OVERSIZED spare: Let's see how/where you carry when wheeling
Discussion in 'General Tundra Discussion' started by Eclipsed & Floating, Apr 3, 2017.
  1. Apr 4, 2017 at 8:38 AM
    #61
    J4RR3N4
    J4RR3N4 New Member
    South east Texas
    14 Tundra
    3” lift on 35’s
    @LibertySand that rack is going to be tits. I remember you having a race style jack and skid plate thing on it. does it jack up high enough to lift the tires off the ground?
  2. Apr 4, 2017 at 8:52 AM
    #62
    dcsleeper408
    dcsleeper408 BASTRDS
    mark
    San Jose CA
    2015 TRD PRO
    Don't get me wrong. It works. I would say if you have a sturdy base to pull it off and bring it down to the ground safely then do it.
    I am not the strongest dude in the world but a 35" + rim can weigh up to 120lbs at most. Grabbing it and safely bring it down is not only dangerous but you can really hurt yourself or even the rig. And if you huck it off the roof.. well lol its gonna be fun if doesn't land flat.
    Wilco got some good options. look into them.. Prices are fair as well.
    @mac11 makes a really nice swing out.
    mac11 and J4RR3N4[QUOTED] like this.
  3. Apr 4, 2017 at 8:53 AM
    #63
    LibertySand
    LibertySand IH Support Rig
    Montclair, CA
    07 TRD DC 5.7 Tow 4X4
    Ya, I'm trying to get it the rack done before the Tundras to Sedona trip. I have the same Jack at home that I use in the garage and so far I've never had to use a block under it but I may make an adapter riser for it just in case....
  4. Apr 4, 2017 at 8:56 AM
    #64
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    what size tire is that? and is that on a stock size spare steel rim?
    Law323 likes this.
  5. Apr 4, 2017 at 9:01 AM
    #65
    sdhq_offroad
    sdhq_offroad New Member
    GILBERT, AZ
    Jack extension for the Pro Eagle 2 ton jack along with it fitting the harbor freight 1.5 & 2 ton jacks. Locks into the foot pad so it doesn't kit out. Adjustable height.
    http://store.sdhqoffroad.com/13extensionforoff-roadjack.aspx
    and if your jack doesn't have the right foot plate, they make one that you can change out as well for $20.
    dcsleeper408 and J4RR3N4 like this.
  6. Apr 4, 2017 at 9:04 AM
    #66
    LibertySand
    Montclair, CA
  7. Apr 4, 2017 at 9:05 AM
    #67
    Bear
    Bear Fargin' Iceholes
    Bear
    Custer, SD
    2022 GMC Sierra 3500 Dually
    Pulsar Edge V3; MBRP side dump exhaust
  8. Apr 4, 2017 at 9:05 AM
    #68
    LibertySand
    Montclair, CA
    I might have to order this with my ICON leaf pack.... pick up in Sedona ;)
  9. Apr 4, 2017 at 9:12 AM
    #69
    J4RR3N4
    J4RR3N4 New Member
    South east Texas
    14 Tundra
    3” lift on 35’s
    And I was gonna ask about that extension. Thanks for sharing that.
    sdhq_offroad[QUOTED] likes this.
  10. Apr 4, 2017 at 9:25 AM
    #70
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    :facepalm::frusty:
    shun me..
    Bear likes this.
  11. Apr 4, 2017 at 9:31 AM
    #71
    Bear
    Bear
    Custer, SD
    You have been thus forthly shunned Sir
    Good day.
    I said. GOOD. DAY!!!
    TNTundra08, Patriot, Law323 and 2 others like this.
  12. Apr 4, 2017 at 3:03 PM
    #72
    CM-LENNY
    CM-LENNY No Complaints
    San Diego, CA
    2015 4x4 CrewMax SR5
    PRO shocks, 37's Nitto G2's 4:88 diffs, few other mods
    Good question LAW. If you look at the picture close, I have a tie down strap going fwd in both directions, and a piece of grade 70 chain with a black abrasion sleeve over it to quiet it and blend into the tie-down strap. A grade 70 chain is almost un-cuttable and the bullet proof pad lock is locked at the rim itself. I unbolted the OEM tie-down hook and looped the chain through it. If someone wants it, they're going to get it. (this keeps out the honest thief).
  13. Apr 4, 2017 at 3:16 PM
    #73
    Eclipsed & Floating
    Eclipsed & Floating [OP] Over it.........
    I’m right where I need to be
    Voluptuous Whitey
    Got it up high and I'm seeing the possibilities now
    Patriot and dcsleeper408 like this.
  14. Apr 4, 2017 at 3:25 PM
    #74
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    I can see what you're talking about now.
    That's a solid setup!
    CM-LENNY[QUOTED] likes this.
  15. Apr 4, 2017 at 3:31 PM
    #75
    Eclipsed & Floating
    Voluptuous Whitey
    Confirmed
  16. Apr 4, 2017 at 3:34 PM
    #76
    Eclipsed & Floating
    Voluptuous Whitey
    Probably going to trim the guides and then work the full sized spare back towards the rear bumper for more clearance
  17. Apr 16, 2017 at 10:22 AM
    #77
    trayday
    trayday New Member
    Oregon
    2015 limited CM 5.7
    Its faster than air I'd think since its under pressure. Just gotta carry around a tank. I run nitrogen in my tires, larger molecules so the tires don't deflate on their own. Nitrogen is under more pressure than air and co2 and I'm able to watch my tires inflate and deflate within seconds. I ran nitrogen in 3 sets of tires for a car, when i sold the car along with the spares, the tires were still full after years of sitting.
