NSV Light Bar Install Tips
Discussion in 'Lighting' started by cook2kill, Feb 10, 2019.
  1. Apr 21, 2020 at 9:19 AM
    #121
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    @Headlight Revolution please sort us all out on this if you can. We want to know: Should our DRL's dim when headlights are on? Thank You!!
  2. Apr 21, 2020 at 10:13 AM
    #122
    Jmduncan1
    Jmduncan1 New Member
    2017 Tundra Crewmax- gray
    email sent.
  3. Apr 22, 2020 at 10:23 AM
    #123
    Headlight Revolution New Member Vendor
    Atlanta, GA
    Regarding the Dimming with the NSV:
    There are 3 Revisions of this light bar.
    The 1st version did not dim whatsoever, it was a constant power DRL.
    The 2nd version had issues with dimming, where on some applications it would dim without an issue and others where it wouldn't dim at all.
    The 3rd version has been fully swept and revised so that it will dim at all times! If it does not dim down, you would want to re-check your Wiring/Pinning for any errors.
    Beesta likes this.
  4. Apr 26, 2020 at 7:44 PM
    #124
    rmvcard0303
    rmvcard0303 New Member
    Ray
    San Gabriel Valley, CA
    2019 White Tundra TRD Sport CM
    I’d rather not list. My wife might see it.
    Can anyone please share a photo of the depin tool you use for the NSV connector. I need to pull the wire loom off the hood so i need to depin the whole connector. I’ve tried several and can’t seem to pull the wires off. Is there a trick to this? Thanks!
  5. Apr 26, 2020 at 7:49 PM
    #125
    KERNEL_DALE
    KERNEL_DALE New Member
    Norcal
    19’TRD-PRO
  6. Apr 26, 2020 at 7:51 PM
    #126
    rmvcard0303
    Ray
  7. Apr 30, 2020 at 9:26 PM
    #127
    Greywind Tundra
    Greywind Tundra New Member
    Stephen
    San Diego, CA
    2020 Cement Tundra TRD Off-Road CM
    I assume I have gen 3 because I just bought it but anyone figure out how to have the bar com on by pressing the button on the panel even when the high beams are not on?
  8. Jul 11, 2020 at 10:55 PM
    #128
    DMXTundra
    DMXTundra New Member
    Help please! i regret to introduce my first post with a weird situation with this new install, has anyone experienced the following? Based on the instructions, the blue wire needs to be cut at the headlight housing for a 2018 Tundra with DRL and LED lights.
    Once I plugged the battery, I ran into some issues. I get power going into the switch panel, the three buttons light up when pressed but I do not get the lightbar, the swipe or the DRL’s to turn on. I tried different settings such as lights on with the high beams on, but no results on the lightbar.
    The only successful results I get is when I locked or unlocked the truck. The swipe feature of the lights does this once, and for this reason i'm a bit suspicious about the blue wire. Any suggestions on how to trace the problem? Any info would be greatly appreciated.
  9. Jul 11, 2020 at 11:08 PM
    #129
    Greywind Tundra
    Stephen
    San Diego, CA
    If you have LED’s you need to cut that blue wire, I had the same worry but it’s what you have to do.
    remember the power/lights on the switch panel come from the “tap in” you did to the cigarette lighter power so that really doesn’t mean anything.
    My best guess is that the pin connectors are not seated properly or maybe even in the wrong order? I assume you have the newest version of the light so make sure you skipped pin #3.
    use the search bar there are a bunch of NSV talk on here maybe that will give you more info. Good luck
    Beesta likes this.
  10. Jul 11, 2020 at 11:27 PM
    #130
    DMXTundra
    Thanks Greywind! I got one of the recent models 1417TUN.NSV.LIGHTBAR. I did skipped pin #3 during the install, but I'll recheck my pin connectors once again. I'll keep searching for similar issues.
