Infected with 5G
    Northwest
    2007 Tundra SR5 5.7 Longbed
    Eibach Level Lift, DIY SAIS preventer, headers.
    You can use regular ol rust oleum, but then people look at you like your truck is about to burst into flames due to slight plume of smoke. On the bright side, it holds up really well. Not recommend unless you want your truck to possibly catch on fire. :bananadead:
  2. Apr 15, 2021 at 4:05 AM
    Badknees
    Badknees New Member
    South Carolina
    2016 White Tundra 1794 CM 4X4
    TRD Pro BBS Wheels, TRD LED Headlights, Rigid LED Fog lights, 040 TRD Grille, 040 Hood Bulge, Black Center Valence, Driver's Grab Handle, TRD Pro Fox Suspension, 1.00" BORA Wheel Spacers, 1.5" Rear Shackles, TRD Front and Rear Sway bars, 295/70 R18 Cooper Discoverer AT3 XLTs, Full Size Spare, TRD Dual Exhaust, Console cover, Console Organizer, Husky Liner X-act Contours, Tinted Front Windows, Stubby Antenna, Autoventshade Deflectors, Duplicolor Painted Calipers, 040 Painted Front End Caps, Undercover Armor Flex Bed Cover
    I had about 1/2 of can left over after (4) calipers, but only had the time and patience to paint 2 coats. It is tedious work painting by hand and took me about 30 minutes for one coat on each caliper. I would imagine the spray paint is an easier job. The single small can of brake cleaner wasn't enough for me and I used another large can from Advance Auto.
    Kbar691[QUOTED] likes this.
  3. Apr 15, 2021 at 4:24 AM
    Badknees
    Badknees New Member
    South Carolina
    Sorry, missed this question and Thanks for the compliment:
    I don't profess to being an expert on painting calipers, but here's what I did to prep.:
    * Used the brake cleaner supplied with the kit and one more can to clean the calipers.
    * While wet with cleaner, I used a small wire brush to try and clean-off any extra dust/dirt.
    * Probably not necessary, but used a rag with rubbing alcohol to wipe off the calipers and just to be sure of good paint adhesion.
    * Taped-off completely around the calipers, rotors, and dust shield using 3M 2" painter's tape (if you spray, you'll need to tape-off more area, of course).
    * Taped-off the rubber caliper parts and bolt heads.
    * Taped-off the caliper opening where you access the brake pads for replacement.
    * Taped-off the front-facing S.S. brake pad shield on the rear brake caliper.
    * Taped-off speed sensor cable and brake line leading to caliper.
    * Of course, you will see there's places you just can't reach since the calipers are still bolted to the mounts. For the rear brakes, I did remove the front mount bolt, loosen the rear bolt, and tilted the calipers back for max. access. I left the front calipers alone and as mounted.
    Best of Luck and send us pictures when you're done!
  4. Apr 17, 2021 at 3:30 PM
    TruPatriot
    TruPatriot [OP] New Member
    Lee
    Northeast Texas
    2020 TRD Pro MGM Mall Crawler & Trail Riding Queen
    Ahh...thank you for the tutorage!
  5. Apr 20, 2021 at 1:19 AM
    reimord
    reimord New Member
    I did mine using VHT also. This paint is long-lasting and forgiving.
  6. Apr 20, 2021 at 8:10 PM
    copmagnet82
    copmagnet82 Member
    Paul
    Chicago
    2010 SR5 & 2021 TRD Pro
    I recently painted my calipers with VHT on my 2010, followed by baking to cure the paint, and personally, I will never use that paint again. I've had beyond good luck with G2 and I should have never switched. Live and learn. IMHO there is no comparison between regular caliper pain and G2 when it comes to durability and chip resistance.
  7. Apr 20, 2021 at 8:39 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    Anyone paint their drums with VHT? Or is that just stupid?
  8. Jun 19, 2021 at 5:48 PM
    TruPatriot
    Lee
    Northeast Texas
  9. Jun 19, 2021 at 5:49 PM
    TruPatriot
    Lee
    Northeast Texas
    Got the front done…rear tomorrow
  10. Dec 8, 2021 at 5:39 AM
    TrdPro89
    TrdPro89 New Member
    This is the best way in my opinion. Less mess than spray paint and dries up fast.
  11. Dec 12, 2021 at 5:40 PM
    Bajis
    Bajis New Member
    2016 Tundra Limited 4x4 MGM
    Trd suspension, RW wheels, 33’s
    Red goes hard
  12. Mar 4, 2022 at 6:40 AM
    DoublePro
    DoublePro New Member
    I end up using a rattle can, high temp black gloss. I didn’t want the silver calipers to show through. Even on the black wheels, if kinda stick out like a sore thumb.
  13. Mar 4, 2022 at 8:29 AM
    Scud
    Scud New Member
    San Francisco Bay Area
    2017 1794 Tundra Super White
    Working on it :-)