  18. Apr 18, 2017 at 9:30 AM
    #78
    Vector W8
    Vector W8 Old guy with a lot of expensive habits.
    FFV, TRD Supercharger, Bullydog FFV Tune, 2014 Fit Kit, TRD Dual Exhaust, Sequoia Front Sway Bar, TRD Rear Sway Bar, TRD Skid Plate, TRD Pro Grill, 040 White Mirror Covers, 040 White Door Handles, Ready Lift 3"/2", Anzo 3rd Brake Light, Winjet LED Tail Lights, LED Fog Lights, LED Rock Lights, Axle Vent Mod, SDHQ Hidden Winch Mount, 12,000lb Winch. Storm Trooper Shift Knob. BMF BATL Wheels.
    Bed mounted NFAB spare tire carrier:
    T-Rex266, TheBeast and dcsleeper408 like this.
  19. Apr 18, 2017 at 9:51 AM
    #79
    TheBeast The Beach
    clean setup
    Vector W8 likes this.
  20. Apr 18, 2017 at 5:46 PM
    #80
    Vector W8
    I'm pretty happy with it so far. I modified it a little by putting 3M PUL1212 tape on the areas where the tire rests to prevent ware on the powder coat. It should preserve it for a long time to come.
  21. May 3, 2017 at 8:23 AM
    #81
    LibertySand
    Montclair, CA
    Finally got around to getting my new rim and spare on the completed rack...
  22. May 3, 2017 at 9:02 AM
    #82
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
  23. May 3, 2017 at 9:05 AM
    #83
    Vector W8
    Nice Job.
  24. May 3, 2017 at 9:10 AM
    #84
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    Serious ? Here... if we have a 6 inch lift.. get a flat.. we really have to get a 5Th wheel that's the same as we are running.. can't go to reg spare just to get to a shop??
  25. May 3, 2017 at 9:36 AM
    #85
    Dustydirt19
    Dustydirt19 Hoghead
    Dustin
    Duluth, MN
    2015 Blue Ribbon Metallic 5.7L 4WD SR5 TRD DC
    ProComp 6" stage 2 lift 18x9 Fuel Vapor -12 offset 35x12.5 Nitto Ridge Grapplers BullyDog Tuner Gibson Metal Mulisha cat-back exhaust, S&B cold air intake, Color matched TRD PRO Grille, Compustar Remote Start N-Fab Hooped Nerf Bars, AMI Big stick antenna, Salex organizer and tray, Weathertech laser cut floor mats, Weathertech window deflectors Black out badge Black out front and rear bumper Black out flags 24/7 black out TRD Off-road decals Spray in Line-X Bedliner Scosche phone mount Soft rolling tonneau cover TRD pedals and footrest
    If you're just worried about a spare for emergency situations just buy the cheapest rim and cheapest 35 you can find.
    zcarpenter92 and Jsena[QUOTED] like this.
  26. May 3, 2017 at 9:49 AM
    #86
    LibertySand
    Montclair, CA
    I actually wheel my Tundra. Being on a trail miles away from any tire shop, it's good to have a spare the same size as what the other 4 are. I currently run 35" and thats a bit bigger than the stock which could severally damage some chit inside the differentials if I had a long way's to get off the trail. I also carry plugs but I'd rather change a tire than plug it, unless I really need to.
    What works for some, doesn't work for others.
    Before I built my rack, thats exactly what I did. I used the Tundras Spare 18" Rim and found a used 34" tire. Till I got my 17" Spare Method rim.
  27. May 3, 2017 at 9:53 AM
    #87
    Dustydirt19
    Dustydirt19 Hoghead
    Dustin
    Duluth, MN
    I can remember if it was on this thread or not but on a 6in lift if your front goes flag you'd have to do a 2 tire swap correct?
  28. May 3, 2017 at 9:54 AM
    #88
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    Huh lol
    joonbug likes this.
  29. May 3, 2017 at 10:03 AM
    #89
    Dustydirt19
    Dustydirt19 Hoghead
    Dustin
    Duluth, MN
    **Flat**
  30. May 3, 2017 at 10:27 AM
    #90
    LibertySand
    Montclair, CA
    I'm not sure who is fawkin with you but No. It doesn't matter what size lift or no lift. If you swap the flat tire with the same size tire as the tire you pulled off than you are good.
    In a 4X4 Truck situation:
    If the tire is not the same size as the other side of the vehicle you can do some damage to the differential. The reason being is that the smaller tire will be rotating faster than the other larger tire, thus during sharp turning the differential will be working overtime while it's trying to slip power to one axle shaft to the other. This greatly compounds destruction if the axle has a locker or spool in it.
    So did you read somewhere you need to change both tires to a set of smaller tires if one large tire blows? This would be wise if you had 2 smaller tires to quickly replace them with... but I'd put a plug in the large flat tire first before doing that.
    Jsena likes this.
