NorCal Offroading
Discussion in 'California' started by joonbug, Aug 28, 2017.
  1. Oct 24, 2018 at 8:35 AM
    #631
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    I haven't heard anything bad about 'em. For me, I don't like having that ball joint adjustment. Sure, helps the alignment tech but it's one more unnecessary link in the chain that can fail.
  2. Mar 5, 2019 at 9:32 AM
    #632
    GodlessPro
    GodlessPro Bougie BASTRD
    Matthew
    NorCal
    2018 Cement CM Limited
    Cemented, Sunnier, sr5shark and 3 others like this.
  3. Mar 5, 2019 at 11:16 AM
    #633
    Mwray8909
    Mwray8909 New Member
    Chino Valley
    18 TRD offroad cement CM
    Why no?
    joonbug[QUOTED][OP] likes this.
  4. Mar 5, 2019 at 11:42 AM
    #634
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    'Cause it's ball joint and can/will limit travel. See post 638. If that thing comes loose while off road, you're likely (worst case) to lose a wheel and everything attached to it. Now, if you want a street queen/ off road at 15 mph, sure go for it. Just my .02
  5. Mar 5, 2019 at 11:48 AM
    #635
    Mwray8909
    Chino Valley
    Also possible with a uniball set up
    dcsleeper408 likes this.
  6. Mar 5, 2019 at 11:49 AM
    #636
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Limit travel?
  7. Mar 5, 2019 at 11:51 AM
    #637
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Or provides more nuts/ bolts and a sliding mechanism? Go for it, your truck.
  8. Mar 5, 2019 at 12:10 PM
    #638
    Mwray8909
    Chino Valley
    Both uniball and SPC increase travel. A uniball is not a true 1 piece ball. They are still bolted together....
    Absolutely true my truck. So then does that mean the Heim joint is bad because that has even more parts to go bad then a single uniball or the SPC?
    joonbug[OP] and Sunnier like this.
  9. Mar 5, 2019 at 12:12 PM
    #639
    dcsleeper408
    dcsleeper408 BASTRDS
    mark
    San Jose CA
    2015 TRD PRO
  10. Mar 5, 2019 at 2:01 PM
    #640
    joonbug
    joonbug [OP] °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Uniballs are more reliable and just stronger, may give more travel too. But they will require more maintenance and will need to be changed out sooner. If you wheel alot, I'd definitely go uniball. Ball joint if you're just an occasional wheeler. If I had a choice, I'd be going with Delta Joints.
  11. Mar 5, 2019 at 2:19 PM
    #641
    Mwray8909
    Chino Valley
    I can agree they are stronger and require more maintenance. I will also say they are more reliable then OEM, IF they are maintained and cleaned properly. I can say I've seen more Uniball UCAs fail then balljoint style and that's mostly due to lack of care and attention to the equipment as well as there are generally more uniball on the trails.
    They are also harder to replace (the joint not the entire UCA) then any ball joint style. So the ability to do a trail fix and carry an extra one to just toss in is big to me.
    I have also seen balljoint failure. That's commonly from driver error (commonly same as uniball) picking a bad line and hitting it hard or to much skinny petal when thinking and finesse would serve better.
    Along with seeing some failures, I've seen dozens more take a beating on both types. So the breakage is the exception not the rule for either.
    I also agree if my truck was dedicated to daily or weekly abuse, or it was a race truck I'd go uniball. But considering I live right on the coast, I wheel 1-2 times a month (1-4 days a trip) and I travel long distance. The balljoint is better in my opinion or in my application I guess would be a better way to state that.
  12. Mar 5, 2019 at 2:33 PM
    #642
    tahoetrails
    tahoetrails New Member
    Just to throw my 2 cents in....
    Ive used all of the above. I like the uniballs over the ball joints. But damn they get squeaky and I had to replace at 30k both times due to wear. Living in snow country decreases life expectancy really quick.
    I now run the icon delta joint, best of both worlds. fully sealed joint with a zerk fitting on the top. I haven't had any squeaking at all. Seems like it drives more stable than my previous uniball setup. But could just be that I remember the end of the life of the uniball.
    Mwray8909 and joonbug[OP] like this.
  13. Mar 5, 2019 at 2:36 PM
    #643
    joonbug
    Joon
    NorCal - Dublin
    2020 LT DC
    I've only had my delta joints off my truck for 2 days and I already miss them. :(
    GodlessPro likes this.
  14. Mar 5, 2019 at 3:24 PM
    #644
    tahoetrails
    I probably skimmed too much of this thread. What happened to your uca’s?
