North West BS Thread
Discussion in 'North West U.S.' started by JAMMDOGG, Jan 6, 2014.
  1. Dec 4, 2022 at 6:38 AM
    #9301
    BrunoTheRescuePup
    BrunoTheRescuePup New Member
    SW Portland Metro
    2021 MGM Limited TRD
    Eibach Pro-Truck 2.0, Coachbuilder +1, Undercover Flex, Tyger Star Armor, TRD Rear Sway Bar, DD SS3 Max, MisoCustoms
    Sounds like a real word from Australia.
  2. Dec 4, 2022 at 9:02 AM
    #9302
    Blue Thunder
    Washington
    NWPirate likes this.
  3. Dec 4, 2022 at 10:39 AM
    #9303
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    My second year living here, some asshat with no traction anything (tires, chains, whatever) spun out in front of us on Hwy 26 coming the opposite direction close to dark. Fucked up the front end of my wife’s 4R, and completely destroyed the passenger side of his car. Thankfully I was only going about 35, and the main impact was the rear passenger door, or it would have been a serious injury accident for his passenger.
    It blocked traffic both ways (we were between Gvt Camp and Rhododendron below silent rock), and it took three hours to get a tow truck up there because of the traffic jam (before the days of cell reception and it was only one lane each way). I stood in the fucking cold with my buddy those three hours trying to direct traffic one car at a time each way while the other driver sat in his car whining about the damage to his car. It was a good thing my wife was with us, or I’d probably have ended up in jail for bashing his head in with his own hub cap.
    The signs were clearly up requiring traction devices.
    The conditions were snowing hard and lots of snow and ice on the road.
    DOT isn’t putting that stuff up as a suggestion.
    If you don’t have the gear for the conditions, stay home.
    </rant>
  4. Dec 4, 2022 at 10:43 AM
    #9304
    Blue Thunder
    Washington
    Preach brother.
    And slow the fuck down. I know I drive too fast in general but you won’t see me going gonzo on snowy highways.
  5. Dec 4, 2022 at 11:08 AM
    #9305
    BrunoTheRescuePup
    SW Portland Metro
    I think it also has to do with the shortage of snow plow driver in WA (and OR) this year. Greater chance of getting stuck than in previous years.
  6. Dec 6, 2022 at 5:12 AM
    #9306
    BrunoTheRescuePup
    SW Portland Metro
    Update time. So, Wheel Kraft stated that in their process this does happen and they cannot control the chipping, it is one of the downsides of turning the face of the wheel. Les Schwab for their credit is stepping up and offering me new wheels.
    I like the stock wheels as I don't want a flashy truck. I want something that looks stock-ish and doesn't draw attention. I also like being confident in drivability and handling.
    Also, I do like the Method 701. My concern is the offset, as if I am understanding this correctly going from a -60 to a +25, it is going to suck the tire into the suspension over 3" according to an online calculator. That gets me into likely modifying the mud flaps and fender wells and that is not the road I want to go right now. Am I understanding this correctly.
    Aside from TRD Pro wheels which I would jump at, any other recommendations or thoughts here? Thanks in advance.
    Edit: Also there are same TRD OR wheels that are all black (Sport package?). Those are a maybe. Thoughts?
  7. Dec 6, 2022 at 5:24 AM
    #9307
    NWPirate
    Zach
    WA
    I could be wrong but those numbers don't sound right to me for a stock TRD OR wheel.
    Can you get cash out of them and then go find your own?
    I saw OR takeoffs on Craigslist recently for $500.
    That might even put a little cash on your pockets for your trouble.
    20GR8 Super and RainMan_PNW like this.
  8. Dec 6, 2022 at 6:21 AM
    #9308
    20GR8 Super
    Corey
    PNW Outskirts
    2007 Super White CM Limited
    Agreed. Stock is +60 I believe and going to +25 would push it out away from the suspension and slightly stuck past the fenders. +60 to +25 would push it out 1.37” if I did my math right this early. You should be able to run +25 at stock tire size or slightly larger and not have to do any trimming.
