NSV Light Bar Install Tips
Discussion in 'Lighting' started by cook2kill, Feb 10, 2019.
  1. Oct 14, 2019 at 5:36 PM
    #61
    Mr. Arroz
    Mr. Arroz New Member
    Joint Base MDL, NJ
    2018 Platinum Tundra
    BedRug Full Bed Liner Driver side Grab Handle Color matched mirror caps/door handles Truxedo PROX15 Tonneau Cover Smoked Reverse light tint
    Just got NSV Light bar, Have 2018 Tundra with DRLs.
    So the question is:
    1. I removed battery, but still do not know how to get to Headlight Motor plug?
    Watched video a hundred times and read through pdf !
    Any insight would be much appreciated!
    Disfigurative likes this.
  2. Oct 14, 2019 at 6:07 PM
    #62
    wire89
    wire89 New Member
    This was by far the most aggravating. Hopefully someone has a more pleasant answer but here is what I did, and hopefully you have small hands.
    - remove grille surround and remove the plastic trim between bumper and bottom of headlight.
    - keep battery out
    - to remove plug reach up from under headlight with a small screwdriver to push on the tab. with other hand from above, reach into frame well to pull on the plug. this is the easier part.
    - to reinstall plug, hold the end of the plug between your two fingers reaching up from under the headlight. with the other hand from above use a couple of fingers in the frame well to guide the plug to its fitting, and push in to click.
    it literally took me 15 or so minutes for this one task, good luck.
    Mr. Arroz[QUOTED] likes this.
  3. Oct 15, 2019 at 8:15 AM
    #63
    Mr. Arroz
    Joint Base MDL, NJ
    Thanks, I had to end up removing headlight as well
  4. Oct 16, 2019 at 12:05 PM
    #64
    Headlight Revolution
    Headlight Revolution New Member Vendor
    Atlanta, GA
  5. Oct 19, 2019 at 5:51 PM
    #65
    Lambeau
    Lambeau New Member
    2024 Black Tundra 1794 Limited Edition
    285/60/R20 BF Goodrich KO2’s
    Are the DRL’s on the Gen 2 light bar supposed to dim with the headlights? Or is there just one brightness level?
  6. Oct 20, 2019 at 12:04 PM
    #66
    wire89
    wire89 New Member
    If anyone is interested in just the NSV interior switch panel then I have posted mine on eBay. Don't think I'm allowed to link you to the listing as a new member, but should be easy to find.
    #66
    Headlight Revolution likes this.
  7. Oct 20, 2019 at 2:26 PM
    #67
    Atlanta, GA
    I believe they stay at one brightness level. :)
  8. Oct 20, 2019 at 4:29 PM
    #68
    Lambeau
    Lambeau New Member
    They’re too bright. I’ve been pulled over twice already. Any way to dim them? Or keep them from coming on at night?
  9. Oct 21, 2019 at 9:15 PM
    #69
    Lambeau
    Lambeau New Member
    The NSV is useless. It’s basically a hood ornament. If it doesn’t dim with the headlights, it can’t be on, especially at night. You can switch off the DRL’s in daytime but they come on automatically at night regardless of switch position. You will blind oncoming traffic and potentially be the cause of a wreck. I have pulled the fuse on mine and am not able to use it. Worst money I’ve ever spent. I’ve already gotten a ticket. Don’t need another one.
  10. Nov 13, 2019 at 4:57 AM
    #70
    Xray09
    Xray09 New Member
    Phenix City, Al
    2014 White Tundra Platinum Crewmax 4x4
    2.5/1 lift 275/65r20 BFG ko2 TRD rear sway bar Spray in bed liner Sprayed tow hooks red
    Just pull pin #9 in the harness near the light bar. This will disable the DRLs to only when you have the switch on in your truck, but still retain the rest of the functions. I too was pulled over twice for the DRLs even when mine where dimmed.
  11. Jan 1, 2020 at 6:46 PM
    #71
    RoninPro
    RoninPro Abecedarian BASTRD
    East Bay
    17 CM TRD Pro
    Hi, without the panel how are you using the bar? Wired to an SPOD or SwitchPro? Thanks.
    #71
  12. Jan 2, 2020 at 7:55 AM
    #72
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    I have followed the directions on my install and I finally got the thing to work...granted, only when the truck is in reverse :notsure: Attached is a page out of the directions for the 3rd gen harness...I have a 2014 and have installed the 2018 LED headlights with an iHacker harness...I have NOT installed the NSV headlight harness jumper cable...I HAVE installed the t-taps according to the directions. Any idea why they only activate when I'm in reverse?! Is it literally because I need the NSV jumper harness to work properly? With the attached image from the installation directions, I'm speaking on specifically step #28; I have tapped the correct brake controller harness wires but...I am challenged when it comes to electrical work so forgive my naivety.
  13. Jan 19, 2020 at 3:36 PM
    #73
    wire89
    wire89 New Member
    Ya, Switch-Pros
  14. Mar 11, 2020 at 12:48 AM
    #74
    KERNEL_DALE
    KERNEL_DALE New Member
    Norcal
    19’TRD-PRO
    I did Installed the nsv lightbar on my 19 trd pro.followed the manual as well as the video installation. My problem now is i don’t have the strobe function. I tried doing manual high beam but it didnt work. My factory drl is always on but doing the manual off function it wont work either. Need input on how to troubleshot this delima.. thanks in advanced.
  15. Mar 11, 2020 at 3:59 AM
    #75
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    I was under the impression that they did away with the strobe for legal reasons. Mine doesn’t strobe. Not sure where you got yours but HR had a disclaimer about this. What does manual high beams mean? Are you saying the bar doesn’t come on with your high beams? The button for the light bar needs to be engaged. Only then will the light bar work and only with your truck high beams on.
