Nitro 4.88 gears
Discussion in 'Performance and Tuning' started by Kilos, Jan 14, 2019.
  1. Mar 6, 2019 at 6:15 PM
    #61
    Grumpy Uncle
    Pat
    CO
    2016 Black CM Tundra TRD Off Road
    Yep, same here!
    Rica25 likes this.
  2. Mar 6, 2019 at 6:21 PM
    #62
    Fspmdt
    Fspmdt New Member
    2016 tundra 1794
    Bam 8 exhaust 285/70 18 ridges 4:88 gears, auburn lsd 6112s SPC UCA
    Yep accelerates, holds gears better and doesn’t hunt for gears like it did before. MPG up too. Worth the money, and makes your transmission happy too
    Rica25 likes this.
  3. Mar 6, 2019 at 6:21 PM
    #63
    UTTundra
    UTTundra New Member
    Lou
    Utah
    My mpg stayed the same or went down a bit with 4.88 gears and 34.5” tires. Acceleration is better, though.
    Phantom Lord and Rica25 like this.
  4. Mar 6, 2019 at 6:27 PM
    #64
    UpSteer32
    UpSteer32 New Member
    Actually the good gear calculators, like the one I referenced, take into account your transmission gearing too. That's why it can give you an approximate, but still somewhat accurate, indication of RPM's at various speeds.
    You mpg's went up compared to what? 34's and stock 4.30's? Have you re-calibrated your speedometer and odometer?
  5. Mar 6, 2019 at 6:29 PM
    #65
    Fspmdt
    Fspmdt New Member
    2016 tundra 1794
    Yep went up from when it was stock 430s with 34s. Yeah I recalculated.
    Rica25 likes this.
  6. Mar 7, 2019 at 3:01 PM
    #66
    iamsmokey
    iamsmokey Smokey the Tundra
    Oahu, HI
    2018 Cement SR5 Off-Road 4x4 Crewmax
    for the 2018's the diff oil that Toyota recommends is 75W-90. I'm literally on the Nitro website about to pull the trigger and am wondering if you guys are running the Nitro 80w-140 gear oil they recommend or if you are using stock gear oil?
  7. Mar 7, 2019 at 3:03 PM
    #67
    Fspmdt
    Fspmdt New Member
    2016 tundra 1794
    I am running 80/90 non synthetic because I have Auburn LSD and that’s what they recommend. I’m sure that’s good gear oil but you might want to use conventional initially because you have to change the fluid at 500 miles.
  8. Mar 7, 2019 at 3:05 PM
    #68
    iamsmokey
    Oahu, HI
    I'm only doing 4.88 gears, will change the fluid at 500 miles but after that should I be running the 80W-140 gear oil from Nitro?
  9. Mar 7, 2019 at 3:07 PM
    #69
    Fspmdt
    Fspmdt New Member
    2016 tundra 1794
    Yeah I would thicker weight will be quieter.
  10. Mar 7, 2019 at 3:07 PM
    #70
    iamsmokey
    Oahu, HI
    Okay thank you! Just needed the okay before I pull the trigger on gear oil I don't need haha
  11. Mar 7, 2019 at 3:46 PM
    #71
    iamsmokey
    Oahu, HI
    UPDATE: just took a shot of jack and pressed "complete order" ... somebody give me tissue to wipe my tears
  12. Mar 7, 2019 at 7:24 PM
    #72
    Fspmdt
    Fspmdt New Member
    2016 tundra 1794
    Nice you won’t regret it. Let’s us know how you like them. Follow the break in procedure too.
    iamsmokey[QUOTED] and Rica25 like this.
  13. Mar 7, 2019 at 10:53 PM
    #73
    iamsmokey
    Oahu, HI
    Cool. 500 miles and fluid change :thumbsup:
    And of course taking it easy for a bit (like I even hardcore stomp my truck)
    Rica25 likes this.
  14. Mar 8, 2019 at 5:09 AM
    #74
    Fspmdt
    Fspmdt New Member
    2016 tundra 1794
    Also when u pick it up only drive 15 miles or so and let it completely cool down before driving again. That the important part. No towing too in the first 500
    Rica25 likes this.
  15. Mar 14, 2019 at 7:49 PM
    #75
    iamsmokey
    Oahu, HI
    Hoping for the install next week Wednesday!
    Ostrich, Rica25 and GAknight like this.
  16. Mar 14, 2019 at 8:13 PM
    #76
    Rica25
    Ricardo
    Tulare
    I thought Nitro was USA made but they are not
  17. Mar 14, 2019 at 8:19 PM
    #77
    neirbot
    neirbot New Member
    South Korea as I was told by Nitro, in the same factory as the OEM gears.
  18. Mar 23, 2019 at 10:12 AM
    #78
    neirbot
    neirbot New Member
    Just had my 4.88's installed. While I can't get on it yet because I'm still in the break-in period, the truck feels very different -- almost like it's lighter on it's feet, if that makes sense.
    I also had the ECGS bushing installed to replace the needle bearing. This really tightened up the front end and got rid of the play I had in the CV axle.
