OVERSIZED spare: Let's see how/where you carry when wheeling
Discussion in 'General Tundra Discussion' started by Eclipsed & Floating, Apr 3, 2017.
  1. Apr 3, 2017 at 7:27 PM
    zcarpenter92
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
    If a guy had on-board air, I wonder if it'd be easier to stuff an aired down full sized spare under the bed. Then just air that fucker up if you need to put it on.
  2. Apr 3, 2017 at 7:32 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    How'd you lock it down? Looks like a regular strap...no carabiner?
  3. Apr 3, 2017 at 7:35 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    :rofl::rofl::rofl:
    Bondage from the kids or death by your wife's hands.....
    Rock and a hard place....damn
  4. Apr 3, 2017 at 8:00 PM
    Eclipsed & Floating
    Eclipsed & Floating [OP] Over it.........
    I’m right where I need to be
    Voluptuous Whitey
    No matter which way you spin it.....you're screwed:ballchain:
    Law323[QUOTED] likes this.
  5. Apr 3, 2017 at 10:23 PM
    Bear
    Bear Fargin' Iceholes
    Bear
    Custer, SD
    2022 GMC Sierra 3500 Dually
    Pulsar Edge V3; MBRP side dump exhaust
    1: Not sure. Haven't taken a look or measured yet
    2: the stock spare will work fine, BUT only on the rear axles. (Already thought this through). If a front goes tits up, then it'd be a 2 tire swap. PITA, but a no cost solution at the moment.
  6. Apr 3, 2017 at 10:45 PM
    dcsleeper408
    dcsleeper408 BASTRDS
    mark
    San Jose CA
    2015 TRD PRO
    https://www.tundras.com/threads/spare-tire-carrier-options.4865/
    Since then handful of moderate trips..
    not much changed. Tire is still in good condition. Air pressure dropped by 2-3 psi..
    Most damage to the tire came from where it met with the brackets that were cut off. I went back and bfh'd that shizz..
    Also have someone crank the tire up while you guide it into the best place.
    This is a full 35" bigger than my ko2 on a full size 18x9 +12 fn bfd
    It's really close to the shackle during normal driving conditions. Once I start getting flexy (when you shackles swings out enough) the bolt head hits. Haven't experienced anything out of norm as far as the spare stopping either side from dropping down.
    To be honest I haven't gotten to that point only in my stuff/flex tests on my loading dock at work. Even then still didn't seem to affect it/articulation/drop/spare damage etc.
    Best place to put it is on a wilco tiregate.. or have a swing out.
    If you can spare the space in bed throw i in there and tie it down.
    I don't know how people put there 35"s+ / 100lb spare+tire combo on the roof racks. I feel it's more work to get the damn thing off.
    Do what works for you. Hope this helps ya out!
    joonbug, J4RR3N4 and 040Tundra like this.
  7. Apr 4, 2017 at 4:01 AM
    Pvarela07
    Pvarela07 New Member
    2014 Silver Tundra SR5 TRD Off-road 4x4
    Just getting started
    I thought the smaller spare would go in the front.
  8. Apr 4, 2017 at 5:24 AM
    Bear
    Bear
    Custer, SD
    The size of the spare has nothing to do with it, rather, for those of us with the 6" lift and different spindles, it's the backspacing on the wheel itself that becomes the issue.
    J4RR3N4 likes this.
  9. Apr 4, 2017 at 7:01 AM
    Patriot
    Patriot Member
    Western NC, “Boondocks”
    If your shackle moves a half inch either way me thinks your worries are no longer about a spare.;)
  10. Apr 4, 2017 at 7:05 AM
  11. Apr 4, 2017 at 7:07 AM
    J4RR3N4
    J4RR3N4 New Member
    South east Texas
    14 Tundra
    3” lift on 35’s
    I believe if your 4wd, all your tires must match in size and tread pattern or it'll eat up your gears if your not careful.
  12. Apr 4, 2017 at 7:08 AM
    Yes but in a pinch that can be done .. would still not recommend it.
    dcsleeper408 and Bear like this.
  13. Apr 4, 2017 at 7:09 AM
    J4RR3N4
    J4RR3N4 New Member
    South east Texas
    14 Tundra
    3” lift on 35’s
    There is a guy driving around my town with a lifted suburban on what looks like military wheels and tires, and he has a matching spare on the roof!? It dosnt make sense to me either.
    dcsleeper408[QUOTED] likes this.
  14. Apr 4, 2017 at 7:11 AM
    Bear
    Bear
    Custer, SD
    True, if you're in 4WD. Otherwise we are open differential set up. No harm in the short term. Now...an AWD, like the 6spd FJ? Yep. Bigger problem.
    csuviper likes this.
