Off-sized spare
Discussion in 'Wheels & Tires' started by focal, Nov 21, 2019.
  1. Jun 27, 2022 at 2:35 PM
    shdwkeeper
    shdwkeeper New Member
    2013 Magnetic Gray Tundra 4x4 Limited CM
    Diamondback Bed Cover (Line-X) Bed Rug Mirror Caps (Paint Matched) Door Handles (Paint Matched) 2020 Sequoia TRD Grill Conversion Morimoto XB Fog Lights Alpharex Pro Jet Black Headlights HIKARI 2021 Acme-X H7 LED Bulbs 6112 (top setting) / 5160 Combo @Coachbuilder1 Differential Drop Kit 1.00" @Coachbuilder1 Coilover shims (2 drive-side 1 passenger side) @Coachbuilder1 Front Bump-stop extensions @Coachbuilder1 Front Bumper Shims @Coachbuilder1 +3 Shackles Fuel Vector 18" +20 Wheels 35x12.50x18 Nitto Ridge Grapplers RCI Off-road Engine Skid plate Desert Eagle Off-road transmission/catalytic converter protection plate Interior: VLEDs 5K cabin interior + LED strip footwell Coupe Custom Battery Mount WeatherTech Floor Mats
    Maybe have your tire shop mount it and see if it fits. I wouldn't put a brand new tire as my spare as it's temporary, until you get your original tire fixed so may be a waste of money.
    But you can always tip the guys at the shop and throw it on the spare rim and do a dry run to see if it fits. That's what I did. You will need to remove those guides though. Pictures of my setup are in previous posts.
  2. Aug 25, 2022 at 3:54 PM
    DanTundra
    DanTundra Danny
    Wilmington, NC
    2015 Ribbon Blue Tundra SR5 4x4
    TRD sway bar, airbag kit, Diamondback HD, LED headlights, Pedal Commander, Bilsteins 6112's up front with shims (2.5 inch lift), 5160s in the rear with CB +2 shackles (1.5 inch lift), Falken Wildpeak AT3W 285/75/18, TRD Pro Grill insert, MattGecko under hood and bed light kit,
    Just an update. I found a used 285/70/18 tire on Facebook for $40, got it mounted and balanced for $42 at Discount Tire. Went to raise it into place under the truck and it fits between the coachbuilder shackles, but it is hitting the rear bumper and resonator from DirtyDeeds.
    I'm supposed to drive 350 miles this weekend. Is it okay for the spare to rub against the resonator? Any thoughts on a quick solution to get through this trip? Should I buy heat wrap at AdvanceAuto and wrap the resonator? Try to adjust it?
    Thank you for everyone's advice and help so far on my spare tire questions!
  3. Aug 25, 2022 at 5:12 PM
    shdwkeeper
    Do you have guides under there pushing it toward back of truck?
  4. Aug 25, 2022 at 5:16 PM
    DanTundra
    DanTundra Danny
    Wilmington, NC
    Nope this is with the guides removed. I didn't get a chance to take any pictures, however, the chain crank is cranked all the way up and the tire is against the rear bumper/hitch and up front i see it pressing against the resonator near the middle of the resonator.
    I've thought about getting some heat wrap to wrap the resonator or trying to unbolt it and adjust it a little, but I'm not sure how much I can adjust it since I had to cut the hole in the exhaust for it.
  5. Aug 25, 2022 at 7:29 PM
    shdwkeeper
    I had to press the tire forward as I raised it, you can also take some air out of it, bring a little air compressor just incase. Harbor freight has them for cheap.
  6. Aug 26, 2022 at 8:16 AM
    DanTundra
    DanTundra Danny
    Wilmington, NC
    Thank you for everyone's feedback. I unbolted the DD resonator and shifted it a little forward and up to make space for the tire. Plenty of clearance now.
    285/70/18 used Toyo Open Country spare on stock rim
    +2 Coachbuilders shackles
    DD resonator
    Removed the tire guides so I guided the tire in place manually as a friend cranked it up.
    Passenger side- There is less than 1" of clearance from shackle to tire
    Driver's side shackle
    Resonator
    Rear bumper
    e30cabrio and biebs96 like this.
  7. Aug 26, 2022 at 3:14 PM
    shdwkeeper
    That's perfect, nice job
    DanTundra likes this.
  8. Aug 26, 2022 at 3:34 PM
    biebs96
    PA
    looks perfect. That’s about all of the clearance I have as well. Also have the resonator installed.
