OEM power locking tailgate??
Discussion in '2.5 Gen Tundras (2014-2021)' started by DocC22, Sep 3, 2017.
  1. Feb 7, 2020 at 7:24 PM
    #91
    daylorb
    daylorb New Member
    Austin, TX
    2016 Limited 4X4
    Go Pack!
    Thank you for the instructions, and thanks to everyone for these posts. I bought the OEM kit, it does indeed work on a 2016 Crewmax LTD. Pretty easy installation. I made a couple mistakes, but got 'er done.
    One recommendation - pay attention to the torque specs. The are not ft-lbs... really no need to complicate things by over-torquing like this idiot did.
    Also - in the pax foot compartment, I already had wires in the hole, so the fitting did not work. I simply lined everything up, cut the new through-compartment gasket to allow the other wire, then taped over all of it with aluminum tape I have lying around (use it to tape weights to track wheels).
    Sealed-up fine without the tape, but good added measure.
    I accidentally ran the connector wire across the brake lines, had to disconnect and re-run it all, but I had not zip-tied anything yet thankfully.
    Works perfectly, very quiet - barely louder than a door. Pretty killer mod for $134 from the dealer online.
    bulldog93 and tlpru like this.
  2. Feb 7, 2020 at 7:37 PM
    #92
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    Glad everything worked out, do you happen to have bed lighting? It seems people with bed lights happen to already have a wire in that same grommet. Also just a random tip probably no one would agree with but put away the torque wrench for non torque sensitive things like this, it's really not necessary and as long as you're not someone prone to over tightening things just go with the German torque of "gutentight" and you'll be fine.
    bulldog93 and BravoDeltaRomeo like this.
  3. Feb 7, 2020 at 8:06 PM
    #93
    daylorb
    daylorb New Member
    Austin, TX
    2016 Limited 4X4
    Go Pack!
    Yes, have the bed lights, that must be it.
    Completely agree on the torque wrench - I really only use it for torquing wheels, oil, not much else. I saw the spec and wondered why it mattered, but then over-torqued it. Not again! I actually snapped the bolt, had to drill it out. Thankfully in my piles of random parts I found a decent match, used locktite and a lock washer and got it to seat nicely.
    Joe333x[QUOTED] likes this.
  4. Feb 8, 2020 at 1:10 PM
    #94
    tech1208
    tech1208 Old Salt, New truck
    Orlando, FL
    2023 Tundra Platinum 4X4 Blueprint Blue
    I apologize for the delay, been out of town. OEM instructions attached.
    daylorb[QUOTED] likes this.
  5. Feb 17, 2020 at 11:49 AM
    #95
    tlpru
    tlpru New Member
    trent
    Southlake, Texas
    2016 Trd Pro
    added power mirrors, auto fold mirror, 2019 TRD head and FOG lights, FORTIN remote start, retrax tonneau cover, 18" fuel BFGK02, TRD sway bar, TRD intake
    great information .... next mod up for my 2016 TRD PRO
    $134 online.
  6. Mar 16, 2020 at 7:47 AM
    #96
    field8909
    field8909 New Member
    Austin Texas
    2020 Voodoo Blue TRD Sport
    Thank you for the info...I will be getting this done this week.
  7. Mar 16, 2020 at 9:51 AM
    #97
    BENWALES
    BENWALES New Member
    Ben
    2020 Tundra White SR5
    Has anyone figure out if the 20's are prewired for this?
  8. Mar 16, 2020 at 9:52 AM
    #98
    field8909
    Austin Texas
    I read in another thread that it is the same
  9. Mar 16, 2020 at 2:57 PM
    #99
    flying dave
    flying dave New Member
    NC
    Hmmm.... I need to do this....
