Official Tundra Wheel and Tire Setups - Pics and Info
Discussion in 'Wheels & Tires' started by csuviper, Jan 10, 2014.
  1. Mar 6, 2016 at 2:41 PM
    #511
    rons23
    rons23 Get The Led Out!!!
    Ron
    Kill Devil Hills
    2008 Nautical Blue TRD
    Yeah Brian, but considering I have a 2wd, smack me now!, that set up is more for off-road. Tanner @Toytec recommended the 6112's said they would be a better ride. I definitely don't need the 5160's as there set up for off-road also and more expensive. Thanks for the recommendation
  2. Mar 6, 2016 at 8:28 PM
    #512
    equin
    equin Texarican Tundra
    Ed
    DFW, TX
    I was unaware of the Toytec Ultimate, but knew of and had considered the Toytec Boss. I used to have adjustable Toytecs on my old '03 Tacoma and thought they were great. If I remember correctly, they used Bilstein shocks on those. Main reason I went with the 6112s was the price for a shock with a bigger diameter than a 5100. But you can't go wrong with Toytecs.
  3. Mar 8, 2016 at 6:18 AM
    #513
    OGT242
    OGT242 Always know if the juice is worth the squeeze
    Oscar
    Marana, AZ
    2016 Tundra TRD Pro Quicksand CrewMax
    What wheels are those?
  4. Mar 9, 2016 at 7:41 AM
    #514
    csuviper
    csuviper [OP] Moderator Staff Member
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    View of how far my tires stick out past the fender as viewed from the drivers side mirror tilted down.
    315/70R17 (Diameter:34.4", Section Width: 12.7") Goodyear Wrangler Duratrac
    Wheel offset with wheel spacers: +18.24
    Halfjap, zcarpenter92 and equin like this.
  5. Mar 14, 2016 at 1:52 PM
    #515
    ldale
    ldale New Member
    Txk Tx
    17' Limited Silver Sky Metalic
    Tonno Pro LowPro , TRD Sway Bar, Helwig Leaf Pack
    Can some help me ID this Wheel?
  6. Mar 14, 2016 at 2:16 PM
    #516
    Virgils12
    Virgils12 New Member
    Camburg Fox factory 2.5" lift Xd monsters with 295/70/18 nitto terra graplerrs Corsa cat back Weather tech liners Wet okole covers
    Pics of how far my new to me rims and tires stick out past the fenders.
    Set up is 18x9 Moto metals with -12 offset
    35x12.50x18 bfg all terrain. Right at 2 3/4" out.
    The Juice, equin and T-Rex266 like this.
  7. Mar 14, 2016 at 5:05 PM
    #517
    Jbrady.801
    Jbrady.801 New Member
    2014 tundra
    Stock image.jpg 3/1 level kit image.jpg cooper discoverer STT pro 295/70/18. Mayhem wheels +18 offset fender trimming and heat gun used to clear front inner fender. Very minor rub on driver side body mount. image.jpg
    DGempis11, thedonn, The Juice and 4 others like this.
  8. Mar 14, 2016 at 5:10 PM
    #518
    Jbrady.801
    2014 tundra
    Thank you guys for all the great info
  9. Mar 14, 2016 at 5:17 PM
    #519
    TruckyTruck
    TruckyTruck Dumbest Username
    Gary
    Looks great! You sure those aren't a zero offset, or +12...?
  10. Mar 14, 2016 at 5:26 PM
    #520
    jberry813
    jberry813 The Mad Scientist Staff Member
    Lake Tahoe
    2015 Tundra Platinum, 2012 Tacoma, 2007 T4R
    Metric shit ton of parts
    Those are the MO971's. They only come in a -12 or +18 offset in the 18x9 5x150 bolt pattern.
    TruckyTruck[QUOTED] likes this.
  11. Mar 14, 2016 at 5:27 PM
    #521
    rons23
    Ron
    Kill Devil Hills
    You know Trucky, I was thinking the same thing, because the rims I really want are +12, but if Virgils12 is negative 12, then +12 would tuck in another 24mm or essentially almost a inch. Am I correct by saying that. I hope Virgils right, because I could probably live with 1 1/2" stick out
  12. Mar 14, 2016 at 5:58 PM
    #522
    Virgils12
    This is correct. Mine are -12. I measured the back space and found a app online to do the math. I well my paint would have liked it better if they were the +18. Looks great but it's a bitch to keep clean right now with all the damn rain we have been getting. I really want to get the pro comp flares only ones I have found that I like right now but not sure they will fit my second gen.
    TruckyTruck likes this.
  13. Mar 14, 2016 at 6:01 PM
    #523
    Virgils12
    Your math is right. But it's also gonna depend on tire width...
  14. Mar 14, 2016 at 6:10 PM
    #524
    rons23
    Ron
    Kill Devil Hills
    I'm looking at the Black Rhinos (Sierra) 18x9 / 295/70/18. uploadfromtaptalk1458004210063.jpg
  15. Mar 14, 2016 at 6:41 PM
    #525
    Virgils12
    So that should put you very close to Brian's set up. Will look good. :thumbsup:
    rons23[QUOTED] likes this.