  11. Aug 9, 2020 at 9:09 PM
    #131
    RK65Tundra
    RK65Tundra New Member
    Rod
    2018 Tundra Limited
    So I’m not sure whether to start a brand new post or see if others can assist me on this thread so let me know if I need to start a new thread. Earlier this year I purchased and installed the NSV light bar on my 2018 Tundra (I have the LED head lights). I got everything working according to the install instructions, but a few weeks ago I took my Tundra in to the dealer for unrelated service and they had a recall issue on the Tundra that involved the front turn signals. Apparently, their have been numerous complaints about the Tundra front turn signals on the LED headlight units being too dim. So Toyota had a ‘fix’ that changed the voltage going to the turn signal lights. As a result, one function of the NSV light bar was disabled in Toyota doing this... it was the high beams turning the entire light bar on; all other light bar functions still work. The service person at Toyota proactively told me this when they finished the work, so they obviously saw the wiring harness connections from the NSV light bar. However, because of ‘liability’ reasons, they couldn’t correct high-beams for the light bar. But the service person did tell me that he thought it would be an easy thing to change “one wire” that led to the turn signal. He said something like “you just need to change the wire to use the higher current wire” or something to that affect. Unfortunately, I’m not sure what to do - I’m a bit intimidated by the complexity of the NSV connectors, and it’s outside my comfort zone to ‘experiment’. I’m hoping someone is familiar with the overall wiring scheme of these light bars and Tundra headlight units AND that there really is something easy I can do without screwing something up or making things worse. I really don’t know exactly what Toyota did, but I’m thinking that others that have taken their Tundras into Toyota for this recall/fix are experiencing the same issue and have the appropriate corrective action they can describe... I’m happy to provide additional information so just let me know what I can add to help figure this thing out...
    Thanks in advance to your posts!
    Rod / Oregon
  12. Aug 9, 2020 at 9:21 PM
    #132
    KERNEL_DALE
    Norcal
    19’TRD-PRO
    i too have the same experience. What they did was to move that white wire on the next slot of the connector of the turn signal.
  13. Aug 20, 2020 at 6:08 PM
    #133
    JAMES
    JAMES COLORADO TUNDRA
    2016 Colorado Tundra Crew Max MGM
    6" PC Stage II Coil Over 37x12.50x20 Toyo RT 20" Fuel Recoil Wheels N-Fab black Step Bars Splash 5% Window Tinting Clear Mask Protection Premium leather interior with 2-front Heat/Cool seats Viper 5806v Alarm w/ remote start Garmin 2589 Garmin Dash Cam Dual Flo-Pro 3.5 18" Glass Packs Black Chrome exhaust tips Bakflip Bed Cover Weather Tech Floor Mats Bushwacker Pocket style with matching paint TRD Pro Grill Tesla 12.1'' Head Unit Oh Shit handle on Drivers Side Under seating Storage 4.88 Gears NSV LED Light bar Upgraded Sound system with JL Audio Speakers and Sub
    I have a question for all who have the NSV Light bar that have the Strobe light. My light bar works perfect, no problems. The DRLs dim when I switch to the parking lights and when I turn on the headlights. The only thing I don’t like is the DRLs being on all the time. I would like to delete them but don’t know how. Has anyone deleted this feature. I asked HR and they said their was no way to do this.
  14. Aug 20, 2020 at 6:14 PM
    #134
    Tundyfundy
    Bay Area, CA
    Sorry, no help here, I have a switch for the DRL lights on the supplied panel.
    Beesta and HulkSmurf14 like this.
  15. Aug 20, 2020 at 6:20 PM
    #135
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    If you have strobe, your DRLs will always be on...otherwise DRLs are on the toggle...this is for v2 & v3 harnesses with DRL toggle in-lieu of strobe...
  16. Aug 20, 2020 at 6:21 PM
    #136
    JAMES
    Yeah, the newer versions swapped out the Strobe function for the DRL on and off switch. Although, I like having the Strobe lights I just don’t like the bright DRLs.
