Oil change tips
Discussion in '2.5 Gen Tundras (2014-2021)' started by TTU19, Jan 12, 2018.
  1. Jan 25, 2018 at 3:32 PM
    #61
    Noodle
    Noodle That Guy
    Files creek
    2016 Tundra Limited TRD DC Inferno
    Thanks for the info Sean. Everything went smoothly, no leaks.
    15whtrd[QUOTED] likes this.
  2. Feb 27, 2018 at 9:32 AM
    #62
    15whtrd
    15whtrd Mr. Blonde
    So I’ve got about $80 in Amazon gift cards. Thinking of buying the fumoto valve, clip and aluminum oil canister. My question is about the valve. Are the threads so long that you think it is leaving a little oil in the bottom of the pan, compared to just removing a plug and getting every drop out that you can?
    I’m pretty OCD about getting as much old oil out of the engine as possible when changing fluids. I have been known to dump a little fresh oil in with the plug removed just to be certain I’m leaving as little amount of sludge in the bottom of the pan as possible.
  3. Feb 27, 2018 at 9:40 AM
    #63
    15whtrd
    15whtrd Mr. Blonde
    @Noodle sorry I think I was mistaken I thought you had the fomoto valve. I was in the middle of researching multiple threads.
  4. Feb 28, 2018 at 5:01 AM
    #64
    Noodle
    Noodle That Guy
    Files creek
    IMO no the threads aren’t that long. I’ve got an extra valve at home along with the original drain plug. When I get home this evening I’ll get some side by side comparison pics for you.
  5. Feb 28, 2018 at 5:38 AM
    #65
    RickC
    RickC NOT a new member
    Rick
    Knoxville TN
    2017 CrewMax Platinum 4x4 5.7
    SCS Wheels, Line-X, WeatherTech, UnderCover Flex bed cover
    The owners manual will tell you how much oil, but mine is 7 qts. You don't want to overfill it. Someone here posted 8 qts and that is not correct.
  6. Feb 28, 2018 at 5:46 AM
    #66
    15whtrd
    15whtrd Mr. Blonde
    My manual says 7.9. I don’t know if it’s different for the earlier years. I would think it would be the same. I heard one guy say he put nine quarts in there! I put 8 quarts and it’s always perfect.
  7. Feb 28, 2018 at 5:47 AM
    #67
    RickC
    Rick
    Knoxville TN
    Ah, thanks for that info. I know my manual says 7 qts but I have the 07 model. Maybe the Gen3 has a larger oil pan. Great info.
    15whtrd likes this.
  8. Feb 28, 2018 at 6:12 AM
    #68
    Same here
  9. Feb 28, 2018 at 6:17 AM
    #69
    15whtrd
    15whtrd Mr. Blonde
    Yeah it does come flying out of there doesn’t it!? I bought a large 10 quart oil pan thinking it would catch it but it just splashes out of there. So for the time being until I get my Fumoto valve I cut the bottom out of a milk jug on an angle and hold it underneath the drain plug to contain the splashes. Still up in the air if I want that thing though. My luck I would somehow smash my skid plate and shear it off and run my engine dry.
    Abrams65 and Cfincke like this.
  10. Feb 28, 2018 at 6:21 AM
    #70
    Fumoto valve helps with the clear tube as well..before I had a cardboard that covered the tire n wheel with a section cut out to go up to the cv axle so that it wouldn't splash...I have a 6" lift and the thick skid plate covers it I also got the little lock that goes on it
  11. Mar 2, 2018 at 4:22 PM
    #71
    Noodle
    Noodle That Guy
    Files creek
    Dude I haven’t forgot about you. I’ve been busy as hell doing the Richmond home show this weekend and had a good deal of damage at the house today from the wind storm we had. I’ll try to get you some pics in the morning.
  12. Mar 2, 2018 at 4:24 PM
    #72
    15whtrd
    15whtrd Mr. Blonde
    No sweat what so ever! No rush. TCB man
    Noodle[QUOTED] likes this.
  13. Mar 3, 2018 at 1:50 AM
    #73
    Abrams65
    Abrams65 New Member
    Cliff
    WV
    16 Tundra MGM SR5 CM OR/15 Corolla S
    ICI Magnum RT Steps, 18' LED Foglights
    Tip for first timers that don’t have the fumoto valve, before draining your oil take a old washer solvent bottle and cut the top off. At the bottom cut the the center out say 3” diameter. Now when the flood begins you’ve got a sort of splash guard for the wheel. Just have to good aiming judgement with placement. Usually if you place the solvent bottle about even with the drain plug your g2g. Hope this helps
    757TUNDRA likes this.
  14. Mar 4, 2018 at 8:17 AM
    #74
    Snoozer
    Snoozer New Member
    2014 MGM Sequoia Limited 4x4
    carseats
    I always heard all of that about Pennzoil, not Valvoline. :gossip: I’ve always been a Valvoline guy.
    7.9 quarts (with filter change) on my ‘16 5.7 FFV too.
    I’ve settled on Mobil 1’s oil filter. The construction of it is much nicer than Toyota’s or Wix’s. The Wix one gave me the wrong filter housing drain valve too. Fram is a joke.
    RitcheyRch and 15whtrd[QUOTED] like this.
  15. Mar 4, 2018 at 8:37 AM
    #75
    15whtrd
    15whtrd Mr. Blonde
    I’ve settled on Mobil 1’s oil filter. The construction of it is much nicer than Toyota’s or Wix’s. The Wix one gave me the wrong filter housing drain valve too. Fram is a joke.[/QUOTE]
    I buy TRD filters. Haven’t seen mobile 1 on the shelf but I have looked. I get the TRD for $12 form Toyota of cool springs. It gives me a chance to buy other BS I shouldn’t buy haha.
