Official Lifted 2nd Gen Tundra Pics w/ Info
Discussion in '2nd Gen Tundras (2007-2013)' started by csuviper, Jan 7, 2014.
  1. Oct 14, 2019 at 9:01 PM
    #211
    zcarpenter92
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
    I know @Eclipsed & Floating ran a similar setup on his Tundra, don’t recall the width on his wheels. Check the 3rd gen builds section, his build may still be there.
  2. Oct 14, 2019 at 9:25 PM
    #212
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    I ran 35x12.5 toyos on 18x9 method wheels with +18 offset i believe.
    They rubbed the body mounts even with the body mount chop. I had to turn the coilovers up to about 3.25 inches to not rub on the street. It rode like crap turned up that high
    Wider wheel would rub worse
  3. Oct 15, 2019 at 9:55 AM
    #213
    JtTundra87
    JtTundra87 New Member
    Justin
    North Carolina
    2007 Crewmax Limited
    Thanks, that’s unfortunate news but great info.
    The Rough Country website recommends a 295/70R18 tire up to a +25 offset so I guess I just stick with that. I guess that’s around a 34x12R18?
    I don’t mind trimming a little but I’m not sure about the body mount chop.
    Silverghost likes this.
  4. Oct 15, 2019 at 10:31 AM
    #214
    FloridaTundra
    FloridaTundra New Member
    Vero Beach, FL
    2011 Toyota Tundra CrewMax
    7" lift
    295/70/18 is 34.3 inches tall, 11.6 wide. Those won't clear either. I'd look at a 33x12.50 tire.
    Rica25 and Silverghost like this.
  5. Oct 15, 2019 at 10:49 AM
    #215
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Don’t be afraid to cut the body mount. It is 100% as strong as it was when done.
    If you want 35x12 you gotta follow icon’s example. They run a slightly narrower wheel, I believe 8.5 inch wide, with the perfect backspacing to fit with a 3 inch lift
    Added thought. The rough country 3.5 kit is garbage do not buy it.
  6. Oct 15, 2019 at 12:43 PM
    #216
    zcarpenter92
    Zach
    NE Colorado
    In sig
    Dude, there are an absolute shitload of people on this site running 295/70’s on 2-3” of lift, myself included. Mine only rub on the front bumper at fully lock, none at all on the cab mount. And the only reason it rubs on the front bumper because I haven’t adjusted the driver’s side coil over to a full 3” of lift.
    JtTundra87 likes this.
  7. Oct 15, 2019 at 2:22 PM
    #217
    JtTundra87
    Justin
    North Carolina
    Why would rough country recommend a size that doesn’t fit? If I go 33’s I’m gonna run a thinner tire. Can anyone tell the specs on this truck from the pics? I like the way it sits.
    Prostar 190 and Rica25 like this.
  8. Oct 15, 2019 at 2:37 PM
    #218
    JtTundra87
    Justin
    North Carolina
    Some of these have 35x12.50’s on 3”. What did they modify to fit them?
    Rica25 likes this.
  9. Oct 15, 2019 at 3:07 PM
    #219
    FloridaTundra
    Vero Beach, FL
    7" lift
    Dude, rubbing is rubbing. I was trying to assist him by sharing what I know runs.
    Rica25 likes this.
  10. Oct 15, 2019 at 3:51 PM
    #220
    Silverghost
    Silverghost New Member
    13 tundra 4x4
    Were the fat Bob's coilovers worth it for the price point ? Did they hold up well , sorry I'm a new tundra owner and looked at these last nite online
  11. Oct 15, 2019 at 3:55 PM
    #221
    Silverghost
    13 tundra 4x4
    What about that size tire on a stock wheel would it work then ? Sorry new tundra owner here , not trying to hijack thread
  12. Oct 15, 2019 at 6:30 PM
    #222
    JtTundra87
    Justin
    North Carolina
    Thanks dude! I’ll have to study up on the bmc then.
    I will be running factory 18’s for a while but I need tires almost now so I was hoping to go ahead and get the lift and tires I wanted. But I guess that explains why rough country’s is almost half the price of other kits.
    I appreciate it man. It’s good to hear both sides. I don’t like rubbing however if there’s a way to alter the truck in a safe and tasteful manner so that I can clear the tires that fit my vision for the truck then I’m open to it.
    Rica25 likes this.
  13. Oct 15, 2019 at 7:26 PM
    #223
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Stock wheels are 8 inches wide. So they will tuck the tire better. Even with 1.25 wheel spacers you will be farther from the body mount than an 18x9 wheel will be.
  14. Oct 15, 2019 at 8:14 PM
    #224
    zcarpenter92
    Zach
    NE Colorado
    In sig
    Dude, the only reason you know mine rubs a minuscule amount is because I disclosed it. And that will disappear once I adjust the coils up to make it level side to side with the passenger side of the vehicle. I’m currently at 3” of lift on the passenger, around 2.75” on the driver. That rubbing issue is due to Yota Lean and me not adjusting for it, not tire size. So “rubbing is not always rubbing,” at least in the context you were referring to.
    Rica25 likes this.
