Nitto Ridge Grappler vs. Toyo At2 extreme
Discussion in 'Wheels & Tires' started by Muleycrazy13, Dec 29, 2017.
  1. Mar 14, 2018 at 5:57 PM
    #91
    Bshell
    Bshell New Member
    Brandon
    2015 tundra XP
    RG 33x12.50 on the XP wheels. Rides good, balanced fine and good in the snow/off-road. Can't speak for the toyos but I love the look of this tire. IMG_5200.jpg
    Watt maker likes this.
  2. Mar 15, 2018 at 9:55 AM
    #92
    Drew44
    Drew44 New Member
    Drew
    I just changed my stockies out for the regular Toyo a/t, (not a/t/2 extreme). The 275/70/r18 tires are about 1" taller in diam. there's a little rubbing in reverse turning on the little front tire wind flap- which will be removed. They ride great, not as quiet as the stock Michelin 275/65/r18's, but they will work.
  3. Mar 15, 2018 at 10:14 AM
    #93
    cu52
    cu52 New Member
    Denver Metro
    13 Platinum CM
    Supercharged, TRD Dual Exhaust, Bilstein 6112's/5160's, TSS wheels, Toyo AT Xtreme 285/60R20, LED bed lights, Hellwig sway, PopNLock tailgate lock
    Sorry Just saw this post below is full side shot.
    TheBeast[QUOTED] and Drew44 like this.
  4. Mar 17, 2018 at 7:51 PM
    #94
    2010bigdog
    2010bigdog New Member
    Chuck
    Chicago
    2018 MGM SR5 TRD
    looks really good . how much was your lift ?
  5. Mar 17, 2018 at 8:08 PM
    #95
    TheBeast The Beach
    295/70/18 Toyo AT2 xtreme.
    Wrongside, Watt maker and 1UPPER like this.
  6. Mar 17, 2018 at 9:21 PM
    #96
    Justin9
    Justin9 New Member
    Justin
    Utah
    2017 Cement TRD Pro
    I paid $1600
  7. Jun 6, 2019 at 6:07 AM
    #97
    Jacktruong
    Jacktruong New Member
    Jack
    White tundra trd pro
    Does Nitto ridge grappler has size 295/65r18? Im looking for it everywhere but couldnt find that size
  8. Jun 7, 2019 at 8:43 AM
    #98
    showtime240
    showtime240 New Member
    You can go directly to the nitto website.
    They have all of their sizes listed with specifications like actual diameter, weight, warranty, tire depth etc etc
  9. Jul 19, 2019 at 4:59 PM
    #99
    ncomeau35
    ncomeau35 New Member
    North of Boston
    2019 White Toyota Tundra TRD PRO
    Nitro Ridge Grappler 285/75/18
    I just put on a set of Nitto Ridge Grapplers 285/75/18! They look the balls, but there is a slight rub on the front mud flap that will be removed tomorrow!!
  10. Jul 19, 2019 at 6:56 PM
    #100
    careyrob
    careyrob In the field
    Carey
    Massachusetts
    2008 Crewmax TRD 4x4 Silver
    LRO 3/1 leveling lift 35x12.50's on 20x9's Hellwig rear sway bar B&M 70264 SuperCooler Transmission Cooler Firestone airbags Daystar cradles Air Lift WirelessONE Compressor System
    I'm not trying to be a punk here so please forgive me if it comes off that way. Just spreading some knowledge for everyone.
    It's not quite the same as just adding the weight difference to the truck. You also have to accelerate the rotational speed of that weight.
    It's not exact, but if two tires are the same diameter dividing the weight of the heavier tire by the weight of the lighter one will give you a rough percentage of how much additional torque it will take to accelerate the heavier tire at the same rate as the lighter one.
    In the case of the 295's here: (69 lbs.)/(64 lbs.) = 1.078 or 7.8% more torque required.
    275's: (64 lbs.)/(58 lbs.) = 1.10 or 10% more torque required.
    If you increase the tire diameter with the same weight it's different. You divide the square of the diameters. 295 vs. 275: (34.3 in.)^2/(33.2 in.)^2 = 1.067 or 6.7% more torque required.
    If you have a larger and heavier tire you do both and multiply them together.
    Comparing Toyo 275 vs. Toyo 295:
    (64 lbs.)/(58 lbs.) = 1.103 or 10.3%
    AND
    (1.103)*(1.067)= 1.178 or 17.8% more torque required for the same acceleration.
    That's pretty significant.
  11. Jul 19, 2019 at 8:58 PM
    #101
    xtyfighterx
    xtyfighterx New Member
    Ty
    North Idaho
    2015 Black Crewmax Mid Travel
    Ridge grapplers are as bad as trial grapplers in the snow. From what I’ve heard. I know my trail grapplers are pretty worthless in the snow and they are sipped