    Are you saying your light bar drl’s don’t disable with the button off?
  16. Mar 11, 2020 at 5:31 AM
    #76
    KERNEL_DALE
    Norcal
    19’TRD-PRO
    My factory control on the steering wheel for drl wont Work.beforehand i can use it to turn it off.
    tried doing the high beam on my truck but my trucks function wont work.
  17. Mar 11, 2020 at 6:06 AM
    #77
    Atlanta, GA
    Hey there!
    @Tundyfundy would be correct, NSV has done away with the Strobe feature on these light bars due to Safety reasons, I apologize!
    Can you email us with the issues you are having? Pictures/Videos help out as well! We'll be able to sort out any issues you may be having! PM me the Email Ticket Number once you send one in and I'll look into it!
  18. Mar 11, 2020 at 8:47 AM
    #78
    HulkSmurf14
    2014 Tundra Limited
    The strobe only works on V1 harnesses and directions. Pull pin #8 on V2 harness and insert into empty pin slot #3...from my understanding, this is the work-around to enabling the strobe function in-lieu of the toggled DRL...my only question is if doing this modification for the strobe to function, does this enable the DRL to ALWAYS be on or is that disabled now...personally, the DRL on the lightbar is neat, but useless to me...I'd rather have the strobe...all other functions are amazing and I'm glad I bought this lightbar!
    KERNEL_DALE likes this.
  19. Mar 11, 2020 at 9:25 AM
    #79
    KERNEL_DALE
    Norcal
    19’TRD-PRO
    so you did put pin#8 to pin#3 slot? did it work on you?
  20. Mar 11, 2020 at 3:10 PM
    #80
    HulkSmurf14
    2014 Tundra Limited
    I apologize for making it seem I did...this is something I have read much on and plan on doing, however, not completed yet...
  21. Mar 11, 2020 at 9:42 PM
    #81
    Tundyfundy
    Bay Area, CA
    My bar has a button to toggle the drl. Anytime switch is on DRL runs, Anytime switch is off DRL is off. I turn it off at night because they dont dim. I also didnt have to depin anything. everything was plug and play but no strobe.
  22. Mar 11, 2020 at 9:51 PM
    #82
    KERNEL_DALE
    Norcal
    19’TRD-PRO
    Does anyone experience your trucks high beam function won’t work after the nsv install.
  23. Mar 12, 2020 at 4:34 AM
    #83
    HulkSmurf14
    2014 Tundra Limited
    I too have the same feature and it works as suggested...I will eventually (when I have time) depin my #8 and insert in pin #3 and hope (from what others have completed) my toggled DRL transforms to a toggled strobe feature...one thing I do not know for certain is if when repinning the bar will cause my now toggled DRL to always be on and I will.lose the ability to turn the DRLs off when converting my DRL switch to a strobe? Essentially, turning mt V2 harness to the V1 harness...
    I have had no problems with high beams but just make sure, and it sounds like you have, the headlight stalk is on manual-mode for enabling the NSV to shine bright when you activate the high beams...if you don't have high beams at all, time to get under the dash and look at fuses...
  24. Mar 12, 2020 at 9:56 AM
    #84
    KERNEL_DALE
    Norcal
    19’TRD-PRO
    Heads up.. hope you won’t encounter this dilemma.
    while pinning the 12 pins, you must heard of the clicking sound each time you pin. Beware that the orange plate on the other side has deformity that impedes the contact point to the female receiver.
    In my case its has a defect.
    i discovered while doing a thorough double checking on its pins because my high beam doesn’t work that time.
    And finally got it.
    Joe, HulkSmurf14 and Tundyfundy like this.
  25. Apr 11, 2020 at 7:41 AM
    #85
    Jmduncan1
    Jmduncan1 New Member
    2017 Tundra Crewmax- gray
    So I have read through this thread god knows how many times now. I have a 2017 with DRL (amber) and installed the NSV bar. Everything seems to work correctly except the DRL switch does nothing. The DRL on the bar dim when the headlights come on etc. I did not install the blue jumper wire, is this why the DRL’s do not turn on and off? How do I properly hook up the blue jumper, the directions included weren’t the greatest at laying that out.
    Second question. I am about to update to OEM LED TRD Pro lights. What will I need to change in my configuration, if anything, when I do the upgrade for the NSV to work correctly.
    thanks for your replies in advance.
  26. Apr 11, 2020 at 1:35 PM
    #86
    Joe
    Joe New Member
    Joe
    Northeast Pennsylvania
    2019 Tundra TRD Pro ( Voodoo Blue)
    Driver side grab handle and The tailgate Tundra letters from Toyota Am looking at rear step and the Tonneau cover , also the safe
    I just put mine in yesterday, cut the blue wire on the connector for the blinker , if you have factory installed OEM LED headlights . So don’t cut the blue wire , when you install OEM LED headlights then cut the blue wire . Ok when I push my DRL they come on , I cut the blue wire I have OEM LED lights .
  27. Apr 11, 2020 at 2:15 PM
    #87
    Joe
    Joe New Member
    Joe
    They should dim when the headlights come on
  28. Apr 11, 2020 at 2:43 PM
    #88
    Tundyfundy
    Bay Area, CA
    I called HR and they told me otherwise. Are you positive?
    @Headlight Revolution ?
  29. Apr 11, 2020 at 6:44 PM
    #89
    Joe
    Joe New Member
    Joe
    Nope , you are right , i read that here . I’m sorry looked tonight and they don’t dim , but regardless of if I have lights on or not they do come on and go off with the DRL switch
  30. Apr 11, 2020 at 8:35 PM
    #90
    Tundyfundy
    Bay Area, CA
    Same.
