Nitto Trail Grapplers MT's
Discussion in 'Wheels & Tires' started by T-Rex266, Mar 30, 2015.
  1. Mar 30, 2015 at 10:40 PM
    T-Rex266 [OP] Owner, CTO and executive chairman of X Staff Member
    Anyone have personal experience with these? If so, how did they hold up? Ware? Snow? Mud? Rain? Noise? Etc.
  2. Mar 31, 2015 at 8:04 AM
    1G3-TRD
    1G3-TRD New Member
    Aaron
    2014 double cab TRD off road
    I havnt had these personally, but I did have 2 sets of Nitto terra grappler and I was very happy with them, I am going to be getting them trail grapplers mt's very soon
    T-Rex266[QUOTED][OP] likes this.
  3. Mar 31, 2015 at 8:38 AM
    Relentless
    Relentless Eric @Relentless Fab Vendor
    Eric
    East of the Sierras(Reno), Nevada
    '14 Crewmax TRD 4x4> '15 Duramax SLT
    Just a few, more to come
    I've had them on my truck for about 2k now so no real long term wear updates (appear to be wearing kind of quick in the front on my truck so far) but from the time I've had them ive been happy. Seem quite chip-resistant in the rocks, handles all road conditions well so far, and moderately noisy.
    They're heavy. Seem like they're very durable and will resist puncture well.
  4. Mar 31, 2015 at 8:55 AM
    Virgils12
    Virgils12 New Member
    Camburg Fox factory 2.5" lift Xd monsters with 295/70/18 nitto terra graplerrs Corsa cat back Weather tech liners Wet okole covers
    Really? I hate my terra grapplers!!
    cadis10 likes this.
  5. Mar 31, 2015 at 10:12 AM
    TNTundra08
    TNTundra08 New Member
    Blake
    2008 DC 4x4
    3/1 lift. 20x9 Method standards, machine face. 305/55/20 nitto trail grapplers
    I had these on my Silverado, probably only put 3,000 miles on them. I also have them on my tundra currently, probably only have 400 miles but I love these tires. Great in mud, snow, rain, ect. They are a little noisey but I just crank the radio and it doesn't bother me. I have heard, no personal experience, that the toyo open country MT is less noisey. They are a little more expensive but supposedly a good tire as well. I'm happy with my trail grapplers if you don't mind a little whine.
    T-Rex266[OP] likes this.
  6. Mar 31, 2015 at 10:17 AM
    Any throttle hesitance when u jump on it? They are about 10lbs lighter per tire than the 35" Toyo OC
  7. Mar 31, 2015 at 10:39 AM
    TNTundra08
    Blake
    2008 DC 4x4
    I notice some coming from my precious tire set up but these are about 10-15 pounds per wheel/tire than my last so I think it's the added weight. Not any caused by the tire itsself
  8. Mar 31, 2015 at 10:42 AM
    TNTundra08
    Blake
    2008 DC 4x4
    :thumbsup: Dig through the mud just fine though image.jpg
  9. Mar 31, 2015 at 10:51 AM
    Ur tires are a little taller than mine...I believe the ones I was looking at are 65lbs each..I would have to check the specs on yours
    How much delay do u get when u gun it?
    Edit: looks like yours are 51lbs
  10. Mar 31, 2015 at 11:01 AM
    I believe my Toyos (315/70/18) were 82lbs each :eek:
  11. Mar 31, 2015 at 11:10 AM
    Relentless
    Eric
    Theres a slight hesitation due to the larger diameter and bit of extra weight, but I do not notice any due to lack of traction of the tire itself
  12. Mar 31, 2015 at 11:44 AM
    TNTundra08
    Blake
    2008 DC 4x4
    These are 305/55/20. They are 33.39/12.6/20. I thought they were 77lbs a piece. I'll need to double check Bc I have researched sooooo many wheel/tire set ups.
