nsv light bar install
Discussion in 'Lighting' started by gregfocker77520, Mar 10, 2018.
  1. Oct 2, 2018 at 6:12 AM
    #61
    Headlight Revolution
    Headlight Revolution New Member Vendor
    Atlanta, GA
    It most certainly will! :)
    Sas likes this.
  2. Oct 27, 2018 at 10:22 PM
    #62
    Young80i
    Young80i New Member
    Kyle
    Garden Grove CA
    2015 Platinum
    thinking about to buy one.. wanna know how to install this to a Switch-Pros
    Headlight Revolution likes this.
  3. Oct 29, 2018 at 6:10 AM
    #63
    Atlanta, GA
    It's a bit of work, as you have to assign each function, but it can be done!
  4. Oct 29, 2018 at 6:11 AM
    #64
    Atlanta, GA
    Love hearing that man, thank you! :) Hopefully you're loving that setup as much as we do!
  5. Oct 30, 2018 at 10:15 AM
    #65
    Lambeau
    Lambeau New Member
    2024 Black Tundra 1794 Limited Edition
    285/60/R20 BF Goodrich KO2’s
    I installed mine last week per the instructions and have several issues. The driver's front turn signal doesn't work anymore. With truck headlights on the DRL's go bright/dim with the turn signal. I got Jensen's phone number and need to call him to figure out a solution.
  6. Oct 30, 2018 at 10:19 AM
    #66
    Atlanta, GA
    Ah no! There can be little hiccups, but Jenson knows these light bars like the back of his hand, he'll get you fixed up! :)
  7. Oct 30, 2018 at 10:22 AM
    #67
    Lambeau
    Lambeau New Member
    Yeah just need to give him a call. Should be an easy fix.
  8. Oct 30, 2018 at 10:37 AM
    #68
    iHacker
    iHacker SW TRD PRO
    Mario
    TRD PRO Super White CM
    2019 TRD PRO LED Headlights, 2019 TRD PRO Rigid LED Fog lights, All LED Interior, LED Cargo Lights, Bed LED Lights, Undercover Flex, Husky Weather beater floormats, FORTIN EVO ONE remote start, TDR Cold Air Intake, Tundra tail gate inserts, Pop & Lock...
    I guess you don’t have to use the t-harness and simply splice the jumper wire to the side maker, just remember your truck doesn’t have Amber parking/DRL the Amber in the center is for blinkers only.
    The t-harness also is wired for the old 3157CK bulb and the new 2018+ LED headlights use a 7444NA bulb so they have the ground terminals switched.
  9. Jan 31, 2019 at 3:11 PM
    #69
    Steve Tundra
    Steve Tundra New Member
    Steven
    2022 4x4 platinum
    I just ordered the nsv light gem 2 I have a 14 platinum but have also added the 18 headlights. What re pinning should I be doing?
  10. Feb 1, 2019 at 6:58 AM
    #70
    Atlanta, GA
    Please refer to our install video! :)
    Link: https://www.youtube.com/watch?v=xPZbmI4QMQg&t=391s
    Time: 4:29
  11. Feb 6, 2019 at 10:48 AM
    #71
    Steve Tundra
    Steven
    2022 4x4 platinum
    So treat it like I have the old headlights first and do the tapping on the original harness before the adapter harness? Sounds pretty straight up then.
  12. May 17, 2019 at 4:40 PM
    #72
    anthonygan
    anthonygan New Member
    2017 Cement TRD PRO
    7in BDS lift, Spyder Smoked Taillights,
    I have a gen 1 light bar, but I want the ablity turn off the drls. Do I just repin #3 into 8?
  13. Jul 30, 2019 at 9:28 PM
    #73
    explore more
    explore more New Member
    2018 Tundra
