No turn signals or hazards
Discussion in '1st Gen Tundras (2000-2006)' started by Mikeyk13, Apr 6, 2024.
  1. Apr 6, 2024 at 5:04 PM
    Mikeyk13
    Mikeyk13 [OP] New Member
    McCall,ID
    2005 DC
    Hi y’all, I fell like have exhausted what I know. My turn signals and hazards stopped working all of a sudden a few weeks ago. I have replaced the flasher and combo switch. All fusses are good. I also bought a cheaper Napa flasher that clicks when turn signal is on but no indicator lights on dash or turn signals themselves. New OEM flasher does nothing, no clicks. Weird? I feel like there must be a short but don’t know where to start? Any ideas would be much appreciated. Thanks.
  2. Apr 6, 2024 at 5:12 PM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    A multimeter that can read voltage would be a good place to start. Also, check the wiring diagram for your vehicle from the FSM. I’m sure others here can point out where to follow the wiring once you know what you’re looking to check.
  3. Apr 6, 2024 at 6:56 PM
    shifty` In South Dakota Trouble ain't hard to find
    Any chance you have a crack in your windshield, or have had the windshield replaced?
    Common leak is down the A-pillar and into the fusebox. If the connection is corroded, you're not gonna get shit at the lights. One of many things found in the megathread, "[water leaks] into the fusebox inside the cab/dash (pics & pics & pics, it happens a LOT)"
  4. Apr 8, 2024 at 7:58 PM
    Mikeyk13
    McCall,ID
    2005 DC
    Thanks, yes my carpet is wet under the floor mats. I am going to pull the fuse box tomorrow and go from there.
  5. Apr 8, 2024 at 8:59 PM
    Check the ‘Definitive leak’ sticky thread. It will help.
