OVERSIZED spare: Let's see how/where you carry when wheeling
Discussion in 'General Tundra Discussion' started by Eclipsed & Floating, Apr 3, 2017.
  1. May 3, 2017 at 10:48 AM
    #91
    osidepunker
    osidepunker OsidePunker
    Alex
    2013 Tundra DC 4x4
    Full LT, full armor, fully self contained Speed Glamper
    I use aircraft rails to strap everything down in the bed. Works well. Got them from US Cargo Control
    dcsleeper408 and Jsena like this.
  2. May 3, 2017 at 10:57 AM
    #92
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 Long Travel DC
    Alex, that platform your RTT is on, does it lift up with the RTT on it? Where did you get it?
  3. May 3, 2017 at 11:01 AM
    #93
    osidepunker
    Alex
    2013 Tundra DC 4x4
    It's hinged on the passenger side and lifts to 90 degrees with a 12v actuator. I designed it and DMZ Fab and Race Prep fabricated it for me. Its an easy way to keep the weight of the tent and awning low to the ground and still be able to lift it and get access to my gear. Hold on let me find a pic
    dcsleeper408 and joonbug[QUOTED] like this.
  4. May 3, 2017 at 11:02 AM
    #94
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    I need my spare to stay under my truck.. I like the bed empty for throwing shit in it
  5. May 3, 2017 at 11:05 AM
    #95
    osidepunker
    Alex
    2013 Tundra DC 4x4
  6. May 3, 2017 at 11:09 AM
    #96
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 Long Travel DC
    That is awesome. Mind if I ask what it cost you? I was thinking something similar, just wouldn't know how to go about making one.
    osidepunker[QUOTED] likes this.
  7. May 3, 2017 at 11:16 AM
    #97
    osidepunker
    Alex
    2013 Tundra DC 4x4
    1500 for the fabrication and 400 for the actuator.
    I'll give you the plans for a case of bud light... jk
    joonbug likes this.
  8. May 3, 2017 at 11:22 AM
    #98
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 Long Travel DC
    Do you think it would work manually, without the actuator?
    dcsleeper408 likes this.
  9. May 3, 2017 at 11:25 AM
    #99
    osidepunker
    Alex
    2013 Tundra DC 4x4
    Depends on how you cycle, with steroids or just creatine.
    I tried without the actuator. Me and a buddy could not lift a 220lbs RTT and awning and rack. My new RTT is 100 lbs less, but I wtill wouldn't want to.
  10. May 3, 2017 at 11:27 AM
    #100
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 Long Travel DC
    LOL Thanks Alex, I'm keeping this in mind when it's time for my RTT.
  11. May 3, 2017 at 11:31 AM
    #101
    n2deep
    n2deep Pavement Princess
    Not one but two full size spares. Don't need the second one until you do. Lol.
  12. May 3, 2017 at 1:26 PM
    #102
    Dustydirt19
    Dustydirt19 Hoghead
    Dustin
    Duluth, MN
    2015 Blue Ribbon Metallic 5.7L 4WD SR5 TRD DC
    ProComp 6" stage 2 lift 18x9 Fuel Vapor -12 offset 35x12.5 Nitto Ridge Grapplers BullyDog Tuner Gibson Metal Mulisha cat-back exhaust, S&B cold air intake, Color matched TRD PRO Grille, Compustar Remote Start N-Fab Hooped Nerf Bars, AMI Big stick antenna, Salex organizer and tray, Weathertech laser cut floor mats, Weathertech window deflectors Black out badge Black out front and rear bumper Black out flags 24/7 black out TRD Off-road decals Spray in Line-X Bedliner Scosche phone mount Soft rolling tonneau cover TRD pedals and footrest
    I'm sorry I meant if you mounted a 35 on the stock spare rim. With a 6in lift maximum B.S. is 5in. You don't have that with the spare. I believe you need this backapacing because of the new spindles. So if your front went flat you'd have to put one of your rear tires up front and then the spare on the back. Correct?
  13. May 3, 2017 at 3:18 PM
    #103
    LibertySand
    LibertySand IH Support Rig
    Montclair, CA
    07 TRD DC 5.7 Tow 4X4
    Ahhh, Yes. Correct-ish. You'd be safe to say you could still mount a 35" Tire on a stock rim and run it, just won't be able to turn tight. About the tire hitting the Spindles....not sure. I don't know the answer to that one.
