Oil filter cartridge
Discussion in '2.5 Gen Tundras (2014-2021)' started by Oregon 1 Toyo, Apr 15, 2018.
  1. Apr 19, 2018 at 9:54 PM
    #91
    I just don't understand why they printed it upside down shuda been other way
  2. Apr 20, 2018 at 5:34 AM
    #92
    Skippy
    Skippy Standing for the Flag
    San Antonio US of A
    2016 Tundra 1794
    Is it, "Made in China"?:annoyed:
  3. Apr 20, 2018 at 5:37 AM
    #93
    Someone wasn't thinking on engineering side
    Prostar 190 likes this.
  4. Apr 20, 2018 at 8:12 PM
    #94
    TTund16
    TTund16 New Member
    so if you buy the alum cap, it comes with short filter thing and you have to take the longer filter thingy from your car and replace it with the short one in the aluminum filter cap? is that right?
    why doesn't Toyota sell one with the long filter?
    is there any danger to break or stress the pins when doing this?
  5. Apr 20, 2018 at 8:30 PM
    #95
    nk1794
    nk1794 Always torque to spec
    San Jose, CA
    Does anyone know the reason why they go with this type of filter rather than the conventional canister type? To me this is more complicated and more chance of leakage. I see more cons than pros. Thoughts?
  6. Apr 20, 2018 at 8:33 PM
    #96
    teedubbya
    teedubbya I like fat booty
    Austin TX
    2019 trd pro voodoo 4runner
    It’s just a cap/filter holder. Exact same as OEM but not plastic.
  7. Apr 20, 2018 at 8:36 PM
    #97
    nk1794
    San Jose, CA
    I meant why not stay with this type
    Instead of this
  8. Apr 20, 2018 at 8:38 PM
    #98
    boostedtrdpro
    boostedtrdpro voided warranty
    Jeremy
    2024 GMC Sierra 2500HD AT4X 2020 Sequoia TRD Pro 040
    Not sure why, but the cartridge must be beneficial for some reason over the sealed canister. My Audi A8 uses the cartridge style as well.
  9. Apr 20, 2018 at 8:38 PM
    #99
    nk1794
    San Jose, CA
    That seemed to be a trend. Is it cost cutting?
  10. Apr 20, 2018 at 9:36 PM
    #100
    boostedtrdpro
    Jeremy
    15whtrd and nk1794 like this.
  11. Apr 20, 2018 at 9:53 PM
    #101
    nk1794
    San Jose, CA
    boostedtrdpro[QUOTED] likes this.
  12. Apr 21, 2018 at 8:32 AM
    #102
    Oregon 1 Toyo
    Oregon 1 Toyo [OP] New Member
    2014 Tundra sr5 double cab 4x4
  13. Apr 21, 2018 at 8:36 AM
    #103
    Oregon 1 Toyo
    I just took the shorter one out of my just bend the little butterfly clips up gently wth a standard screwdriver, push down on the filter cylinder, twist and remove, then put the one from the origional filter cap back in the new filter cap and reverse the process.
    nk1794, TTund16, Skippy and 1 other person like this.
  14. Apr 22, 2018 at 6:57 AM
    #104
    Oregon 1 Toyo
  15. Apr 22, 2018 at 7:00 AM
    #105
    Oregon 1 Toyo
    This is the tool that got it done took the plastic one off wth no problem torqued the new one to 20 pounds good to go!8C383492-3A67-4F49-B85D-B58CCA1E587D.jpg
    TTund16 likes this.
  16. Apr 22, 2018 at 7:03 AM
    #106
    Oregon 1 Toyo
  17. Apr 22, 2018 at 7:05 AM
    #107
    Oregon 1 Toyo
    After doing some research it appears that Toyota is trying to go green wth the canisters so there is less waste like wth the spin on filters.
    nk1794 likes this.
  18. Apr 22, 2018 at 8:43 PM
    #108
    Oregon 1 Toyo
    Yes you can drain the filter canister only if you have issues with the filter without having to drain the oil pan, came in handy when I was having issues with my filter canister, finally got the plastic one off and new alluminum one installed. Seems the alluminum canister has a higher oil capacity since I had to add more oil back in than I drained out of the plastic one.
    TTund16 likes this.
  19. Jun 8, 2018 at 12:21 PM
    #109
    Ok I'm out here doing my oil change out here at work at the hotel out in the back, I have the new aluminum filter canister, from what I've heard I need to remove the tube with holes from new one and from the plastic old one put that tube in new canister???
    15whtrd likes this.
  20. Jun 8, 2018 at 12:23 PM
    #110
    15whtrd
    15whtrd Mr. Blonde
    Yes you do. The one that comes with the aluminum canister is too short it needs to match the length of the filter. I have the canister I’m just waiting for my next oil change do it. Some people of had luck just pushing down and spinning the tube out. But most I’ve read say you have to bend those little tabs slightly.
  21. Jun 8, 2018 at 12:24 PM
    #111
    15whtrd
    15whtrd Mr. Blonde
    Make sure you do it. It’s what keeps the filter from collapsing on itself.
  22. Jun 8, 2018 at 12:28 PM
    #112
    What about the new spring and that flat washer thing with cone in middle from new canister?
  23. Jun 8, 2018 at 12:28 PM
    #113
    Thanks brother!
  24. Jun 8, 2018 at 12:32 PM
    #114
    15whtrd
    15whtrd Mr. Blonde
    I don’t think I follow. I think you need to swap over the aluminum plug out of your plastic cartridge. Don’t forget new O-rings that come with new filters.
    If what you’re talking about is a spring that is underneath the tube just make sure whatever you take out you put back in. Whether it’s parts from the old one swapping over to the new one or vice versa.
  25. Jun 8, 2018 at 12:33 PM
    #115
    15whtrd
    15whtrd Mr. Blonde
    From my knowledge the only thing you need to swap is the tube. Just make sure you put it back together the way it came apart.
  26. Jun 8, 2018 at 12:34 PM
    #116
  27. Jun 8, 2018 at 12:35 PM
    #117
    Those ^ are from new canister
  28. Jun 8, 2018 at 12:50 PM
    #118
    15whtrd
    15whtrd Mr. Blonde
    Same thing inside your old one correct?
    I want to say that’s like a drain back valve or something like that
  29. Jun 8, 2018 at 1:20 PM
    #119
    Yeah I put new ones
    15whtrd[QUOTED] likes this.
  30. Jun 8, 2018 at 1:34 PM
    #120
    Tacogrande
    Tacogrande New Member
    Jeremy
    2016 SR5 dbl. cab long bed gray
    Husky weatherbeaters,short antenna,window deflectors
    I was wondering the exact same thing. How does it install? I just want to know before I do the oil change.