  10. Mar 16, 2020 at 5:08 PM
    #100
    Pitbull410
    Pitbull410 New Member
    2020 TRDPro CM MGM, 2018 LC200 MGM
    The kit comes with the wiring harnesses. Everything is plug and play, no splicing
  11. May 24, 2020 at 8:27 PM
    #101
    jlarkin1918
    jlarkin1918 New Member
    Jared
    Western Massachusetts
    2020 SR5 TRD Offroad Crewmax-Cement
    OEM Spray-In Liner TRD Pro Black Badges & center caps GoRhino RB20 running boards Lomax cover
    Finally got around to installing the OEM tailgate lock kit today, was easier then I expected based on the instructions. This might actually be a case where the instructions were too detailed but I guess better than not enough.
    A couple parts in the instructions I didn’t really follow or had questions on:
    1.) Removing the heat shield? Maybe I screwed something up but I didn’t find it necessary to remove any of the heat shields.
    2. Zip ties can wait until the end. Personally I found it easier to make sure I ran the wires the correct route and had everything hooked up correctly before I went back and zip tied everything.
    3. The wire grommet in the floor and the 4 O’clock position? I think I did this correctly but seating the wire grommet in this position seemed awkward and made the wire make an unnecessary turn.
    I feel like the whole under the truck section could be summarized by “follow the other wire line and avoid the heat shields, exhaust and brake lines.”
    All and all the OEM kit is nice and worth the $130ish to buy and install yourself instead of paying a dealer $600+ to install it. It’s not loud as I’ve heard some complaints about the popnlock kit that everyone used before the OEM kit came out.
    Ignoring the fact that it’s ridiculous that in 2020 this isn’t a standard feature on a 45k truck but oh well now I can lock my tailgate with the click of a button so I’m happy.
  12. Jun 6, 2020 at 6:03 PM
    #102
    getwiser88
    getwiser88 New Member
    2020 TRD Pro
    Just installed today on my 20’ Pro. Instruction where right on and was simple enough for a, “trying to be hands on type”. Thanks for the info!
  13. Jun 7, 2020 at 10:29 AM
    #103
    TundraGuy66
    TundraGuy66 New Member
    Mat
    2020 Cement Tundra TRD
    This is on my list to do as well...my list is getting pretty long!
  14. Jun 9, 2020 at 10:47 PM
    #104
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
  15. Jun 24, 2020 at 1:58 PM
    #105
    Thrance
    Thrance New Member
    2020 Silver Platinum Tundra
    None Yet!
    Sorry for the necromancy of the thread. Thanks for the post. I was just going to have the local dealer do it as well, I am always short on time but they wanted $900 in labor. I am going to have a friend help me install once I order it.
  16. Jul 26, 2020 at 7:26 PM
    #106
    twin_boys_tundra
    twin_boys_tundra New Member
    Terry
    San Jose, CA
    2020 Super White SR5 2WD
    2020 Tundra SR5 Super White * Chrome Mirror Caps and Door Handles * Bedrug Mat and Tailgate * Toyota Running Boards (Free Love It) * Toyota 20" Limited Alloy Wheels and Tires (Free Love It) * All LED conversion * FRAC Harness * Toyota Power Tailgate Lock * Bakflip G2 * Bull Ring Stake Pockets * Tech12Volt Kenwood/Hertz full audio combo * Bilstein 6112/5160 in the works, maybe Black Friday special * BAM 10" Std
    Thanks for the write up and part number. I will get this done with the Toyota OEM part.
  17. Sep 8, 2020 at 11:07 AM
    #107
    brownclee
    brownclee New Member
    Carlton
    2020 Tundra Ltd DC
    I doubt it since the bulk of the cost is in the wiring. I just received the OEM kit and the actuator is only a minor part of the kit.
  18. Sep 8, 2020 at 11:10 AM
    #108
    brownclee
    Carlton
    2020 Tundra Ltd DC
    Seriously, $900 labor! What a rip off. It's at most a 2hr job...even for a novice.