    Also, once the truck gets out of surgery, when’s the next NorCal trip??
    Sunnier and joonbug[OP] like this.
  15. Mar 5, 2019 at 3:29 PM
    #645
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Next trip is in 2 weeks 15-17 to Mojave.
  16. Mar 5, 2019 at 3:32 PM
    #646
    tahoetrails
    Ya I didn’t miss that post. Truck won’t be ready till after the 20th.
    joonbug[OP] and GodlessPro like this.
  17. Mar 5, 2019 at 3:39 PM
    #647
    GodlessPro
    Matthew
    NorCal
    T2S is in April.
    We can't really do any trails in NorCal until the snow melts.
  18. Mar 5, 2019 at 3:50 PM
    #648
    joonbug
    Joon
    NorCal - Dublin
    2020 LT DC
    Wasn't getting enough camber and caster so I swapped out the Icon Tubulars w/Delta Joints for some Camburg UCA's. When it's time to replace my balls, I'm going to get Delta Joints if they have a retrofit kit for the Camburgs.
    GodlessPro and sr5shark like this.
  19. Mar 5, 2019 at 3:54 PM
    #649
    tahoetrails
    Ahh gotcha. Ya I had the same issue with my old uca’s switched to billet icons and they work great. No rubbing.
    joonbug[OP] likes this.
  20. Mar 5, 2019 at 3:55 PM
    #650
    joonbug
    Joon
    NorCal - Dublin
    2020 LT DC
    Yup, I think those are the best arms out there. I should've just got those from the start.
  21. Mar 5, 2019 at 3:58 PM
    #651
    tahoetrails
    It’s tough to see the damn price tag. But after speaking with Matt at mcm, we decided it was the safest route to make sure I could get the alignment the way I wanted. Only downside I have now is that I can’t get a set of tires to last past 35-40k. Stupid mountain driving.
  22. Mar 5, 2019 at 4:02 PM
    #652
    ForceV4
    ForceV4 Pull my finger
    Sacramento
    2018 DC TRD 4x4
    Haha! I am FAR too easily amused. By the way, what is t2s?
  23. Mar 5, 2019 at 4:02 PM
    #653
    joonbug
    Joon
    NorCal - Dublin
    2020 LT DC
    My STT Pros have 15k on them. 2 tires just blew. And the other 2 are about 40% gone.
  24. Mar 5, 2019 at 4:03 PM
    #654
    joonbug
    Joon
    NorCal - Dublin
    2020 LT DC
    LOL, that was intentional. :p T2S is Tundras to Sedona. Huge tundra gathering every year in Arizona. We're going this year. Anyone is welcome to caravan with us.
  25. Mar 5, 2019 at 4:05 PM
    #655
    Sunnier
    Sunny
    San Diego, CA
    :( I had high hopes for longevity. And not ripping on trail.
    831Tun and joonbug[QUOTED][OP] like this.
  26. Mar 5, 2019 at 4:07 PM
    #656
    tahoetrails
    I run the same tire in the summer. Tire performs great while wheelin, but Ive got some real deal cupping issues through the entire tread. Ive got about 15k on em and will be replacing a couple months into spring. Ive tried everything, but its the roads, so I've come to live with it.
    You blew two of em?! I'm impressed, I have put these things through a lot and I haven't had a blowout yet:fingerscrossed:
  27. Mar 5, 2019 at 4:08 PM
    #657
    tahoetrails
    I wouldnt say these things wear fast, for me at least. They are just mud tires and driving 45-55mph on curvy roads 35k a year would punish all tires out there. My buddy runs toyo mts and his wore just as fast.
    831Tun and joonbug[OP] like this.
  28. Mar 5, 2019 at 4:09 PM
    #658
    Mwray8909
    Chino Valley
    I will be going with 295/75r17 wildpeak AT3Ws soon. I've had them before and loved how they performed with everything that was thrown at them.
  29. Mar 5, 2019 at 4:10 PM
    #659
    joonbug
    Joon
    NorCal - Dublin
    2020 LT DC
    Well, only blew one and the next day I found a huge blister on the other one on the sidewall. Personally, I think driving on the highway aired down for like 30-40 minutes might've contributed. Then hitting a rock at high speed finished it off. Also bent my cam tabs and knocked my alignment way off.
  30. Mar 5, 2019 at 4:12 PM
    #660
    tahoetrails
    hahah damn that musta sounded great inside the cab on that hit. Ya before I got my compressor put on, I noticed some issues driving home aired down with my st maxx a couple years ago.
