NSV Light Bar Install Tips
Discussion in 'Lighting' started by cook2kill, Feb 10, 2019 at 7:02 PM.
  1. Feb 10, 2019 at 7:02 PM
    cook2kill
    cook2kill [OP] New Member
    2018 CM
    Just finished installing the NSV Hood Bulge Light Bar.
    I researched extensively and watched @Headlight Revolution install videos at length, several times.
    Update**** After driving it for a day I noticed a few things I’m trying to get worked out with @Headlight Revolution
    1)With my headlights in the off position both of the lightbar’s DRLs flash when I use either blinker
    2)With my headlights in the Auto position during the day both DRLs flash when I use either blinker
    3)With Headlights on the bar seems to operate as designed with the exception of the headlight DRLs not being illuminated. Full disclosure I guess I never looked to see if the headlight DRLs were on when the headlights were on. Maybe someone could answer that?
    A few things that may help the next person looking to install this light bar:
    1) Put pin 8 in the pin 3 slot and you’ve got strobe on the DRL Switch (maybe this is why I’m having the above issues?)
    2) (huge!)When running the interior harness go through the firewall first so you can pull all the slack through and have ample space to pin the 6 pin connector. Then pull it back from the interior to finish running the harness. Trying to pin the connector 6” from the firewall was a pain in the ass.
    3) 2018+ Getting to the headlight motor plug was a huge pain. Ended up taking the headlight out to do this. If someone knows a better way to remove that plug and tap the purple wire. Please share.
    Numbers 2 and 3 had I done them right off the bat would have saved me at least 30 minutes.
    OkcthunderGuy, Krezz and zlaneb like this.
  2. Feb 10, 2019 at 8:32 PM
    Krezz
    Krezz Doesn't want to be new member
    Kevin
    Southern Ontario, Canada
    2018 Tundra Crewmax Platinum
    See Build Thread.
    You know you need pictures! ;)
  3. Feb 11, 2019 at 5:02 AM
    Racingjohndeere55
    Racingjohndeere55 I thought it was funny.....
    NEPA
  4. Feb 11, 2019 at 1:51 PM
    PinoyRN
    PinoyRN Manila Gorilla
    Sammy
    Phoenix, AZ
    ‘18 MGM TRD SPORT
    @cook2kill Did your light bar come with the connector that goes on the cut blue wire, and also the blue T-tap for the purple wire? My kit doesn’t have either item.
  5. Feb 11, 2019 at 3:12 PM
    cook2kill
    2018 CM
    Yes it came with two red T-taps and a jumper wire with connectors.
  6. Feb 11, 2019 at 3:15 PM
    cook2kill
    2018 CM
    I will say I discovered today that when I turn on my blinker both DRLs on the light bar flash. Seems like it would be confusing for oncoming drivers and mostly illegal.
    I do believe I have wired it correctly but who knows. Waiting on an answer from @Headlight Revolution in his thread.
  7. Feb 11, 2019 at 3:19 PM
    Padj
    Padj Life is what happens when you're making plans
    Denver, Colorado
    2019 Limited CM TRD MGM
    Pictures? :/
  8. Feb 11, 2019 at 3:25 PM
    Bongskie
    Bongskie New Member
    2016 Black Crew
    6" Pro Comp Kit, Mayhem 20" rim, Toyo M/Ts
    Thanks for all the tips. :thumbsup:
  9. Feb 11, 2019 at 3:33 PM
    cook2kill
    2018 CM
    As soon as the massive rain stops I’ll add a bunch of photos.
  10. Feb 11, 2019 at 10:16 PM
    sryota
    sryota New Member
    Norcal
    '18 Tundra Platinum
    Did you cut the blue wire on the headlight T harness like what the instructions said? Also what did you connect the headlight T harness to? Since I have a '18 platinum the video was different with connecting the headlight to the split on the harness. I pretty much got everything done besides connecting the headlight harness part and using the t-tap since the purple wire is a pain to get to like you said. Didn't want to start snipping wires before I mess something up.
  11. Feb 12, 2019 at 9:45 AM
    cook2kill
    2018 CM
    Cut the blue and jumped to the purple as per the ‘18 instructions. Talking with @Headlight Revolution now. I’ll update when we get it figured out.
  12. Feb 12, 2019 at 12:06 PM
    PinoyRN
    Sammy
    Phoenix, AZ
    ‘18 MGM TRD SPORT
    @Headlight Revolution @cook2kill
    Can somebody who’s wired an ‘18 help me with this part?
    Step 2: “Using the blue wire junction populate connector on the ends as shown in step 2.”
    I’m not sure I did this step correct because my lightbar DRL’s are not working. What I did was cut the blue wire between the plugs, T-tap the other end of the blue wire, and connect that T-tap to the T-tapped purple wire. The picture in the instructions in step 2 is confusing...what’s the second blue wire coming out of the connector?
  13. Feb 12, 2019 at 7:14 PM
    cook2kill
    2018 CM
    https://youtu.be/Y1wEQAX0oPM
    ^^^watch from 13:00. He explains it. Sounds like maybe you tapped the wrong part of the harness but I don’t know without seeing it.
  14. Feb 13, 2019 at 10:50 AM
    Headlight Revolution Vendor
    Please check your PMs, my good sir!