  15. Oct 16, 2019 at 3:34 PM
    #225
    HTxSnoop
    HTxSnoop New Member
    2012 4.6L Tundra Crewmax
    3in level kit with 20s
    2012 Tundra Crewmax with level only 20x12 33s... about to go 6in lift kit
  16. Oct 16, 2019 at 5:00 PM
    #226
    Silverghost
    13 tundra 4x4
    Wow!!!!
    Rica25 likes this.
  17. Oct 16, 2019 at 5:15 PM
    #227
    Eclipsed & Floating
    I’m right where I need to be
    Voluptuous Whitey
    Correctamundo!!
    It was the exact same setup. A bit of rubbing until I got properly aligned. Still does it a full lock but only in reverse, and I used to wheel with a ton of weight regularly. Not hard wheeling, but significant off roading
  18. Oct 16, 2019 at 9:07 PM
    #228
    zcarpenter92
    Zach
    NE Colorado
    In sig
    Where the hell have you been buddy?!?
  19. Oct 17, 2019 at 2:10 AM
    #229
    Eclipsed & Floating
    Voluptuous Whitey
    Just trying to forge a path, Zach
  20. Oct 27, 2019 at 6:17 PM
    #230
    anirudh
    anirudh New Member
    Anirudh
    2012 Tundra Double Cab Long 8 Feet bed Black
    Would love to get brush guard, tail light guard, runner boards, windwisors, reverse camera, camper shell with windoors hi cab models, lift kit, bid wider tires best traction in snow, rain, off road, etc etc
    hello folks - i have just been born in just last few seconds into this world of lifts, may need some education here. the only time i came to know about these lifts is when the toyota dealer guy told me you need lift if you bigger tires, so can someone help me with what are the badass tires out there with costs so i know which ones has got the looks i need, robustness i need and fits the cost, then we can backtrack from there about how much life and other things i need, please remember i'm going to become 3.5k poorer once i put the new shell i'm planning on putting onto my 2012 looooong bed.....also what you guys think about the k2s or the falken wilkpeak? or do they not even count in the top 10 badass tire list? i'm taking best snow, rain, road traction , dont give much damn about tire noise unless i should, and then there is gas mileage - and yes the pics above look really cool - i think i'm not settling for anything less than 6" lift, it seems that where the game starts
  21. Oct 29, 2019 at 6:07 PM
    #231
    Mr. Seven
    Mr. Seven New Member
    Rolla, MO
    07 DC 4x4 4.7
    Eibach Lift Level 8 MK6 18x9 ET12 295/70R18's 4.88's Auburn JBA exhaust
    -Eibach Pro lift (coils & struts/ shocks) lowest circlip setting (2")
    -Level 8 MK6 18x9 12mm offset
    -295/70R18's
    -Minor heat & reattachment of front fender liner, rear mud flap removal. No BMC. Haven't heard any rubbing since. 20190820_195313.jpg 20191028_101049.jpg
  22. Oct 29, 2019 at 8:24 PM
    #232
    Mountun Goat
    Mountun Goat She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    I dig it.
    camillethetoy likes this.
  23. Oct 29, 2019 at 9:56 PM
    #233
    TheBeast The Beach
    was that after alignment ? aftermarket UCAs ?
  24. Oct 29, 2019 at 9:58 PM
    #234
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Total chaos uca, yes alignment.
    I think toyo are just very true to size 35x12.5 tires. Seems bigger than a previous brand on my last truck
    TheBeast[QUOTED] likes this.
  25. Nov 4, 2019 at 11:51 PM
    #235
    LBGlossWorks
    LBGlossWorks New Member
    Rawr
    2013 Toyota Tundra RW
    -Front Bumper
    IPMfab Baja Style Bumper
    Baja Designs S8 30” Light Bar
    -Front Suspension
    King 3.0 Coilover with Adjusters
    Total Chaos Upper Control Arm
    Wheeler Superbump Stop
    -Rear Suspension
    King 2.5 Shock with Adjusters
    Toytec Shackles
    -Wheel/Tire
    Toyota TRD Rock Warriors 17x8 50Offset
    BFG KM3 37x12.5x17
    Spidertax 1.25 Spacers
    BMC “Body Mount Chop”
  26. Nov 5, 2019 at 3:39 AM
    #236
    Mr. Seven
    Rolla, MO
    07 DC 4x4 4.7
    ^ That looks superb. Nice truck.
  27. Nov 5, 2019 at 4:49 AM
    #237
    anirudh
    anirudh New Member
    Anirudh
    all the things you said you have put on them - didnt make sense to me given my very limited knowledge but those are some bigger tires, i could see front side of your tires are almost touching the bumper on the top corner - look COOOOOOOOOOL
  28. Nov 5, 2019 at 7:18 AM
    #238
    LBGlossWorks
    Rawr
    Did mod list for you:cheers:
    Mountun Goat and Silverghost like this.
  29. Nov 5, 2019 at 9:18 AM
    #239
    zcarpenter92
    Zach
    NE Colorado
    In sig
    Very good work on that truck, would love to see a build thread on it!
  30. Nov 5, 2019 at 5:10 PM
    #240
    Silverghost
    13 tundra 4x4
    37s my lord that's bad ass ,I see you did b.m.c. any other clearance involved to make them fit , just awesome to see you on 37s with out a drop bracket lift
    Mountun Goat likes this.
