Opinion on front coilover options!!!!
Discussion in 'Suspension' started by Shelbie67, Apr 14, 2018.
  1. Apr 15, 2018 at 1:43 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    All good advice above. The only thing to caution you about is mixing Icon in with one of the others. Icon is digressively valved and the others are progressively valved. I don't know for a fact that you can't run them together, It just seems weird to me.
    joonbug likes this.
  2. Apr 15, 2018 at 1:45 PM
    Shelbie67
    Shelbie67 [OP] New Member
    Blake
    NorCal
    2018 tundra crewmax platinum
    RADFLO 2.5 suspension, apex rock sliders, BFG KO2, exhaust delete, Full Active Stereo
    appreciate that. I'm not a fan of mixing just from the looks....I'm OCD enough it would probably bug me lol
    joonbug and 831Tun[QUOTED] like this.
  3. Apr 15, 2018 at 1:47 PM
    Shelbie67
    Blake
    NorCal
    Also, should I do a 2.0 with rest or 2.5 Resi in the rear?
    831Tun likes this.
  4. Apr 15, 2018 at 1:48 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    I understand the OCD thing. I did run fox rears and ADS fronts for nearly a year. I'm also planning to run a king secondary up front if my deal with @zackbremer works out. I can live the Franken truck, as long as it performs.
    UTTundra, dcsleeper408 and joonbug like this.
  5. Apr 15, 2018 at 1:51 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    It's up to you. A lot of people run 2.0 but these are big, heavy trucks. I personally never considered a 2.0. If you're doing technical stuff, you're less likely to cycle the suspension rapidly enough to warm the shocks. If you go desert romping you will warm up the shock oil. Maybe @dcsleeper408 will chime in on this.
  6. Apr 15, 2018 at 2:01 PM
    Shelbie67
    Blake
    NorCal
    That was my thinking...I'm good running 2.5 up front, but was on the edge of a reservoir...but i know it also does more that cooling, it also helps with absorption of the bumps...I'f i did 2.0, id run a reservoir no problem.
    dcsleeper408 and 831Tun[QUOTED] like this.
  7. Apr 15, 2018 at 2:45 PM
    dcsleeper408
    dcsleeper408 BASTRDS
    mark
    San Jose CA
    2015 TRD PRO
    If you can afford it the 2.5 with resis will go a long way as far as performance. Ads/king/icon are all rebuildable and you can customize the valving on them if you please. Look into extended travel vs. your “stock” over the shelf length. The clickers give you some user tuning as well.
    https://youtu.be/rpEqmHknBJM
    For a little more understanding. :thumbsup:
    831Tun likes this.
  8. Apr 15, 2018 at 2:50 PM
    Shelbie67
    Blake
    NorCal
    You just love spending my money don't you @dcsleeper408 ;) Just kidding. if I go 1" in the rear, will i need extended length? i'm between king and Fox for the money, but mostly fox due to cost since i can buy a members 2.5 rest shock for a good price...
    I thought fox were rebuildable? That is a good video too
    dcsleeper408[QUOTED] and 831Tun like this.
  9. Apr 15, 2018 at 2:56 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Yeah, Fox are rebuildable. Mark just suffers momentary amnesia at times.
  10. Apr 15, 2018 at 3:06 PM
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    Yes. Sorry I completely forgot to mention fox. Yes they are rebuildable.
    Extended is recommended. So your shock won’t limit your down travel.
  11. Apr 15, 2018 at 3:06 PM
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    :p
    831Tun[QUOTED] likes this.
  12. Apr 15, 2018 at 3:26 PM
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
  13. Apr 15, 2018 at 4:07 PM
    Shelbie67
    Blake
    NorCal
    Exactly!!!
  14. Apr 15, 2018 at 4:08 PM
    Shelbie67
    Blake
    NorCal
    Ok, so if I got extended that’d be a custom order then???
    dcsleeper408[QUOTED] likes this.
  15. Apr 15, 2018 at 4:09 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    David or Hugo!!!
    Shelbie67[QUOTED][OP] likes this.
  16. Apr 15, 2018 at 4:09 PM
    csuviper
    Broomfield, CO
    Toytec Boss or Toytec Radflo 2.5 are a great option
    dcsleeper408 likes this.
  17. Apr 15, 2018 at 4:14 PM
    LEKS
    LEKS Truck name “Sancha”
    Makaha
    2013 Rockwarrior Supercharged
    Contact mcmFab and get a quote for an ADS setup before you decide. Imo they are neck & neck with king and may even be better considering what you get with them. Check out ADS’s website for a direct comparison with Kings
  18. Apr 15, 2018 at 4:50 PM
    Shelbie67
    Blake
    NorCal
    I kinda want reservoirs though
  19. Apr 15, 2018 at 4:51 PM
    #49
    Shelbie67
    Blake
    NorCal
    I believe the fox
    880-02-947 are extended. Also when it says new upper control arm needed, is that due to ride height?
    831Tun and dcsleeper408[QUOTED] like this.
  20. Apr 15, 2018 at 5:16 PM
    #50
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    There are several reasons for the UCA replacement.
    1. More space for resi hose
    2. Improve alignment specs.
    3. Eliminate the potential for binding the OEM ball joint that becomes possible with the increase in travel.
  21. Apr 15, 2018 at 6:03 PM
    #51
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    This was my oem uca with billy/eibach setup at full droop.
    A lot of good benefits to getting uca. If manufacture requires then best to do so. Save you some headache down the road.
    GodlessPro and 831Tun like this.
  22. Apr 15, 2018 at 6:06 PM
    #52
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Is that spindle hitting the spring? Looks really close.
  23. Apr 15, 2018 at 6:07 PM
    #53
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    Yeah it would hit the coil from time to time. I was surprised the oem bj lasted as long as it did.
  24. Apr 15, 2018 at 6:19 PM
    #54
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    yeah, you can get by for a while with a good BJ :anonymous:
    Sunnier, GodlessPro, joonbug and 3 others like this.
  25. Apr 15, 2018 at 6:23 PM
    #55
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    Extended travel co requir aftermarket uca.
    dcsleeper408 and 831Tun like this.
  26. Apr 15, 2018 at 6:47 PM
    #56
    Shelbie67
    Blake
    NorCal
    So.....you all know what I’m gonna ask next...
    UCA recommendations without breaking the bank
  27. Apr 15, 2018 at 6:56 PM
    #57
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    Mcm fab
    Total chaos
    Icon
    To name a few.. they are all pretty pricey.
    I know someone that is going to be selling his icon delta ucas soon. :anonymous:
    BlueBottle and Shelbie67[OP] like this.
  28. Apr 15, 2018 at 6:57 PM
    #58
    csuviper
    Broomfield, CO
    SPC light racing UCA, Icon with their new delta joints or Total Chaos are good options
  29. Apr 15, 2018 at 7:32 PM
    #59
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Spc or jba are the only two cheaper ones I would look at. @dcsleeper408 covered the rest. +camburg.
  30. Apr 15, 2018 at 7:57 PM
    #60
    Shelbie67
    Blake
    NorCal
    anyone know anything of "Protune" or " Tuff Country" or "pro comp"?
    I'm sure i know the answer to follow lol