  9. Dec 6, 2022 at 7:29 AM
    #9309
    BrunoTheRescuePup
    SW Portland Metro
    Yes, thank you both. That makes much more sense. I guess I have too much else on my mind this morning.
    Might just go the 701s. Last question, the 701 are bead grip (not lock). Does that have any positive or negative aspects for me? I suspect 1-2 over the life of the tires I might air down in the sand. Not enough though to need the bead grip. I just like the look of this wheel better than the 316 or 703 that are standard.
    NWPirate and 20GR8 Super[QUOTED] like this.
  10. Dec 6, 2022 at 7:39 AM
    #9310
    20GR8 Super
    Corey
    PNW Outskirts
    Sounds like it’s not a necessity but I don’t think it will hurt you either. I’d do the same thing and buy for the look. I do like the 701’s and would look good on your truck.
  11. Dec 6, 2022 at 8:13 AM
    #9311
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Time for 17s and 35s lol
    20GR8 Super likes this.
  12. Dec 6, 2022 at 8:26 AM
    #9312
    NWPirate
    Zach
    WA
    I've got a set of Method wheels on our Sequoia with the bead grip. I would put it between standard bead and the locking type. I don't see any negatives.
    I might be interested in your chipped stock wheels for a winter set, if you plan on selling them.
  13. Dec 6, 2022 at 8:42 AM
    #9313
    Tbrandt
    Tbrandt I read it on an internet forum, it must be true.
    Tristan
    Kansas City
    2021 SR5 DC TRD Off-Road
    Kenwood DMX907S + Maestro iDatalink RR2 Kenwood DRV-N520 dash cam Kicker Door Speakers TRD rear sway bar Firestone airbags + Daystar cradles Setrab oil cooler, OEM thermostat and hard lines Century High-C topper Bedrug Helmholtz resonator on stock exhaust Sound deadened + insulated cab Platinum 20s, hwy tires Viair 400P
    What are the nuances of the chain laws up here? Most of my life has been spent in the Midwest and Northeast where we have limited snowfall and salt the fuck out of the roads so don't have worry about it. Do you always carry chains and use them when required? Not req'd on 4WD cars? Throw 3 peak rated tires on and forget about it?
    I'm trying to my research so I'm not one of those idiots, just wondering what you guys do to stay safe/legal.
    Tripleconpanna and NWPirate like this.
  14. Dec 6, 2022 at 9:37 AM
    #9314
    20GR8 Super
    Corey
    PNW Outskirts
    I support this message! :D
    jewsNbrews and reywcms[QUOTED] like this.
  15. Dec 6, 2022 at 1:51 PM
    #9315
    Blue Thunder
    Washington
    Not sure about OR, but in WA when traveling mountain passes you generally don’t have to chain up when “chains are required” if you have four/all-wheel drive. However, legally you have to carry chains. Technically if things are bad enough the state could mandate chains on all vehicles but have never seen it.
    I keep a set of chains in the truck during the winter months. Never had to use them, but like to be ready.
  16. Dec 6, 2022 at 3:23 PM
    #9316
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    I always have them in the truck. However, I have yet to put them on during normal highway use... With that being said, I do slow down and if the roads get too icy, I stay off of them when I can, as I don't trust other drivers. I'd imagine if you're running a 3 peak or winter rated tire on a 4WD or AWD in and not driving like a jackass the Staters/DOT would probably just warn in worse case scenario. However, here is the statute in OR; you'll note is basically just defining authority and signage, etc. for conditions... Most of the 815 ORS deals w/operating an unsafe vehicle (equipment, windshields, etc..). So, if you were to violate the provisions for an established "conditions requirement", you could be cited for 'Operating an Unsafe MV'. Hope this helps....