  17. Aug 20, 2020 at 6:22 PM
    #137
    JAMES
    I’m looking for maybe something as easy as depinning a wire that would disable the DRLs.
  18. Aug 20, 2020 at 6:26 PM
    #138
    Tundyfundy
    Bay Area, CA
    You could put some yellow or orange lamin-x film over the two end sections, or tint them!
  19. Aug 20, 2020 at 6:31 PM
    #139
    JAMES
    It's funny you say this. I bought some yellow lamin-x film. Cut it to fit. After 6 layers of film on each side it was still very bright. I'm open to any other suggestions to dull the brightness.
    excelw and Tundyfundy[QUOTED] like this.
  20. Aug 20, 2020 at 6:40 PM
    #140
    Tundyfundy
    Bay Area, CA
    Dark window tint? Maybe a combination of the two? Also I believe the nsv is getting the DRL signal from the headlight location when you plugged the connector into the headlight motor harness. Maybe you can intercept the DRL signal wire at the headlight motor and add a switch to it. Shouldn’t be that hard. Just find out which wires from your original harness feed the DRL.
    HulkSmurf14 likes this.
  21. Aug 20, 2020 at 6:43 PM
    #141
    Tundyfundy
    Bay Area, CA
    You may also be able to depin the DRL wire at the driver kick panel which I did to disable my factory DRL. @iHacker may be able to help you out. It should be as simple as snipping a wire.
  22. Aug 20, 2020 at 6:48 PM
    #142
    JAMES
    Good suggestions, I will look into that and See what I find.
    I was hoping their was more people out their who had the same issues and found an easy fix.
    Tundyfundy[QUOTED] likes this.
  23. Aug 20, 2020 at 6:51 PM
    #143
    JAMES
    I’ll give him a try, thanks!
  24. Aug 31, 2020 at 7:42 PM
    #144
    Beesta
    Beesta New Member
    Jay
    Loudoun County
    2019 Pro Midnight Black Metallic
    Funny how i got LED’s and also cut the blue wire but lost driver side turn signal ... reconnect and everything works fine ... well except light bar does not come on if on AUTO ...
  25. Sep 2, 2020 at 12:20 PM
    #145
    Beesta
    Beesta New Member
    Jay
    Loudoun County
    Guess i have the 3rd Gen in my 2019 .. but the issue i have is DRL on NSV doesnt dim when auto nor Light switch on ... did you do anything diff to fix that issue .?
  26. Sep 10, 2020 at 3:38 AM
    #146
    Beesta
    Beesta New Member
    Jay
    Loudoun County
    Update .. lost parking lights .. 10 amp tail kept blowing fuse. Unplugged patch harness and re plug steering y harness. Everything works fine ... please Help ... dont want to see the 1K NsV just for hood ornament. Thanks
  27. Sep 21, 2020 at 2:57 PM
    #147
    SweetwoodMac
    SweetwoodMac @toytundramac
    Mac
    2017 Silver Tundra Platinum
    4.5" BDS Coilover Suspension 22x10 Fuel Contra -18MM Offset 35x12.50r22 Nitto RT AMP Xtreme Powerstep
    Did you ever figure out what your issue was? I lost mine over the weekend after installing new headlights. Everything else still functions.
  28. Sep 21, 2020 at 4:56 PM
    #148
    KERNEL_DALE
    Norcal
    19’TRD-PRO
    If you lost your swipe during lock n unlock. You probably did something on the harness that connects the signal light.if you did put it back to the original placement of the wire
  29. Sep 21, 2020 at 5:00 PM
    #149
    KERNEL_DALE
    Norcal
    19’TRD-PRO
    Check your fuse box under the drivers side and look for the fuse “TAIL”
  30. Sep 21, 2020 at 7:04 PM
    #150
    Beesta
    Beesta New Member
    Jay
    Loudoun County
    Got it working ... thanks to @ElNopal !!! Great dude .. had to re pin my turn signal plugs since dealer had a recall on them.
    ElNopal and HulkSmurf14 like this.
