NSV Light Bar Install Tips
Discussion in 'Lighting' started by cook2kill, Feb 10, 2019.
  1. Apr 16, 2020 at 5:17 PM
    #91
    Jmduncan1
    Jmduncan1 New Member
    2017 Tundra Crewmax- gray
    So my DRL on the NSV dim when the headlights are on, but the DRL are always on no matter what. Anyone have any idea why that may be?
  2. Apr 16, 2020 at 5:23 PM
    #92
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    Do you have a DRL switch on the panel? It should toggle those drls. I am also almost positive you DRL don’t dim or shouldn’t dim. At least that’s the info I got from headlight revolution when I installed mine about 4 months ago.
  3. Apr 16, 2020 at 5:32 PM
    #93
    Jmduncan1
    Yeah I have the DRL switch on the panel. They definitely dim. I’ll post pics in a few minutes. Gotta go snap em.
    Tundyfundy likes this.
  4. Apr 16, 2020 at 5:34 PM
    #94
    Tundyfundy
    Bay Area, CA
  5. Apr 16, 2020 at 5:44 PM
    #95
    Jmduncan1
    Here are the pics:
  6. Apr 16, 2020 at 5:44 PM
    #96
    Jmduncan1
    One more.
  7. Apr 16, 2020 at 5:45 PM
    #97
    Jmduncan1
    So they are with headlights off, parking lights on and headlights on. The NSV sims as soon as the Peking lights are turned on.
    again, the only thing I did not do on the install was the blue jumper wire.
  8. Apr 16, 2020 at 5:46 PM
    #98
    Tundyfundy
    Bay Area, CA
    To me this looks like the top pic. It’s hard to tell because the dimming effect may be due to the headlights making the drls seem dimmer. I covered my lights with a towel and was able to see that they don’t actually dim although it was tricky to see. I don’t have an answer for your
  9. Apr 16, 2020 at 5:47 PM
    #99
    Jmduncan1
    I’ve done it in front of glass and you can actually see them dim. Lemme see if I can do a short video.
  10. Apr 16, 2020 at 5:48 PM
    #100
    Jmduncan1
    The top pic is just parking lights on. Second pic is DRL on with headlights switched off.
  11. Apr 16, 2020 at 5:53 PM
    #101
    Tundyfundy
    Bay Area, CA
    if you say so I don’t doubt you. None of the above people have drls that dim so maybe they changed it? @Headlight Revolution should chime in soon.
  12. Apr 16, 2020 at 6:02 PM
    #102
    Jmduncan1
    This is why I’m perplexed. The switch does nothing, but they dim when the parking lights or headlights are turned on. I like the feature, I just wan the ability to turn them off by the switch if I’d like to.
    it may be something to do with the blue jumper I never installed.
  13. Apr 16, 2020 at 7:09 PM
    #103
    Tundyfundy
    Bay Area, CA
    I was under the impression the blue jumper didn’t need to be done. I thought that was something for older models, but HR doesn’t always send out the most current instructions. I just installed it. Didn’t jump anything and it works exactly as described.
  14. Apr 16, 2020 at 7:16 PM
    #104
    Jmduncan1
    i Appreciate all the responses. Hopefully someone else will have run across this and shed some light on what may be the issue. Wish I had a wiring diagram so I could try and run it down myself.
  15. Apr 16, 2020 at 10:52 PM
    #105
    Joe
    Joe New Member
    Joe
    Northeast Pennsylvania
    2019 Tundra TRD Pro ( Voodoo Blue)
    Driver side grab handle and The tailgate Tundra letters from Toyota Am looking at rear step and the Tonneau cover , also the safe
    Tundyfundy[QUOTED] likes this.
  16. Apr 17, 2020 at 1:19 AM
    #106
    Tundyfundy
    Bay Area, CA
  17. Apr 17, 2020 at 4:24 AM
    #107
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    The wire for your pin #8 has been moved...or your pin #3 is now filled...I thought the v1 harness and instructions enabled the DRLs to dim....just spitballing ideas, but are you sure on your pinouts to the bar itself? Cool/not cool feature...if can be toggled...
  18. Apr 17, 2020 at 6:05 AM
    #108
    Jmduncan1
    I’m 100% certain the connector is pinned correctly. That was the first, second and third thing I checked. My DRL switch does absolutely nothing, so I cannot toggle the dimming either.
  19. Apr 17, 2020 at 6:09 AM
    #109
    Donn
    Donn New Member
    Donn
    Tundra 2017
    BDS LIFT ICON SUSPENSION
    Here’s mine on top of skid plate
  20. Apr 17, 2020 at 6:13 AM
    #110
    Jmduncan1
    Anyone wanna shoot me a pic of their connector so I can compair?
  21. Apr 17, 2020 at 10:24 AM
    #111
    Joe
    Joe New Member
    Joe
    Yes especially what we paid, mine do not look like they dim , however the DRL switch operates them regardless of what the light status is ....also it is not mentioned In the owners manual, yet says the switch operates the strobe . Personally I like the DRL switch
  22. Apr 17, 2020 at 12:18 PM
    #112
    Tundyfundy
    Bay Area, CA
    This is exactly how mine works. I think this is how it functions. I’m guessing
    give me a sec
  23. Apr 17, 2020 at 1:03 PM
    #113
    Tundyfundy
    Bay Area, CA
    Beesta likes this.
  24. Apr 17, 2020 at 1:04 PM
    #114
    Tundyfundy
    Bay Area, CA
    So did you skip port 3? There is no pin 3. Did you start pin 1 at the correct location? Verify you plugged the pins in order.
  25. Apr 17, 2020 at 1:10 PM
    #115
    Tundyfundy
    Bay Area, CA
    Here’s the other connector. Took my hood bulge apart to snap these so hoping they help!
    Beesta likes this.
  26. Apr 17, 2020 at 1:20 PM
    #116
    Jmduncan1
    So everything is correct on my plug. Pin 3 is open as it should be. I even pulled the orange thing and ensured all the pins were seated this go round. Same results. I’m stumped.
  27. Apr 17, 2020 at 1:39 PM
    #117
    Tundyfundy
    Bay Area, CA
    Something wrong with your harness or something in think. I’d contact the seller and get a replacement.
  28. Apr 17, 2020 at 4:27 PM
    #118
    Jmduncan1
    When it stops raining and I have some time, I’m gonna pull out the power probe and see what I have on each pin. Then see if I can figure out what the deal is and if I can work around or correct it.
  29. Apr 17, 2020 at 6:18 PM
    #119
    Tundyfundy
    Bay Area, CA
    Good man.
  30. Apr 21, 2020 at 9:13 AM
    #120
    Headlight Revolution New Member Vendor
    Atlanta, GA
    I just now caught wind of this Thread, my bad man! With this going more In-Depth, Can we get you into an Email by chance? That would be the most efficient route to get this all patched up! :)
    Sales@HeadlightRevolution.com