  14. May 3, 2017 at 3:36 PM
    #104
    Dustydirt19
    Dustydirt19 Hoghead
    Dustin
    Duluth, MN
    Why wouldn't I be able to turn tights?
  15. May 3, 2017 at 4:34 PM
    #105
    CM-LENNY
    CM-LENNY No Complaints
    San Diego, CA
    2015 4x4 CrewMax SR5
    PRO shocks, 37's Nitto G2's 4:88 diffs, few other mods
    I thought I was pretty creative on my truck. That's just bad-ass Alex. Nice design/nice truck !
  16. May 3, 2017 at 4:37 PM
    #106
    CM-LENNY
    San Diego, CA
    Nice job Jason ! Love how you took the time to design a rack that holds so much in a small space. Great work !
  17. May 4, 2017 at 8:46 AM
    #107
    LibertySand
    Montclair, CA
    Because like the same reason for the tire rubbing on the Top Spindle, the Tire will rub on the Inner Cab Mount or the Inner Bumper at full bump unless the tire is back spaced correctly or you put wheel spacers on.... this is if you are stock height.
  18. May 4, 2017 at 8:47 AM
    #108
    LibertySand
    Montclair, CA
    Thank you. I sit in a lot of traffic everyday so I had a lot of time designing it in my head. Lol
  19. May 4, 2017 at 9:22 AM
    #109
    Dustydirt19
    Dustydirt19 Hoghead
    Dustin
    Duluth, MN
    Oh yeah that I understand. That's why said if you get a flat in the front you could take one of your rear wheels and replace the flat and put the spare on the back. To get to where you're going.
  20. May 5, 2017 at 11:50 AM
    #110
    Dustydirt19
    Dustydirt19 Hoghead
    Dustin
    Duluth, MN
    Am I correct in assuming this ^^^^
  21. May 5, 2017 at 11:57 AM
    #111
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 Long Travel DC
    Yes but now you're going to put stress on your rear diff.
    zcarpenter92 likes this.
  22. May 5, 2017 at 12:37 PM
    #112
    Dustydirt19
    Dustydirt19 Hoghead
    Dustin
    Duluth, MN
    Even if I throw a 35 on the spare rim? I just know I can't use the spare in the front cause of the backapacing. That's why I'm wondering if this would work. Rather than buying a 5th wheel and tire
  23. May 5, 2017 at 1:24 PM
    #113
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 Long Travel DC
    No, it would be fine with a 35. But if you were going to go through all the trouble and buy a 35 tire anyways, I would just buy another wheel. Plus, you would have to carry around a different set of lugs too.
  24. May 5, 2017 at 1:46 PM
    #114
    Dustydirt19
    Dustydirt19 Hoghead
    Dustin
    Duluth, MN
    Why would I need new lugs? I guess I just didn't want to spend the money on a new rim that's gonna sit underneath my truck. I figured if I got a cheap 35, throw it on the spare I'd be good for an emergency situation just to get where i was going. This wouldn't be for off roading. This would be I have a blow out on the highway type situation
  25. May 5, 2017 at 1:47 PM
    #115
    Dustydirt19
    Dustydirt19 Hoghead
    Dustin
    Duluth, MN
    Will a 35 even fit? @joonbug you've got a 295 70 under there right? Fit no problem?
  26. May 5, 2017 at 1:48 PM
    #116
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 Long Travel DC
    If you have aftermarket wheels. Are you going to be on 35's with the stock wheels?
  27. May 5, 2017 at 1:49 PM
    #117
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 Long Travel DC
    Yeah, it's a tight fit but it's in there without hitting anything. Clears my Toytec shackles, CB shackles probably won't clear.
  28. May 5, 2017 at 1:55 PM
    #118
    Dustydirt19
    Dustydirt19 Hoghead
    Dustin
    Duluth, MN
    Yeah aftermarket wheels
  29. May 5, 2017 at 5:58 PM
    #119
    Eclipsed & Floating
    Eclipsed & Floating [OP] Over it.........
    I’m right where I need to be
    Voluptuous Whitey
    This is absolutely genius!
    @joonbug if you don't do this then I'm disappointed in you. I'll buy @osidepunker his case of sauce just so you have no excuse
