nsv light bar install
Discussion in 'Lighting' started by gregfocker77520, Mar 10, 2018.
  1. Mar 10, 2018 at 7:52 AM
    gregfocker77520
    gregfocker77520 [OP] New Member
    luis
    2018 Graphie tundra crewmax sr5
    none yet!!
    Looking for help on doing the install on my 2018 crewmax, i added 18 led headlights using @iHacker harness.
    the only change that i made for the install is in attached picture.
    Can some one tell me what changes i need to make?
  2. Mar 10, 2018 at 8:24 AM
  3. Mar 10, 2018 at 9:46 AM
    1UPPER
    1UPPER Not A New Member
    TEXAS
    Flux capacitor!
  4. Mar 10, 2018 at 12:02 PM
    iHacker
    iHacker SW TRD PRO
    TRD PRO Super White CM
    2019 TRD PRO LED Headlights, 2019 TRD PRO Rigid LED Fog lights, All LED Interior, LED Cargo Lights, Bed LED Lights, Undercover Flex, Husky Weather beater floormats, FORTIN EVO ONE remote start, TDR Cold Air Intake, Tundra tail gate inserts, Pop & Lock...
    @Sting Ray completed this and also @inferno_pro_satx is the master for NSV bar, in your case your 2018 SR5 is wired same as the old 1794/Platinum’s you will need to use a jumper they provide to get signal from side marker to Dim the NSV bar at night, follow the instructions they provide for 2014-2017 1794/Platinum models
    I can’t help too much on this because I never tried this install myself but installation seems to be pretty straight forward
    https://youtu.be/cuMsVpeOMdA
    https://youtu.be/Y1wEQAX0oPM
    https://youtu.be/YnL2phEWzdk
  5. Mar 10, 2018 at 12:22 PM
    Sting Ray
    Sting Ray New Member
    Ray
    Vegas
    2017 SR5 Crewmax
    Not enough space here...
    I have a thread that talks about this
    iHacker[QUOTED] likes this.
  6. Mar 10, 2018 at 12:24 PM
    Sting Ray
    Ray
    Vegas
    2017 SR5 Crewmax
  7. Mar 10, 2018 at 12:36 PM
    gregfocker77520
    luis
    none yet!!
    Cool just gets confusing with the different types like sr5 or 1794/platinum wiring and jumper this and that. My truck is sr5 but has 1794/platinum wiring for the 18 headlights conversion.
    Just like to get the cliff notes steps of what I need to do other than what’s on the 3 nsv install videos.
  8. Mar 10, 2018 at 12:47 PM
    Sting Ray
    Ray
    Vegas
    2017 SR5 Crewmax
    Pming you
  9. Mar 11, 2018 at 7:08 PM
    gregfocker77520
    luis
    none yet!!
    The pins for the 12 pin plug has #8 pin but not #3. Stuck!!
    I did contact inferno_pro_satx but still waiting on him to see if can help.
    Just wondering if someone else can help out as well.
    blue16 likes this.
  10. Mar 11, 2018 at 7:36 PM
    Sting Ray
    Ray
    Vegas
    2017 SR5 Crewmax
    Read the directions. It talks about there not being a pin purposely.
  11. Mar 12, 2018 at 6:15 AM
    gregfocker77520
    luis
    none yet!!
    Look at instructions. Keep in mind I don’t have a #3 and I have a #8 on my wires. Where does the #8 go not having the #3 throws everything off for me. If they had #3 wire and no #8 that would be straight forward to do.
    If you look at it says if I have gen2 to put the #3 in the #8 spot so if I leave that alone where does the #8 wire go.
    Just confused here
  12. Mar 12, 2018 at 8:58 AM
    gregfocker77520
    luis
    none yet!!
    Spoke with Chris with headlight revolution and 1 have a gen2 nsv. No pin 3 now
    1UPPER likes this.
  13. Mar 12, 2018 at 9:22 AM
    Sting Ray
    Ray
    Vegas
    2017 SR5 Crewmax
    Whats the difference in the gen2? Vs gen 1?
  14. Mar 12, 2018 at 9:30 AM
    gregfocker77520
    luis
    none yet!!
    Not sure still working on install
  15. Mar 12, 2018 at 9:49 AM
    1UPPER
    TEXAS
    Flux capacitor!
    I spoke with a few months back with NSV rep about the gen2 lightbar. They removed the strobe light feature switch and installed a switch to turn the daytime running lights on and off.
  16. Mar 12, 2018 at 9:51 AM
    gregfocker77520
    luis
    none yet!!
    My switches still say strobe
    1UPPER likes this.
  17. Mar 12, 2018 at 9:53 AM
    1UPPER
    TEXAS
    Flux capacitor!
    Hmm..Let us know after your install if you still have the strobe function.
    Sting Ray likes this.
  18. Mar 12, 2018 at 11:34 AM
    gregfocker77520
    luis
    none yet!!
    Yes doesn’t strobe anymore. Kinda wanted the strobe function. It turns on off the drl ascent lights
  19. Mar 12, 2018 at 11:43 AM
    Sting Ray
    Ray
    Vegas
    2017 SR5 Crewmax
    any other differences? Or is that it?
  20. Mar 12, 2018 at 11:44 AM
    gregfocker77520
    luis
    none yet!!
    That’s it bar doesn’t fully come one unless you have high beams on.
  21. Mar 12, 2018 at 12:21 PM
    1UPPER
    TEXAS
    Flux capacitor!
    The first and second gen both have the high beam lightbar on only with high beams on function. The strobe was removed because of liability reasons.
  22. Mar 12, 2018 at 4:00 PM
    inferno_pro_satx
    inferno_pro_satx New Member
    Roger
    2016 Tundra TRD Pro
    If you really wanna bypass the high beam light bar safety feature lmk.
  23. Mar 12, 2018 at 5:39 PM
    Sting Ray
    Ray
    Vegas
    2017 SR5 Crewmax
    Wonder what would happen if you pinned it the same way it was originally supposed to be??? Would the strobe work then?
  24. Mar 12, 2018 at 6:50 PM
    gregfocker77520
    luis
    none yet!!
    Like put the #8 pin in the #3 slot? I could try but What if it mess something up. I’m not willing to take risk and burn the light bar up.
  25. Mar 14, 2018 at 7:30 PM
    eriksghost
    eriksghost New Member
    Is there a way to get the STROBE function back?
  26. Mar 14, 2018 at 7:34 PM
    eriksghost
    Can it be by-passed? I really want that strobe
  27. Mar 14, 2018 at 7:51 PM
    eriksghost
    Wow that kinda makes sense.
  28. Mar 14, 2018 at 8:26 PM
    1UPPER
    TEXAS
    Flux capacitor!
    I would think it could but I’m not sure. Only way to know is try the original install directions or call NSV.
  29. Mar 14, 2018 at 8:46 PM
    eriksghost
    I called them and they said it’s disabled. They said to look in the forums to get it back. Bummer.
  30. Mar 14, 2018 at 8:47 PM
    eriksghost
    Now I need to figure out how to disable the DRL on the light bar.
