Newb here, 4.7 V8 vs 5.7 V8
Discussion in '2nd Gen Tundras (2007-2013)' started by Aron9000, Apr 22, 2018.
  1. Apr 6, 2024 at 5:37 PM
    #61
    MEWaters
    MEWaters New Member
    Maine
    07 2UZFE; previous 02 AC 323k
    I’d like to know how many engines have actually needed the valves to be adjusted as well. How many 300k plus 2UZs are running strong but NeED THeiR VaLvES AdJuSTeD
  2. Apr 6, 2024 at 7:18 PM
    #62
    Red&03Taco
    Red&03Taco YUT
    Jerad
    2018 Platinum Tundra, 1997 FZJ80, 2003 Tacoma SR5 V6 5Spd
    To be fair, I have a 5vz (3.4l V6) in my '03 Tacoma, and I adjusted the valves for the first time at 278k miles. 9 of 24 valves were out of spec, and I did gain back about 1.5 mpg (average) since doing so.
    Subjectively the truck seemed to pull a bit harder. I can now break the tires loose in 2nd gear doing a "California stop" on a right hand turn, and couldn't do that beforehand
    That motor uses the same shim over bucket valve design as the 2uz
  3. Apr 6, 2024 at 7:29 PM
    #63
    MEWaters
    MEWaters New Member
    Maine
    Less than half at 300k. And not doing any damage as they were most likely loose. Not bad at all
  4. Apr 6, 2024 at 8:02 PM
    #64
    Red&03Taco
    Red&03Taco YUT
    Jerad
    Actually they tighten over time. Then you put a thinner shim in to make room so-to-speak and loosen them back into spec. But I get your point. Bulletproof and basically maintenance free design
  5. Apr 6, 2024 at 8:08 PM
    #65
    Bergmen
    Bergmen New Member
    Ukiah, California
    2018 Blazing Blue Pearl DC 4X2 SR5
    The 4.7 (2uz) had shim under bucket valve design requiring camshaft removal to adjust clearances.
  6. Apr 6, 2024 at 8:47 PM
    #66
    Red&03Taco
    Red&03Taco YUT
    Jerad
    Oh yikes, yeah that would suck. I didn't realize that
  7. Apr 7, 2024 at 10:41 AM
    #67
    Rph74
    Rph74 New Member
    Springfield,MO
    2007 Tundra Crewmax Limited Silver/Redrock
    And here I thought that I was the only weird one who prefers the timing belt system. The required maintenance is a double edged sword-it does cost $$$$, but there is that peace of mind that your timing system has been renewed, along with the water pump and perhaps other things while you’re there.
    I do love the 5.7 in my 07, but the 4.7 in my wife’s GX470 is oh so buttery smooth.
    Red&03Taco likes this.
  8. Apr 8, 2024 at 12:23 AM
    #68
    Canman
    Canman New Member
    2007 Crewmax Limited
    Not to mention also how quiet the 4.7 is. When my daughter initially purchased the Tundra I’m now driving, I was shocked at how loud it was at startup. The Car Care Nut guy also made note of that comparing the two engines.
    Started watching Sarah-n-Tuned on YT, and can’t wait for her to start up her 4.7 she installed in her classic Celica.
    Rph74 likes this.
