NorCal (Sacramento) Black Friday Meetup
Discussion in 'California' started by Cruzer, Oct 29, 2021.
Would you attend? Poll closes on 11/12
Poll closed Nov 12, 2021.
  1. Yes
    54.5%
  2. No
    45.5%
  1. Nov 23, 2021 at 2:00 PM
    #61
    wandering_boy
    wandering_boy Junior Tech Wizard
    California
    2005 AC SR5 TRD
    Don't let a kid out smart you.
    technically? It drives straight with the wheel at a slight angle to the right, but tire wear on the front have been good. My rough at home alignment check with some corner squares and a laser just showed that they were both tuned a bit to the left and no real noticeable difference in toe. Either way I just ordered camburg UCA's and It's been like this for 2 years sooo. The alignment can wait until Christmas when I do my my LCS bushings.
    831Tun[QUOTED] and Cruzer[OP] like this.
  2. Nov 23, 2021 at 2:04 PM
    #62
    Cruzer
    Cruzer [OP] Wheeling Full Size
    Cruz
    Sunnyvale, CA
    Corner square and laser method? Hmmm, I use the strings and PVC pipe method. Is your way easier?
    831Tun likes this.
  3. Nov 23, 2021 at 2:25 PM
    #63
    wandering_boy
    California
    2005 AC SR5 TRD
    Maybe. I use %*& corner squares a yard stick and a laser tape measure type thing. This method definitely isn't some crazy precise process since my measurement are based off the Rear wheels not having any kind of toe which in theory should be fine because they are solid axles but practically you probably get 0.05-0.1 degrees of difference between the two but good enough if I'm just checking. Anyway using a tard stick and a square or two I get the laser as close to perfectly parallel to the rear tire as I can at about an inch or 2 away from the tire. Then on the front tire I use the yard stick behind the tire to give me a flat and straight surface to put 2 squares up against that stick out past the tread and there little laser beam. From there I use another square since I got them in pack and level to keep the square 90 degrees vertical as I slolwy move it from the tire until it its the beam and I write down the measurement. Do that for the front square and back square rinse and repeat
    Sunnier likes this.
  4. Nov 23, 2021 at 5:11 PM
    #64
    Sunnier
    Sunny
    San Diego, CA
    Me too. First trip ever, I’ve not needed an alignment after a Tundra trip. After Smiley Rock I was really surprised.
    Cruzer[QUOTED][OP] likes this.
  5. Nov 23, 2021 at 5:13 PM
    #65
    Sunnier
    Sunny
    San Diego, CA
    Doesn’t sound easier.
    Cruzer[OP] likes this.
  6. Nov 23, 2021 at 5:38 PM
    #66
    Cruzer
    Cruz
    Sunnyvale, CA
    :rofl:took the words right out of mouth
    Sunnier[QUOTED] likes this.
  7. Nov 24, 2021 at 2:16 AM
    #67
    wandering_boy
    California
    2005 AC SR5 TRD
    Didn't say it was easier :rofl:
    Sunnier and Cruzer[OP] like this.
  8. Nov 24, 2021 at 2:10 PM
    #68
    wandering_boy
    California
    2005 AC SR5 TRD
    Also Friday is 2 days away so who is coming or at least will try to come besides Cruzer and I?
  9. Nov 24, 2021 at 2:33 PM
    #69
    Cruzer
    Cruz
    Sunnyvale, CA
    Warren is going. Matt and Billy might be going.
    GodlessPro likes this.
  10. Nov 24, 2021 at 4:02 PM
    #70
    GodlessPro
    GodlessPro Bougie BASTRD
    Matthew
    NorCal
    2018 Cement CM Limited
    I'll be there
    831Tun, TG705 and Cruzer[OP] like this.
  11. Nov 24, 2021 at 4:44 PM
    #71
    TG705
    TG705 Braaaap
    Tony
    San Jose, CA
    2011 super white Tundra double cab
    King 2.5 coilovers, King 3.0 rear bypasses, Camburg uniball UCAs, RCI skid plates, Camburg front bumper, warn zeon 10s platinum winch, monster hook reaper shackles, Rigid Industries lights, SDHQ sliders, SDHQ A-pillar brackets, SPOD, 17" Method standard wheels, 315/70/17 Cooper STT tires, Morimoto XB LED headlights, Boon dock steel rear bumper, Durobumps front bumpstops, Deaver U748 with MCM shackles
    I’ll be there too!