    815.045 Rules for use of traction tires, retractable studded tires and chains; signs. (1) The Oregon Transportation Commission shall adopt rules necessary to carry out ORS 815.140 and 815.142. The rules adopted by the commission:
    (a) Shall establish the various types of conditions under which vehicle traction tires or chains must be used or carried.
    (b) Shall define types of vehicle traction tires or chains that may be used or carried under various road conditions. The commission rules under this paragraph shall comply with the following:
    (A) Traction tire shall be defined to include any tire that meets traction standards established by the Department of Transportation.
    (B) Retractable studded tires or tires with studs that are permitted under ORS 815.165 shall be allowed as traction tires under the rules.
    (C) The department may require that traction tires without studs bear identifying marks, defined by the department, that indicate that the tire was manufactured specifically for adverse weather conditions.
    (D) Chains shall be defined to include link chains, cable chains or any other device that attaches to the wheel, vehicle or outside of the tire and that augments the traction of a vehicle.
    (E) Retractable studded tires shall be defined to include tires with embedded studs that project beyond the tread surface only when a vehicle operator extends the studs to augment the traction of the vehicle.
    (c) Shall establish signs to be posted under conditions that require vehicle traction tires or chains to be used or carried.
    (d) May establish types or classes of vehicles that are exempt from requirements to use or carry vehicle traction tires or chains under certain conditions if the commission determines that the operation of the class or type of vehicle would be safe under those conditions.
    (2) A road authority shall:
    (a) Determine when conditions on a segment of highway require a person to use or carry vehicle traction tires or chains as defined by the commission;
    (b) Determine which segments of a highway shall be posted as described under this section to require a person to use or carry vehicle traction tires or chains; and
    (c) Provide for the placement and removal of signs requiring a person to use or carry vehicle traction tires or chains. [1983 c.338 §441; 1985 c.16 §231; 1993 c.741 §86; 1997 c.493 §1; 2007 c.406 §1; 2021 c.630 §97]
  17. Dec 6, 2022 at 3:51 PM
    #9317
    Tripleconpanna
    Hey guys...
    If you get a chance, please take a look at the following thread... @tucsontundra1794 raffle thread for a good cause - CLOSES 12/10/2022
    There's a pretty incredible raffle going on to raise funds to support another forum member going through an extremely difficult situation... If you have the means to support, it would be greatly appreciated; plus you a chance to win some incredible prizes. Details are explained in the above thread, and if you are interested in reading the original post by the member we are supporting, please look at the original post of this thread... Please love your children a little extra today.
    Happy Holidays everyone!!!!
  18. Dec 6, 2022 at 4:58 PM
    #9318
    Greddy
    Greddy It was called the 80s!
    Cam
    Bonney Lake, WA
    2013 SR5 CrewMax
    Fox 2.5 Factory Race Series Resi Coilovers, SPC UCAs, Fox 2.0 Performance Resi Shocks, Roadmaster RAS, Coachbuilder +2” Shackles, Method 18” NV305s & 34” Falken Wildpeak ATW3
    Ironically I'm actually trying to sell those exact TRD wheels with KO2s that les schwab fucked up.
    318604190_10106786204199453_185673812297_b70ee176f04f152fabdca1d98fe7b2788331e2c8.jpg
    reywcms and Blue Thunder like this.
  19. Dec 6, 2022 at 5:03 PM
    #9319
    BrunoTheRescuePup
    SW Portland Metro
    Did they help you on new wheels? Did they give those back to you?
  20. Dec 6, 2022 at 5:03 PM
    #9320
    Greddy
    Cam
    Bonney Lake, WA
    2013 SR5 CrewMax
    I'm pretty much finished with my suspension upgrades.
    Fox Factory Race Series 2.5 remote resi coilovers, SPC UCAs, Rear Fox Performance Series 2.0 remote resi and Roadmaster RAS.
    Scored these wheels on marketplace, 5 for $900 Method 305 NV, and brand new Falken Wildpeak 295/70/18s
    Ready for mall crawlin!