  16. Mar 14, 2016 at 9:05 PM
    #526
    TruckyTruck
    Gary
    Yeah, with a +20 and 12.5s, mine stick out about and inch and a half. I was judging it by his picture. But I guess they stick out further than I thought. Looks great though. Perfect for some pocket flares!
  17. Mar 19, 2016 at 5:07 PM
    #527
    N3tho
    N3tho New Member
    2014 TRD SR5 CM SUPER WHITE
    Hey guys im a new member here i got a few questions sorry if they have already been ask. I got a 2014 CM and planning on getting OEM king shocks 2.5 with reservoir camburg ball joint uca and some 295/70R18 with stock trd wheels i think +60 would i have any rubbing problems? Diff. Drop really need it? Thanks in advance!!!!
  18. Mar 21, 2016 at 2:41 PM
    #528
    anamator
    anamator New Member
    Kevin
    Clearwater, FL
    2013 Toyota Tundra Platinum 4x4 Short Bed Crew Max 5.7 FFV w/ Sunroof
    Toyo A/T Open Country with Fuel Wheels. Tire size 305/55 R20 121/118S 10 PR
    Is there a way to know what my wheel size and offset is without taking the wheels off? Unfortunately I bought them already on the truck and don't have the last owners contact info to ask them since I purchased my truck from a dealer.
    Can you also add/put any spacers on the wheels to stop frame rubbing? I'm getting some rubbing on the frame when turning sharp going forwards or in reverse.
    Thank you.
  19. Mar 21, 2016 at 6:41 PM
    #529
    Virgils12
  20. Mar 21, 2016 at 6:43 PM
    #530
    Virgils12
    Good looking truck by the way! What's the little black dot on your front bumper? What grill is that?
  21. Mar 21, 2016 at 8:39 PM
    #531
    csuviper
    Broomfield, CO
    Your offset is +20
  22. Mar 24, 2016 at 8:39 AM
    #532
    Halfjap
    Halfjap New Member
    Reno, NV
    2015 White Tundra Crewmax
    Looking to get a new set of wheels for the Crewmax. Currently have a 3/1 level/lift with stock rims and 1" spacers. Running 275/70/r18 tires. IMG_2521.jpg
    I am looking at Anthem Offroad wheels.
    They come in either 0 or -12 offset. I would like to get the tire to push out a little further then what I have currently. Should I go with the 0 or the -12 offset to get that look.
    Thanks for any help.
  23. Mar 24, 2016 at 8:49 AM
    #533
    Halfjap
    Halfjap New Member
    Reno, NV
    I forgot to mention that the new wheels with be 18x9's
  24. Mar 24, 2016 at 9:31 AM
    #534
    Tracker
    Tracker New Member
    Shane
    Colorado, Denver Burbs
    2016 Silver Tundra SR5 Lifted
    Toyo Open Country A/T with Fuel Full Blown 20" rims
  25. Mar 25, 2016 at 6:51 AM
    #535
    SCRunner12
    SCRunner12 New Member
    Robert
    Santa Cruz, CA
    2015 SR5 Crewmax
    Might as well post mine. SCS Stealth 6 in matte bronze and 285/75/17 Falken Wild Peak AT3W.
  26. Mar 25, 2016 at 7:06 AM
    #536
    1stToy likes this.
  27. Mar 25, 2016 at 8:47 AM
    #537
    Halfjap
    Halfjap New Member
    Reno, NV
    Noted....Thanks for the input.....the search goes on!
    T-Rex266[QUOTED] likes this.
  28. Mar 29, 2016 at 12:12 PM
    #538
    BigBlue15
    BigBlue15 New Member
    2" level on front only (5100s), 20x9 +11 offset wheels. Would I be able to run 295/65/20 Toyo OC A/T2 tires? I know modifying the skid plate and plastics will be needed but hopefully no body mount chop.
  29. Mar 31, 2016 at 5:56 PM
    #539
    JerseyTundra
    JerseyTundra New Member
    08 Silver Tundra DC Limited 4x4
    Bilstein 5100's all corners, AVS aero skin bug shield , Avs ventvisors, Husky x-act fit liners, Extang Trifecta signature series bed cover, TRD shift knob, TRD cup holder inserts, Front eyebrow LED lights with toggle kill switch.
    Bilstein 5100's all corners. 20in Trd black powder coated Carve wheels with 275/60/20 Bfg ko2's. FYI for anyone looking to install these. Even with my Bilsteins at max height up front I still had to trim my skid plate. I just want to let people know just in case you're looking at these tires in this size.
    dannysmith604 and NJBBPTUNDRA like this.
  30. Apr 8, 2016 at 11:36 AM
    #540
    Joe C
    Joe C Member
    Michigan
    2015 Toyota Tundra TRD
    Toytec Radflo Coil Overs Boss rear shock with reservoir 20x9 Monster +18 offset 286/65/20 Ridge Grappler Toytec adjustable shackles SPC UCA TRD dual exhaust TRD swaybar
    How's everyone Question I got 2015 DC TRD just put on 3/1.5 lift with 305/70/18 Cooper stt pro on stock Trd rims. I feel a little rubbing when I turn I think its the UCA thats hitting the tires I was thinking on putting wheel spacers. What is the good brand? Just don't want the tire to stick out too much.
