Opinion on lift kit
Discussion in 'Suspension' started by PhillyB, Oct 9, 2021.
  1. Oct 12, 2021 at 12:31 PM
    TundraBlack
    TundraBlack New Member
    update, i just called another toyota dealership that is close by, and he told me if i have the parts they will charge 579 in labor. If i needed to buy the part, which he transferred me to the parts apartment, and said thy have 1 in stock at it was 465.74. so total before tax would be 1,044.74. the guy was about to tell me the part number, then i heard another guy say something and he then said in his system it just says lift kit. so i was like ok.. but that's $800 difference from the the first Toyota i went to. A shame
  2. Oct 12, 2021 at 2:06 PM
    1P7R9O4
    1P7R9O4
    AZ
    ‘17 White 1794 Pro
    At those prices, I’d be looking at a set of Bilstein 6112 for the front and either matching rears or go with cheaper 5100 series. Most off-road shops will charge between $100-150 per wheel to install them and then pay for an alignment afterwards. If a dealership is charging over $1000 for a spacer at the front and a 1” rear block installed on your factory suspension, they’re screwing you big time.
    https://www.amazon.com/gp/aw/d/B00NT5T8CY?ie=UTF8#cm_cr_carousel_images_section
    https://www.4wheelparts.com/p/bilstein-6112-series-leveling-kit-46-206084/_/R-BBGL-46-206084
    May have to check around or wait for items to be on stock right now.
  3. Oct 12, 2021 at 2:52 PM
    TundraBlack
    thanks, will look into it
  4. Oct 17, 2021 at 5:13 AM
    preacher35
    preacher35 RIGHTEOUS MEMBER
    2018 MGM Platinum Crewmax 4x4
    I had SPC's on my 4Runner as they were economical, BUT, I have seen pics of them on other peoples' vehicles breaking on the trail so, there is that. If you are going to be doing some hard core off-roading, you probably should consider some Camberg UCA's or maybe Total Chaos. Zone Off Road make some pretty tough, yet economical UCA's, for consideration. Good luck!
  5. Oct 18, 2021 at 4:22 AM
    PhillyB
    PhillyB [OP] New Member
    Bill
    Soon to buy 2021 SR5
    I wont be doing any serious trail stuff, mostly just hunting trails in costal virginia (flatland), and the beach in the summer.