  15. Apr 4, 2017 at 7:15 AM
    J4RR3N4
    J4RR3N4 New Member
    South east Texas
    14 Tundra
    3” lift on 35’s
    Good point sir. Either way. Me myself I will buy a full size spare and sell the janky factory spare. If your wheeling, your going to get a flat sooner or later so best be prepared before you even go. @sdhq_offroad has a few spare tire mounts that I've been looking at. One that slips into your factory hitch and one that replaces the tailgate all together.
  16. Apr 4, 2017 at 7:16 AM
    Bear
    Bear
    Custer, SD
    And thinking about, with a 2" tire difference, you may have to turn off trac control until you get the proper wheel fixed.
    Damn trac control
    J4RR3N4 likes this.
  17. Apr 4, 2017 at 7:19 AM
    J4RR3N4
    J4RR3N4 New Member
    South east Texas
    14 Tundra
    3” lift on 35’s
    Or if you don't go wheeling as often do like cmlenny did. Grab a few d ring mounts to strap it down in the bed. I forget who makes them but there is a company who makes a ratchet style y strap for spare tires being mounted like this.
  18. Apr 4, 2017 at 7:24 AM
    J4RR3N4
    J4RR3N4 New Member
    South east Texas
    14 Tundra
    3” lift on 35’s
  19. Apr 4, 2017 at 7:32 AM
    #49
    Eclipsed & Floating
    Voluptuous Whitey
  20. Apr 4, 2017 at 7:33 AM
    #50
    Bear
    Bear
    Custer, SD
    The CO2 set up is the tits!!
  21. Apr 4, 2017 at 7:40 AM
    #51
    Eclipsed & Floating
    Voluptuous Whitey
    Forgive my lack of knowledge but how long does the CO2 setup last and is it refillable or does it need replaced?
  22. Apr 4, 2017 at 7:44 AM
    #52
    Bear
    Bear
    Custer, SD
    Refillable. Usually a welding or brewing supplies place will do it for $15-20. They last quite a while, but it all depends on how much you're using. Airing down to 20 psi and want to fill back up to 35? That tank will last you many many trips to the trails.
    Edit: and the fill up is fast!!
  23. Apr 4, 2017 at 7:45 AM
    #53
    sdhq_offroad
    sdhq_offroad New Member
    GILBERT, AZ
    A 35" tire will fit in the spare location, we do it all the time. We cut the "ears" off of the spare tire mount to suck the tire up deeper so it isn't hanging down as far. It is generally something we do on the single exit exhaust as the dual exhausts usually have to modified so that it doesn't melt part of the tire. I'll see if I can dig up some pictures. I know we will be doing it to our cement pro as well so I will make sure I get pictures of that.
  24. Apr 4, 2017 at 7:52 AM
    #54
    Eclipsed & Floating
    Voluptuous Whitey
    Please do. Thank you. Also, can you link your bumper mount option? I've been scouring your site and I'm nor seeing them
  25. Apr 4, 2017 at 7:54 AM
    #55
    Eclipsed & Floating
    Voluptuous Whitey
    Anyone else want to chime in on pros and cons to the CO2 option rather than air compressor setup?
  26. Apr 4, 2017 at 7:58 AM
    #56
    sdhq_offroad
    GILBERT, AZ
  27. Apr 4, 2017 at 8:01 AM
    #57
    Eclipsed & Floating
    Voluptuous Whitey
  28. Apr 4, 2017 at 8:07 AM
    #58
    sdhq_offroad
    GILBERT, AZ
    We don't have anything full bumper w/ swing outs, but we do the full bumpers such as Fab Fours, etc, etc
  29. Apr 4, 2017 at 8:33 AM
    #59
    LibertySand
    LibertySand IH Support Rig
    Montclair, CA
    07 TRD DC 5.7 Tow 4X4
    Currently this is how I have my Spare mounted on my 2nd Gen. I used some T-Slots I got off Amazon that worked perfect for the bed rails. The Spare is the stock 18" Rim with a 34" Tire. I will be getting another Bronze Method soon to match the 4 on the ground. I'll be mounting the new Method differently in a rack.
    The T-Slots seem to pull hard from the rail but so far even in some rough off roading everything has held up. Do I recommend it... maybe for daily driving. For off roading all the time. No.
    TheBeast, dcsleeper408 and J4RR3N4 like this.
  30. Apr 4, 2017 at 8:34 AM
    #60
    J4RR3N4
    J4RR3N4 New Member
    South east Texas
    14 Tundra
    3” lift on 35’s
    It dosnt strain your electrical system. It's quicker than a 12v air supply. You can run air tools etc. fill your buddy's tires.