  19. Mar 23, 2019 at 11:35 AM
    #79
    iamsmokey
    Oahu, HI
    Wrote this in my build thread as well but:
    Yo, just put on the first 150 mi with the 4.88 gears. I can’t tell you truly how it feels yet but as far as I feel, it shifts better and feels lighter on its feet. By no means does it go from 0-60 mi/hr instantly but it doesn’t feel like it’s trying its hardest to get going. After driving it, is it worth it still? Yes. Will post back when I am able to hit the gas a little harder and swap out the gear oil after the break in period.
  20. Mar 23, 2019 at 12:04 PM
    #80
    timsp8
    NY
    Do these kill highway gas mileage? I want to do it as my truck feels sluggish with bigger tires, even with a pedal commander. I don’t want to drop to 10 mpg or less going 70 mph though.
    At work I make several short trips during the day of 2 miles or less. I think it would help mileage there. I average 11-12 mpg now whether I get on it or try to drive easy.
    I keep looking at these, but went to a local shop and was told it was a waste of money and everything I read on forums was bs. I won’t go back there now.
  21. Apr 8, 2019 at 5:41 PM
    #81
    Kilos
    Kilos [OP] YotaPro
    Brett
    AZ
    2017 TRD Pro Barcelona Red
    Icon Stage 6 suspension Method NVs matte black w/Toyo Tires 35x12.5s SDHQ Sliders Cab mount chop Precision LED interior lights (6000k) GTR reverse LEDs 20% acrylic tint (heat resistant) Inyati spray in bedliner Black TRD Pro bed inserts Vivid Racing Leather wrapped steering wheel AJT Designs TRD shift knob AJT key fob Morimoto LED fog lights Full JL Audio sound system upgrade Kenwood 995S HU
    sdhq_offroad likes this.
  22. Apr 8, 2019 at 5:42 PM
    #82
    PLC721
    PLC721 New Member
    Patrick
    Chandler, AZ
    2018 Ram 2500 Cummins Laramie
    IG: PLC721
    Keep us posted!
    Kilos[OP] likes this.
  23. Apr 8, 2019 at 6:23 PM
    #83
    Kilos
    Kilos [OP] YotaPro
    Brett
    AZ
    Should have my truck back Thur or Friday, will let you know how it drives!
  24. Apr 24, 2019 at 2:54 PM
    #84
    zackbremer
    zackbremer New Member
    Da Z
    i had heavy 35s toyo rt and not sure the 4.88s would have been worth it..youd def notice a difference but unless you really like the skinny pedal i didnt notice that much loss in power and it didnt hunt for gears on the hwy.
    i then upgraded to heavy 37s toyo rt again 78lb each and def noticed a loss in power, i had to mash the throttle instead of tapping it to hang the ass end out on dirt roads, and it was constantly shifting between 5/6th on the hwy really annoying, say goodbye to cruise control.
    now with 4.88s and JBA headers the truck feels like a race car, the headers brought the power back, the gears brought back my MPG and made it cruise on the hwy without hunting for gears. spins em real easy now. getting 13mpg woot woot
    careyrob and Tacotundra like this.
  25. Apr 26, 2019 at 9:25 AM
    #85
    Kilos
    Kilos [OP] YotaPro
    Brett
    AZ
    Two weeks post install and here are my thoughts...
    Drives amazing, feels like I’m back to stock power and shift points.
    MPGs pre regearing 10.X city and 12.X highway. POST regearing, 13.X city and 16.X highway. I’m on 35s with a stage 6 icon setup.
    Beast mode is unreal!
    Off road, much much better.
    Highway, running just shy of 2k rpm at 70mph and back in the stock power band. No gear hunting whatsoever.
    Overall, one of my favorite mods! If you’re one the fence, take the leap and enjoy!!
    monaco730, ZPMAN and Mountains49 like this.
  26. May 17, 2019 at 12:22 AM
    #86
    SK_Tundra
    SK_Tundra New Member
    Stockton Ca
    2015 Tundra Mall Rated
    What shop?
  27. May 17, 2019 at 4:54 AM
    #87
    Fspmdt
    Fspmdt New Member
    2016 tundra 1794
    differential doctors he had a spring special going on
    TundraLaw likes this.
  28. Aug 15, 2019 at 4:17 PM
    #88
    tribalega
    tribalega New Member
    Gus
    2016 Tundra SR5
    6” lift, CAI, exhaust, 35”
    Sorry Im late fellas, I have a 2016 SR5 and was about to pull the trigger on 4.88’s and the guy at Jegs told me it wasn't recommended for the rear axle? Any input?
  29. Aug 15, 2019 at 4:51 PM
    #89
    Kerch71
    Kerch71 Surgical Precision
    Mechanicsville VA
    I have the Nitro truck that I bought from the Nitro Gears owner. 4.88, SC, 37s. Highly recommend it.20190324_152749.jpg
  30. Aug 15, 2019 at 5:19 PM
    #90
    Fspmdt
    Fspmdt New Member
    2016 tundra 1794
    #1 Don’t listen to JEGS
    #2 Buy from a vendor on here