  12. Nov 24, 2021 at 4:54 PM
    #72
    GodlessPro
    Matthew
    NorCal
    Shit now I can't back out.
    831Tun, TG705[QUOTED] and Cruzer[OP] like this.
  13. Nov 24, 2021 at 5:17 PM
    #73
    Cruzer
    Cruz
    Sunnyvale, CA
    Aww yeah! Get to check out that truck!
    TG705[QUOTED] likes this.
  14. Nov 24, 2021 at 5:50 PM
    #74
    TG705
    TG705 Braaaap
    Tony
    San Jose, CA
    Haha no dude yours!!
  15. Nov 24, 2021 at 5:50 PM
    #75
    sr5shark
    sr5shark Shop smart. Shop S-Mart.
    Alan
    Walnut Creek, CA
    2016 SR5
    Fox & ADS | SCS SR8 | Nitto RG
    I was planning to go and then my wife scheduled our kids b-day celebration for Friday. :(
    831Tun likes this.
  16. Nov 24, 2021 at 9:21 PM
    #76
    Cruzer
    Cruz
    Sunnyvale, CA
    Aren’t bday parties later in the day?
    wandering_boy likes this.
  17. Nov 24, 2021 at 9:32 PM
    #77
    sr5shark
    Alan
    Walnut Creek, CA
    2016 SR5
    Unfortunately my wife does not see her son as much as she would like so we are working around when he is in town.
  18. Nov 25, 2021 at 1:03 PM
    #78
    wandering_boy
    California
    2005 AC SR5 TRD
    Ok damn I might have to show up then. My friends had a ride planned in the morning So I need to flip a coin
  19. Nov 25, 2021 at 1:08 PM
    #79
    Sunnier
    Sunny
    San Diego, CA
    Um, ahem, did you mean, your ‘other friends’?!
  20. Nov 26, 2021 at 12:13 AM
    #80
    wandering_boy
    California
    2005 AC SR5 TRD
    Sorry horrible miss spelling. But at least the coin decided in your favor. And I remembered that my bike is all fucked. So I’ll be there bright and early at 10 with plenty of coffee
    Sunnier[QUOTED] and Cruzer[OP] like this.
  21. Nov 26, 2021 at 8:04 AM
    #81
    NakdGpa
    NakdGpa New Member
    Dallas, TX
    2021 DC SR5 4x4 Cement
    4” lift, Method wheels, 295/70R18 Mickey Thompson’s, TRD F&R Sway Bars, Tinted...
    Apologies…life is getting in the way today and I won’t make it. Hopefully make the next meetup. Enjoy your day!
  22. Nov 26, 2021 at 9:29 AM
    #82
    Cruzer
    Cruz
    Sunnyvale, CA
  23. Nov 29, 2021 at 1:02 PM
    #83
    Cruzer
    Cruz
    Sunnyvale, CA
  24. Nov 29, 2021 at 1:15 PM
    #84
    GodlessPro
    Matthew
    NorCal
    I like how mean Jason's truck sounds in the beginning because the buggy was running around.
  25. Nov 29, 2021 at 7:06 PM
    #85
    TG705
    TG705 Braaaap
    Tony
    San Jose, CA
    Haha that’s hilarious! Great vid Cruz!
  26. Nov 30, 2021 at 9:46 PM
    #86
    wandering_boy
    California
    2005 AC SR5 TRD
    I still get myself confused sometimes sine I normally don’t run it with the muffler on
  27. Nov 30, 2021 at 9:56 PM
    #87
    wandering_boy
    California
    2005 AC SR5 TRD
    I still can’t believe @Cruzer swapped his CV axle in 30 min?!!!! And then the man just keeps thrashing it
    TG705, joonbug, GodlessPro and 2 others like this.
  28. Dec 1, 2021 at 9:37 AM
    #88
    GodlessPro
    Matthew
    NorCal
    It really was impressive.
  29. Dec 1, 2021 at 10:13 AM
    #89
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Who was the funny looking bearded guy spotting you up the pyramid? He should be taken out back and shot in the head. :rofl:
  30. Dec 1, 2021 at 10:16 AM
    #90
    TG705
    TG705 Braaaap
    Tony
    San Jose, CA
    hahaha not his fault! It was mine for not setting myself up right before I went up