  19. Sep 9, 2020 at 10:34 AM
    #109
    dskizzle6226
    dskizzle6226 New Member
    2020 Magnetic Grey Tundra TRD PRO
    Nitro RidgeGrapplers
    I’m sure several others have said it....
    My 2019 TRD PRO came with led lights inside the bed as well as auto locking tailgate(with the cab doors) from the factory. I recently traded it in for the 2020 TRD PRO basically to get the upgraded stereo and push to start... and the bed has the same light in the bed from the factory; however, the tailgate did not come with the auto locking feature... most likely I’ll have them add it, or do it myself.
  20. Jun 10, 2021 at 2:34 PM
    #110
    Cosmo10
    Cosmo10 New Member
    2010 Tundra Rock Warrior
    Anyone know if this would work for a 2nd gen 2010 tundra I would love for company to appreciate the 2nd gen as much as the 2.5gens haha
  21. Jun 11, 2021 at 5:50 PM
    #111
    tundras00
    tundras00 New Member
    Having it done on my truck, a tech that has done this more than once will spend an hour or less on this install, especially since they have a lift. $900 is theft but what else is new from stealerships.
  22. Dec 24, 2021 at 5:24 AM
    #112
    Tundra2Yak
    Tundra2Yak New Member
    2016 1794 4x4 CM
    Pro Comp 6" Lift Fuel Renegade d263 Nitto Ridge Grappler 35 x 12.5 x 20 Borla cat-back exhaust Volant intake Bakflip MX4
    Digging this up again. Does the OEM kit work with factory key fob?
  23. Dec 24, 2021 at 7:16 AM
    #113
    NewOwnerHere
    NewOwnerHere New Member
    Yes, the oem kit works with factory key fob. Install took about 1.5 hrs while watching YouTube videos to double check I was doing things correctly
    Tundra2Yak[QUOTED] likes this.
  24. Dec 24, 2021 at 7:39 AM
    #114
    normagene
    normagene New Member
    Normagene
    New England
    2021 Cement DC Limited Texas Edition
    Texas Edition
    Yes it does. Press “unlock” once and only the drivers door is unlocked. Press twice and the drivers door, passenger door/all doors and the tailgate unlock.
    Press “lock” once and everything locks
    Super easy to install.
  25. Dec 24, 2021 at 11:40 AM
    #115
    GCanuck
    GCanuck Member since 2020
    Gary
    BC,Canada
    2020 Tundra DC MGM TRD Sport
    TRD Swaybars. Line-X bed liner. Toyota Tri-fold Tonneau. N-fab side bars. TRD cold air. AMP bed extender. Rough Country Level kit. BFG A/T K02. RCI Skids. OEM Tow mirrors. TRD exhaust
    Last time I was at the dealer getting service I got a quote on the dual TRD exhaust. He printed me a sheet that was applicable to my VIN with every OEM option price and instal rate.
  26. Dec 24, 2021 at 12:21 PM
    #116
    GCanuck
    Gary
    BC,Canada
    $600+??? My dealer sheet says $395 Canadian installed total in my hometown.
    jlarkin1918[QUOTED] likes this.
  27. Dec 29, 2021 at 5:51 AM
    #117
    BENWALES
    BENWALES New Member
    Ben
    Not a hard install at all. You can do this in your driveway. Its all plug and play.
  28. Dec 29, 2021 at 6:32 AM
    #118
    normagene
    Normagene
    New England
    Texas Edition
    Can you post that price list?
    Like to see the part prices as well as the installed price. I paid $129.41 plus sales tax for the OE Remote Tailgate Lock from my dealership.
    Did the install myself since it’s such an easy “do it yourself” modification!
  29. Dec 30, 2021 at 10:21 AM
    #119
    jlarkin1918
    Jared
    I’ll be honest, I don’t remember if that $600 price was what I got from my dealer or I read it somewhere else on this site.
    Either way I wasn’t paying it and the diy self install was worth it.