    318432701_10106785811551323_599702163645_b3907180398f88070365643994e512c12a2142ee.jpg
    316664354_10106765996061723_805105443386_9fb366cf143155b9a336120e3b3e1f06d7fe10d4.jpg
    318350845_10106785811925573_759788339312_53bfe5f27f8be13b1232f8719492862d31d82390.jpg
    318464846_10106785811376673_869075512295_a866c4d19b5ee039508cfedfc536fcfcceecbcb4.jpg
  21. Dec 6, 2022 at 5:04 PM
    #9321
    Greddy
    Cam
    Bonney Lake, WA
    2013 SR5 CrewMax
    No les schwab didnt fuck my wheels up, I put a lift on and got new wheels and tires. So I just posted these last night.
    Blue Thunder likes this.
  22. Dec 6, 2022 at 5:06 PM
    #9322
    Greddy
    Cam
    Bonney Lake, WA
    2013 SR5 CrewMax
    meant to say the same wheels that les schwab fucked up on your truck. i can see how that was confusing lol, my bad
  23. Dec 6, 2022 at 5:51 PM
    #9323
    BrunoTheRescuePup
    SW Portland Metro
    Got it. Nice ride.
    Greddy[QUOTED] likes this.
  24. Dec 6, 2022 at 5:53 PM
    #9324
    BrunoTheRescuePup
    SW Portland Metro
    Update: Method 701s going on this weekend. Appreciate LS stepping up and doing what is right here. Hope Saturday ends this saga.
    Blue Thunder, NWPirate and Greddy like this.
  25. Dec 6, 2022 at 6:01 PM
    #9325
    20GR8 Super
    Corey
    PNW Outskirts
    Glad they are doing what is right. Hard to find these days and the methods are going to look sweet but I am a little biased. :D
    Blue Thunder and Tripleconpanna like this.
  26. Dec 6, 2022 at 6:56 PM
    #9326
    Greddy
    Cam
    Bonney Lake, WA
    2013 SR5 CrewMax
    glad they made it right!
  27. Dec 6, 2022 at 9:44 PM
    #9327
    Ponderosa_Pine
    Ponderosa_Pine
    Northwest
    2021 Tundra DC, 2022 4R, 2007 FJ
    Magnuson Supercharged, Dobinson Lift, 315/70r17 on Rockwarriors, Heftyfab bumper, Dirty Deeds 3” race exhaust
    Portland metro area and Hood River areas seem to get a "chains required even for 4wd" curfew type events every once in a while. Whereas I have never seen this happen in WA, but WA DOT tends to just shut down mountain passes/specific highways instead (Hwy 2 being the classic one). Areas like Bend, OR seem to acquire so many jack knifed semis that it essentially closes down the highways anyways (similar to WA highways too), but seems like rural areas never have official road restrictions. Some of the best "sliding on snow" videos seem to come from I90 and similar roads around here due to the vast change from metro to mountain snow differences.
  28. Dec 9, 2022 at 7:18 AM
    #9328
    Blue Thunder
    Washington
    Funny all this talk about chains and then this past week there have been daily massive wrecks on I-90 that close the highway. Jinx!
    Normally my wife is crazy excited to visit Leavenworth for their holiday scene. Since they’ve gotten a ton of snow recently I asked her if she’d like to go this weekend. She said “prob not” because of all the road closures this past week.
  29. Dec 9, 2022 at 9:39 AM
    #9329
    RainMan_PNW
    Casey
    Clark County, WA
    Man - that's the best time to go!
    (not for the asshats on the road, but for seeing it with all the snow).
  30. Dec 9, 2022 at 11:23 AM
    #9330
    Tripleconpanna
    That's actually something we were looking at doing in the next couple of years (to do list since we moved up here); so, it's really worth seeing/doing at least once??
    jewsNbrews, 20GR8 Super and NWPirate like this.