    And I wouldn't say a "delay" I just have to use a smidge more throttle to take off from stand still Bc of the extra weight. I didn't notice any delay in my Silverado. Idk what tire size you have now but going to a 35 you'll notice it's a little more sluggish off the line Bc the tires are so much larger
    Edit: checked, "CarID.com" says mine are 77lbs a piece
  13. Mar 31, 2015 at 11:46 AM
    Mike Tread lightly.
    south carolina
    You have to lock up your torque converter more with larger wheels and tires.... If you can tell it re/gear the pumpkins if you plan on staying with that size.. Larger wheels can add alot of HEAT to a transmission and with them sealed no way to check to see if the tranny is having problems under the LOAD until its to late..
  14. Mar 31, 2015 at 12:12 PM
    Interesting. I know a lot of Tacos (4.0) that run anywhere from 33-35" tires....some of these Tundras are running 40" tires..I don't see the 34" being much of an issue to run...I know 35's are common.
    I'll regear this bad boy sooner or later.
  15. Mar 31, 2015 at 1:42 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    I had the Trail Grapplers on my Tacoma for a while. Got them from Matt on TW. Had them on for about a year and then stepped up to 35's.
    Here was my review on the A/T M/T Tire Review thread"
    "Nitto Trail Grappler 33" Taco: Nice aggressive tires. Quieter than the MTZ. Heavier and noticeable in the manual taco. Even wear and would have lasted a long time. Replaced to jump up to 35s. Would recommend."
  16. Mar 31, 2015 at 1:44 PM
    csuviper
    Broomfield, CO
  17. Mar 31, 2015 at 3:08 PM
    Mike Tread lightly.
    south carolina
    Alot goes to how you drive it and how much you can get away with it ... ;)
    Edit remember that your transmission must SLIP in order to get larger tires rolling... Thtas why clutch packs go out on these trucks with larger tires if you dont regear.. or torque converter goes out( locks up)
  18. Mar 31, 2015 at 3:29 PM
    Bumper (not the plastic fender) is rubbing the shit out of the tires...going to have to go to a tall 33" Duratrac..so I don't have to cut into the bumper ...which would cut the tires on an angled bump
    So, safer on the truck and a better overall tire.
  19. Mar 31, 2015 at 3:30 PM
    Truth!
    There was a guy on the TC FB page that has his trans replaced at 50k with 35's due to him driving it hard 24/7 (his words)
  20. Mar 31, 2015 at 4:19 PM
    TruckyTruck
    TruckyTruck Dumbest Username
    Gary
    What about the toyo r/t? I'll be going with those when I get tires.
  21. Mar 31, 2015 at 5:56 PM
    cadis10
    cadis10 New Member
    2011 CREWMAX TRD
    TRD exhaust, 3" lift 33" and 22's
    I like my 33" toyo ATs ended up getting in a real mud hole but truck came out. Mud was up to bottom of doors! b0b3b4d649bfc40008f22134c0b5182d_663f19248e6665be21ba781b3b72861b0326ea3b.jpg
  22. Mar 31, 2015 at 6:14 PM
    chphilo
    chphilo Tundra addict
    Western PA
    I have Trail Grappler 295/70/18, which 34.57 inches in diameter according to Nitto. I've had it since January and it has done awesome so far. Deep snow is not an obstacle for it and for mt, it rides very well on road. Little hum is there, but it's not bad at all.
  23. Apr 1, 2015 at 7:42 AM
    Which Nittos? The AT or MT?
  24. Apr 1, 2015 at 7:51 AM
    Relentless
    Eric
    Bruh.
    He said Trail Grapp's.... MT's ;)
  25. Apr 1, 2015 at 7:58 AM
    Ya, but they make them in AT...its the new "G2' ..
    check it out here
  26. Apr 1, 2015 at 8:08 AM
    Relentless
    Eric
    *Terragrappler G2 AT :cool:
    linky doesnt work BTW
  27. Apr 1, 2015 at 6:04 PM
    chphilo
    Western PA
    Sorry about he confusion. It's MT. Trail Grappler (sounds so similar to Terra) comes only in MT.
    Relentless likes this.