    I only drive about 6k a year so I don’t mind spending the extra $. No thanks on Fram. I do use them on my wife’s Scion sometimes, I just get the best one they offer. I try to find M1 if the have it.[/QUOTE]
  16. Jul 29, 2018 at 4:35 AM
    #76
    hillbillytoyo
    hillbillytoyo Just a country boy
    Daniel
    WV
    21 Limited Cement CM TRD OF
    I ordered everything I need to do my 1st oil change on the Tundra. Thanks for all the info in this thread.
    GbRunner10 and 15whtrd like this.
  17. Aug 17, 2019 at 6:49 AM
    #77
    Jesse30002000
    Jesse30002000 New Member
    Can anyone confirm the model # for fumoto drain valve for 2016 tundra 5.7l?
    Have to shop on Amazon.ca (canadian things ), and it will not spec out if compqtible with my vehicle or not
    Also read that the short nipple is a better purchase since the nipple hangs dangerously low. True or false?
  18. Aug 17, 2019 at 8:54 AM
    #78
    Look on the Fumoto website it shows you all the options for your year, make, model, engine size, I have a lift and I have the one with the nipple and it's covered by the thick skid plate
  19. Aug 17, 2019 at 8:55 AM
    #79
  20. Aug 17, 2019 at 9:32 AM
    #80
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    Im tagging this thread, very helpful.
  21. Aug 17, 2019 at 6:07 PM
    #81
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    Short nipple is fine. F-103N. Get the drain hose for the filter and you can cut off some of th he hose to use on the Fumoto
  22. Aug 17, 2019 at 8:39 PM
    #82
    buckrub71
    buckrub71 Like Father, Like Son--Semper Fi
    2016 Bronze 1794 CM
    s-l300.jpg This! I use this for my Tundra,, wife's Sienna, jet ski, zero turn, etc. Extremely easy and nothing left but mere drips from the pan. Also, very easy to pour oil into recycle jugs.On the truck I installed the fumoto. When released some remaining drips come out but that's it. The filter though, that's a different story. I like the idea of the fitting and hose for that. Who ever recommended greasing the zerks too...good call. I need to work that in.
    Funny, not much mention of the non TRD skid plate. That thing sucks for oil changes. Looking into an RCI or Pro plate with built in access to the filter.
    NewImprovedRon and plumber802 like this.
  23. Aug 18, 2019 at 9:22 PM
    #83
    fundratss
    fundratss Send it!
    Joe
    Colorado Springs
    2016 Magnetic Grey Tundra TSS
    Toytec 2.5” Coilover boss suspension 3/1 lift w/camburg uca’s Morimoto xb headlights Morimoto fog Rough country grill 2 RC blacked light bars Volant air intake system Rear air bags (for towing) I’m sure there’s more but I’m lazy
    Amsoil signature series 0-20 with amsoil filter. I just bought a dealer membership since my buddies all wanted amsoil. So that’s how I get amsoil. Otherwise ya hafta find someone who will sell it to ya or pay for the membership particle these on Toyota filter blows. It doesn’t trap much compared to other oem filters. I’d use a Napa gold before Toyota filter. But depends on how often you want to change the oil/filter too
  24. Aug 24, 2019 at 12:21 PM
    #84
    GlobalGuy
    GlobalGuy GlobalGuy
    Buffalo, NY
    2018 Silver TRD Double cab
    Will this work on ATVs, lawnmowers etc? What size is yours, 9.5L? Any idea how much oil it cannot extract fully?
    Thanks
  25. Aug 24, 2019 at 12:39 PM
    #85
    Punkinhead
    Punkinhead New Member
    I use a similar one on everything I own that has a motor. On some engines it will leave a couple teaspoons behind but I just did the first change on my '19 with a 5.7l and I don't think more than 2 drops came out when I pulled the plug to install a Fumoto valve.
    GlobalGuy[QUOTED] likes this.
  26. Aug 24, 2019 at 12:41 PM
    #86
    jeremyd
    jeremyd 2014 Crewmax SR5
    NV
    2014 SR5 CM 4X4
    ProComp 7" 35/12.50/18 -11
    I think I’ve been a bad boy, I just hit 50k. I’ve only changed my filter twice but I have 10 logged oil changes...
  27. Aug 24, 2019 at 12:46 PM
    #87
    15whtrd
    15whtrd Mr. Blonde
    :eek2:
    How did the filter look after waiting so long? I imagine it still looked fine.
    jeremyd[QUOTED] likes this.
  28. Aug 24, 2019 at 1:29 PM
    #88
    jeremyd
    NV
    2014 SR5 CM 4X4
    It looked fine. The oil was changed twice as often as the manual states..
  29. Aug 24, 2019 at 6:07 PM
    #89
    buckrub71
    2016 Bronze 1794 CM
    Yes, anything with dipstick access. Makes all of mine oil changes extremely easy. There is a 9 5 liter out there. Mine is the 6.5 liter. No problems. As it nears the top, flip the valve, vacuuming stops and then disconnect the quick release. The pour spout is then used to empty it into the original containers. Reconnect and finish pumping...another minute or so and it's done.
  30. Aug 25, 2019 at 5:57 AM
    #90
    GlobalGuy
    GlobalGuy GlobalGuy
    Buffalo, NY
    Thanks:thumbsup:
